September 08, 2026, 10:48:04 pm
Hoffman Amps Forum image Author Topic: Anode voltage power supply.  (Read 6008 times)
Offline slash1986
« on: February 05, 2024, 11:11:25 am »
Hi, I would like to ask you. I'm having trouble finding transformers here in my country to build a power supply for my tube projects. On various Chinese sites, you can see small switchig step up power supplies for a few euros. Is it possible to build a power supply for the anode current with these boards?
here is an example: https://it.aliexpress.com/item/4001247455370.html
{edit: tracking URL removed - PRR}
« Last Edit: February 07, 2024, 11:41:13 pm by PRR »
Re: Anode voltage power supply.
« Reply #1 on: February 07, 2024, 02:05:06 pm »
All depends on the HT current you need. 70V.A/450V = 155mA tops.
However, I personally wouldn’t use one of those power supplies - is it really going to last at 70W dissipation? I highly doubt it. Get a proper PT.
« Reply #2 on: February 07, 2024, 05:57:52 pm »
It's often cheaper to save your money, wait & buy the right part.
It's often more expensive to buy the "cheap part," find out it doesn't work as well as hoped, and then buying "the right part."
Offline slash1986
« Reply #3 on: February 11, 2024, 11:59:08 am »
Since I have 2 120VA transformers with 230v primary and 15-0-15 secondary, I would like to use them and connect the two secondaries  to have 230v on the primary of the second transformer. I could then rectify the voltage with a voltage doubler circuit like this:
« Reply #4 on: February 11, 2024, 12:35:40 pm »
Two times 230V AC in a capacitor makes about 650V of DC. Do you need that much?
(It's what my 300 Watt Bogens ate.)
Offline slash1986
« Reply #5 on: February 11, 2024, 01:29:29 pm »
probably not. but I would like to have at least 400v.
with a normal diode bridge I would only have 325 v. some advice?
Offline WimWalther
« Reply #6 on: February 11, 2024, 09:18:09 pm »
Do you own a Variac (aka variable auto-transformer)? You could arrange your PTs as you suggest, with the fullwave doubler and use the Variac to adjust the output.
If you are planning to work with electronics as a hobby, you really should have a Variac in the first place. They are extremely useful for testing new equipment or equipment under repair.
