June 17, 2026, 01:10:41 am
Hoffman Amps Forum image Author Topic: Vox AC4HW1 Hum  (Read 8498 times)
Vox AC4HW1 Hum
« on: January 06, 2024, 11:02:36 am »
I see online that Hum is an issue with the AC4HW1. I have one and just started looking inside.
Question! What are the (2) blue wires from the transformer attached to the heater filament Green leads for?I can see the (2) 100 ohm filament resistors. I would have thought the center of those (2) resistors 100 ohm would be going to ground but their not.I have pulled the preamp tubes one by one and the hum is still there. Looks like a decent build except for the filament wiring. Attached PDF with schematic.
« Last Edit: January 06, 2024, 11:05:15 am by plexi50 »
Re: Vox AC4HW1 Hum
« Reply #1 on: January 06, 2024, 12:28:25 pm »
Is this really a question???    :think1:
Vox was never known to paint the wires the color you like.   :icon_biggrin:
Re: Vox AC4HW1 Hum
« Reply #2 on: January 06, 2024, 12:28:38 pm »
My Bad. The heater filament wires are Blue and go through a fuse. I feel like an idiot!!! :dontknow:
Re: Vox AC4HW1 Hum
« Reply #3 on: January 06, 2024, 12:29:57 pm »
Yes i just notice the blue are the filament wires. Didn't expect a inline fuse for them.
Re: Vox AC4HW1 Hum
« Reply #4 on: January 06, 2024, 12:30:19 pm »
here, this might help, although you have to apply the colors  :icon_biggrin:
Re: Vox AC4HW1 Hum
« Reply #5 on: January 06, 2024, 12:34:01 pm »
Each resistor reads 49.5 ohms.Center of 100 ohm resistors on diagram are grounded. Mine are not.??? Tried to ground for a second and heard a hum.
« Last Edit: January 06, 2024, 12:36:32 pm by plexi50 »
Re: Vox AC4HW1 Hum
« Reply #6 on: January 06, 2024, 12:35:07 pm »
Never hurts to LOOK AT THE SCHEMATIC.    :icon_biggrin:
Re: Vox AC4HW1 Hum
« Reply #7 on: January 06, 2024, 12:36:40 pm »
Exactly what they should read in circuit. Guess why?
Re: Vox AC4HW1 Hum
« Reply #8 on: January 06, 2024, 12:42:20 pm »
In circuit with heater leads.
Re: Vox AC4HW1 Hum
« Reply #9 on: January 06, 2024, 12:50:56 pm »
No Continuity To Ground With Meter.
Re: Vox AC4HW1 Hum
« Reply #10 on: January 06, 2024, 01:46:15 pm »
or 2 100's in parallel with each other ='s 50?
se the note next to the circled ground?  says heater ground.  so now measure heater ground to ground ground(chassis) n see if they are zero ohms apart or...
Re: Vox AC4HW1 Hum
« Reply #11 on: January 06, 2024, 03:29:30 pm »
... Center of 100 ohm resistors on diagram are grounded. Mine are not.??? Tried to ground for a second and heard a hum.
Start with the complete AC4HW1 schematic
100Ω resistors are tied to "Heater Ground" which ≠ "Chassis Ground."
Skim the schematic, and you see that "Heater Ground," "Tone Ground," and "Ground" are all unique and separate from Chassis Ground.
Look over to the Input Jack area of the schematic to see why:  R29 and C19 separate circuit-ground from Chassis Ground, almost certainly as a ground-lift and to kill RF interference.
Re: Vox AC4HW1 Hum
« Reply #12 on: January 06, 2024, 03:40:45 pm »
Ok i will get there and look it over.
I think this may help. I pulled on the Heater Filament wires from the EL84 going under the board 7" roughly and this is what it looks like. The wires are just laying under the board and connecting to the filament resistors at the far right end of the board. I am going to run them down from the filament resistor connections to the EL84 tube filament pins away from the OT wires. Twist them good and should eliminate 3" of wire and as far away from the board and OT as possible. The wires are barley even twisted together.
Re: Vox AC4HW1 Hum
« Reply #13 on: January 06, 2024, 04:30:05 pm »
Wow! What a difference! Killed about 80% of the hiss / noise. Now onto the input later. I am wiped out. And yes Steve the wire color coding in this amp sucks. I cant believe it is this quiet now! :think1:
« Last Edit: January 06, 2024, 05:11:03 pm by plexi50 »
Re: Vox AC4HW1 Hum
« Reply #14 on: January 07, 2024, 11:10:08 am »
Heaters to ground. I find no continuity from center resistors to ground. Why if it's going to ground?? Here is the reading from center heater resistors to ground.God i have to clean my meter!
« Last Edit: January 07, 2024, 11:16:47 am by plexi50 »
Re: Vox AC4HW1 Hum
« Reply #15 on: January 07, 2024, 11:30:46 am »
100K IS a reference to ground, seems high though, I would expect ohms to small K-ohms
the schematic doesn't show anything worth while for the ground scheme.  suspect it's follow the wires time.
Re: Vox AC4HW1 Hum
« Reply #16 on: January 07, 2024, 11:55:09 am »
I m going to try and see if i can get a small dental mirror and light under the board to see if the center resistors that should be going to ground is wired to anything. So far all wire searches with meter show no continuity to them or any ground. I hate this thing.
Re: Vox AC4HW1 Hum
« Reply #17 on: January 07, 2024, 12:04:58 pm »
Used dental mirror and light. Dead end. Just a blob of solder in the center of the board where the filament resistors connect together.Dam this is not possible! Those (2) center 100 ohm resistors must go to ground! That's the whole point in them being there!
« Last Edit: January 07, 2024, 12:28:41 pm by plexi50 »
Re: Vox AC4HW1 Hum
« Reply #18 on: January 07, 2024, 01:03:01 pm »
Positioned all grid wires up and away from any other wires. It's as quiet as it's going to get which is 100% better than it was.Especially the heater filament wires being in a bundle off the EL84 & away from the OT. Shortened the OT EL84 plate wire as well. Done!
Re: Vox AC4HW1 Hum
« Reply #19 on: January 07, 2024, 01:04:57 pm »
Ciao
If you want to fix in a better way the proplem you must put your hand on your iron
so why not to arrange a better situation in your AC4 ?
instead to connect the junction of the resistors to ground why don't arrange a Voltage Divider from the PS and elevate the ground on 40 - 60 V DC ? Usually this is a better way to avoid Humm (remember to add an e-cap)
or simply connect to the cathode of the Power Tube
Other thing you can do is to remove the two 100R resistors and mount a 500 R pot as Humdinger (you can connect the wiper directly to ground or to an elevated DC source as a Voltage Divider from PS or to the Cathode of the power tube)
« Last Edit: January 07, 2024, 03:09:48 pm by kagliostro »
Re: Vox AC4HW1 Hum
« Reply #20 on: January 07, 2024, 02:40:31 pm »
Thankyou much Franco. Good info to know. I will go over this.
Offline Bieworm
  • I like it loud!
Re: Vox AC4HW1 Hum
« Reply #21 on: January 08, 2024, 12:35:09 am »
I would simply disconnect the conjunction of the 2 100 ohm resistors from wherever it’s going and wire them to the + side of the cathode resistor of the power tube ( like Franco hinted)
This will elevate the heaters and is a proven tactic to reduce hum in cathode biased circuits.
