August 06, 2026, 08:43:46 pm
Hoffman Amps Forum image Author Topic: Poors Mens question - HiFi Speakers Box used for guitar amp ???  (Read 5759 times)
« on: January 04, 2024, 02:36:08 pm »
I've read recently about Full Range Speakers for guitar use
and ...
Sometime happens that I can have under hand a single HiFi Box (because the other was broken), so I can recovery the speakers
Also recently I got a broken SS Bass amp that obviously has a Bass Speaker
My question is ...
Can I use the speakers of an HiFi Box (I consider the 2 way Box) or a Bass Speaker in junction to a Twitter as Speakers for a Guitar Speaker Box ?
This will save some money and to save money on doing something that is an hobby .....
Offline WimWalther
Re: Poors Mens question - HiFi Speakers Box used for guitar amp ???
« Reply #1 on: January 04, 2024, 03:12:19 pm »
The first thing to know is that hifi speakers aren't designed for the sort of abuse that an electric guitar can dish out. They tend to be easily damaged being used this way.
But so long as the speaker is of the required impedance (4 or 8 ohms) and a sufficient power rating (watts) then it should work. Just watch the volume level.. and don't be surprised if it becomes damaged.
« Last Edit: January 04, 2024, 08:32:34 pm by WimWalther »
Offline Latole
« Reply #2 on: January 05, 2024, 03:52:13 am »
Few hi-fi speaker I test with guitar have very low sensitivity
« Reply #3 on: January 05, 2024, 06:16:42 am »
Yes, a hifi speaker will be very quiet, turn up the amp and you’ll probably damage it. Plus it’ll sound bad.
Also with amps that have a lot of negative feedback, the weird impedance response due to high order filters in the crossover may possibly cause stability issues.
The bass cab should sound ok, provided the broken amp didn’t wreck the speaker with DC (common failure mode).
If it’s ok, maybe consider tweaking the cab, eg block off front port, remove the back panel.
Whatever, it’s all zero cost stuff to tinker with  :icon_biggrin:
« Reply #4 on: January 05, 2024, 07:22:22 am »
I have been using 6 way Pioneer speakers in my setup for many years
I run stereo out of my Kemper into a 1000 watt (500 per channel) Crown power amp
A neighbor gave me two Pioneer 6 way speakers many years ago
They turned out to be very high quality speakers but only 150 watt
I tried to not blow them up
I got away with that for maybe 8 years
One of the 15 inch woofers blew up last month
I replaced both cabinets with Eminence 300 watt 15 inch woofers
They sound really good
But keep in mind that the Kemper is supposed to use full range speakers, not guitar amp speakers
You can turn off the speaker section in the Kemper and then use guitar amp speakers if you want to
I cranked them a few days ago and blew the crossover in the right cabinet
I still have to dig into them and see how to bypass that crossover
Not sure I even need all those smaller speakers, just the 15 inch woofers
Here's a couple images of the new Eminence speakers in the cabinets and the Kemper rig
« Last Edit: January 05, 2024, 07:33:19 am by EL34 »
« Reply #5 on: January 05, 2024, 07:27:47 am »
If I can get away with using just the 15 inch woofers, I may chop the cabinets down to a smaller size
Cut off the bottoms, shorten the cabinets and put the bottoms back on
I'll mess with that when I have time
« Reply #6 on: January 06, 2024, 02:38:54 am »
Many thanks to All Friends
Franci
Offline WimWalther
« Reply #7 on: January 06, 2024, 03:48:37 pm »
@EL34
I do not recognize those Pioneer units. In fact, I wasn't even aware that they sold a 6-way design.
What era are they? Are these standard US-export models, or some Japan-only thing that someone managed to import?
« Reply #8 on: January 06, 2024, 08:16:56 pm »
... What era are they? Are these standard US-export models, or some Japan-only thing that someone managed to import?
Squinting at EL34's photo after opening in a new tab, and I see "CS-911A" on the badge.
Googling turns up this 1975 ad for the CS-911, and an eBay listing for the manual if you really want the poop.  Not much helpful free stuff online at the moment (though perhaps some other 1976-era ads in World Radio history if you go leafing through stereo mags).
« Last Edit: January 09, 2024, 05:24:44 am by HotBluePlates »
Offline WimWalther
« Reply #9 on: January 06, 2024, 10:31:55 pm »
Ok, so they're early-mid 70s stuff. Cool.
Back in the early 70s there were fewer export-only models, like the amazing PL-41 turntable - sort of a Japanese copy of the Empire 298 / 208 tables.
Anyway, that was the era where hifi had gone totally crazy, back when quadraphonic audio seemed like the way of the future.. with competing formats, like the Beta / VHS fight of the early 80s still to come.
« Reply #10 on: January 07, 2024, 06:25:37 am »
@EL34
Don't know
I did see some on a search with a asking price of $750
My neighbor gave them to me about 9 years ago
The model number is Pioneer CS-911A on the tags
I managed to baby them along all this time until last month when I blew up one of the 15 inch woofers
Offline ShoemanGB
« Reply #11 on: January 07, 2024, 04:29:58 pm »
All I know is that if you had those back in the day ( I was in High School) you'd have been the coolest kid in school.
« Reply #12 on: January 08, 2024, 07:11:39 am »
I could not have afforded them way back then.
I did work at a record store in the 70's
We had an audio sales room with Pioneer gear
Back then, you could get huge discounts on gear direct from Pioneer as an employee
My price was less than what the dealer payed for their items
I bought a Pioneer turntable,  Pioneer Cassette deck and a few other things while I worked there
I already had a Sansui amp and some Marantz speakers.
