September 14, 2026, 11:10:55 pm
Hoffman Amps Forum image Author Topic: Deluxe Reverb build with the Tone Stack off the board  (Read 6880 times)
Offline MSVguitar
« on: February 17, 2024, 08:32:24 pm »
I am planning to build a Deluxe Reverb AB763.  I found some info on Rob Robinette's site that showed a layout of the tone stack built on the pots and a tag strip.  I thought that it was a good idea that allowed for short leads between the pots and components while gaining some space on the main board.  I just started a layout and thought that I would post it for feedback.  Also, I am planning to replace the tremolo oscillator with Sluckey's Trem-o-nator.  Any comments and suggestions would be appreciated.
Offline glass54
Re: Deluxe Reverb build with the Tone Stack off the board
« Reply #1 on: February 17, 2024, 08:39:16 pm »
Hi MSV,
Done it many times. I've kept it fairly compact and you are right to use quality shielded audio cable/Coax.
(Even done it with James stacks) No instability :icon_biggrin:
Regards
Mirek
"To measure is to know"
Offline MSVguitar
« Reply #2 on: February 18, 2024, 02:34:16 pm »
Hi Mirek,
Thanks for your feedback!
Best Regards,
Mark
« Reply #3 on: February 18, 2024, 03:14:18 pm »
I did the same with my PeeWee amp.
Offline Jonas
« Reply #4 on: February 18, 2024, 03:15:07 pm »
Mark,
I do this as well. I use a dual ganged pot but scrape the carbon off the top pot  at each end and the wiper creating a 3 tag terminal strip.
« Reply #5 on: February 18, 2024, 03:19:49 pm »
Unusual but neat idea! I like it. Could be trouble for someone else later on.   :icon_biggrin:
Offline WimWalther
« Reply #6 on: February 18, 2024, 04:00:34 pm »
Clever it is.. though I agree this could be more than a little confusing for some future technician.
One possible alternative is to solder a 3-pos strip directly to the case of the pot. You get your 3 terminals, and it's less costly and confusing.
(I'm also a fan of replacing FP-style cans by bending a terminal over and soldering the foot of a term strip to it. Gives you a place to mount new caps and the ground lugs on the can are still available.)
Offline MSVguitar
« Reply #7 on: February 19, 2024, 07:44:01 pm »
Thanks everyone for the feedback.  I also like the alternatives for mounting the components, but I don't know what a FP-style can is. :dontknow:
« Reply #8 on: February 20, 2024, 08:29:48 am »
here so you can see one  FP is a letter designation Mallory used to identify its metal can capacitors  https://hallmanlabs.com/wp-content/uploads/2020/01/Mallory_FP-WP_Series_capacitors_1985.pdf
« Last Edit: February 20, 2024, 08:34:03 am by mresistor »
Offline MSVguitar
« Reply #9 on: February 20, 2024, 09:15:32 am »
Got it!  I had never heard the 'FP' reference for a cap can.  Thank you!
Offline 66Strat
« Reply #10 on: February 20, 2024, 10:26:07 am »
The attached YouTube links show the CE production process using the original/antique Mallory machinery.
https://www.youtube.com/watch?v=yfSSIO2c_ak
https://www.youtube.com/watch?v=ITYPYwc_GEo
https://www.youtube.com/watch?v=HDcEZURxWOs&t=0s
Regards,
JT
