August 29, 2026, 07:22:42 pm
Hoffman Amps Forum image Author Topic: What parts determine tone?  (Read 15440 times)
Offline pbman1953
« on: March 12, 2024, 08:57:25 am »
In a preamp what parts should be experimented with when trying to contour tone-
I have tube preamp pedal that's based on a B15 preamp. My question is, what is the determining factor that makes it a B15 emulation ?
  The resistor or cap that is connected to certain pins on the tube?
  • Parts after the tube?
  • The eq circuits?
I’m wondering , if it’s simple to change a value in the right place to make it more like a Fender or Sunn. The B15 s nice but I like a softer midrange, where Ampeg always seemed to have a stronger mid compared to most others.
« Last Edit: March 12, 2024, 09:12:16 am by pbman1953 »
Offline acheld
Re: What parts determine tone?
« Reply #1 on: March 12, 2024, 10:00:03 am »
As a first step, I'd suggest going to http://www.duncanamps.com/tsc/ to check out the tone stack calculator. You can experiment with different components and/or setups given your question, which seems to point toward the tone stack.
"Gain" related tone is an entirely different discussion . . .
Offline WimWalther
« Reply #2 on: March 12, 2024, 10:31:47 am »
There are many factors that can affect the sonic qualities, or "tone" of an amplifier, but they fall into two main categories: circuit topology and component choices.
So the particular circuit used can have a very large effect on the sound. After this, things like tube / transistor / op-amp types, capacitors, resistors, pots / controls, chokes, transformers and even wire and solder all contribute to the final sound to varying degrees.
Now I don't know what makes your preamp sound / behave like a B15 - there are several approaches to this goal. But chances are that the pedal shares the same basic circuit with the B15, and the components used are modern approximations of those found in the original.
Or at least that's how I (and probably others, here) might approach it. But in today's world of powerful yet cheap & ubiquitous electronics, digital modeling can't be overlooked.. but as the saying goes, that topic is beyond the scope of this discussion. ;-)
« Last Edit: March 12, 2024, 10:37:59 am by WimWalther »
Offline pbman1953
« Reply #3 on: March 12, 2024, 10:35:52 am »
The pedal is an Arkham Oracle and the tone circuit info is here-
www.arkhamsound.com/james.html
Offline WimWalther
« Reply #4 on: March 12, 2024, 10:46:01 am »
Apologies if I'm misreading you, but it seems like you're asking two different questions, here..
1) What makes my specific B15 emulation pedal "B15-like'?
2) How do different topologies and component choices affect the sound of an amp / preamp?
Which is it that more interests you? Which would be more helpful?
ETA: Many edits
« Last Edit: March 12, 2024, 10:51:00 am by WimWalther »
Offline pbman1953
« Reply #5 on: March 12, 2024, 10:52:55 am »
Both in a way-
1) What makes my B15 emulation pedal "B15-like'? What are parts that make it B15 like? Parts before the tone controls or after? Are there values that can be changed on the tube that could soften the "Ampeg" sound?
2) How do different tone stacks affect the sound of a preamp? I think tampering the tone stack would not be a good idea. I was hoping that changing a value on the tube may be the solution
Offline pbman1953
« Reply #6 on: March 12, 2024, 11:24:05 am »
Between this pedal and  other Ampeg inputs , pin 7, the Ampeg Normal channel use a 47k. This pedal uses a 1M
Offline Williamblake
« Reply #7 on: March 12, 2024, 12:15:35 pm »
hth
Offline acheld
« Reply #8 on: March 12, 2024, 05:29:20 pm »
The pedal is an Arkham Oracle and the tone circuit info is here- www.arkhamsound.com/james.html
Lots of good info on your pedal's information page, and how they've approached their tone.
Offline WimWalther
« Reply #9 on: March 12, 2024, 11:38:58 pm »
If those are resistance values from input to ground, they are two very different loads, and likely to have a noticeable impact on sonics.
Offline pbman1953
« Reply #10 on: March 13, 2024, 07:03:59 am »
I was wrong on that one. The 1M is out of the circuit when the jack is plugged in
« Reply #11 on: March 14, 2024, 08:46:07 pm »
... The 1M is out of the circuit when the jack is plugged in
Not according to Arkham:
Specifications:
IN: 1/4" TS, Input Impedance = 1 Meg ohm
That said, the B15N schematic shows an input impedance of either ~5.6MΩ (Normal channel) or ~150kΩ (Bright channel).
The lower resistance of the latter would normally roll-off treble from the pickup (due to interaction with the pickup's L-C-R), but the upper leg of the 100kΩ/47kΩ voltage divider is bypassed with a cap to retain highs at full-strength.
Offline passaloutre
« Reply #12 on: March 14, 2024, 09:06:16 pm »
I would say it is precisely the tone stack that makes this sound like an Ampeg and not a Fender or a Sunn.
Offline AmberB
« Reply #13 on: March 14, 2024, 11:06:17 pm »
The type of tone circuits that an Ampeg preamp has are quite different from the Fender/Marshall/Sunn type tonestack.
The Ampeg type tone circuit has the capability to boost the affected frequencys of the bass and treble controls from "flat" as well as to cut them.  Generally speaking, the frequency response is closest to flat when the tone controls are at about 5 on the 1-10 scale.
The Fender type tone stack is all cut, no boost.
That is one of the differences in the "sound" of the different amps.
The RCA tube manual shows a typical tone circuit of the Ampeg type, it's almost like Ampeg just used the RCA circuit descriptions for a lot of their amps.
Bogan also used the RCA type tone circuits in a lot of their PA amps, especially the CHB series.
Also, there is an RCA type tone circuit that has a midrange control as well as bass and treble.  It's quite interesting.
Offline pbman1953
« Reply #14 on: March 15, 2024, 06:26:22 am »
Specifications:
I was looking at my 70's B15 schematic and it doesn't have the 1M resistor, to ground, but here on the Hoffman site I see the early 60's versions do with a 120k resistor.
Offline pbman1953
« Reply #15 on: March 15, 2024, 06:28:11 am »
Based on what you said I'd never be able to cut the frequencies I need on this design.
Offline pbman1953
« Reply #16 on: March 15, 2024, 06:31:09 am »
The company is with holding the schematic. I can't blame them for not wanting their unit to be altered.
Would it help if I made a diagram to show signal path and the parts used?
« Reply #17 on: March 15, 2024, 09:35:41 am »
1/ It's not marketed as being a B15 emulator. Rather it's "inspired by the iconic Portaflex Bass amps of the 1960's" https://arkhamsound.com/oracle.html
So from that, I wouldn't expect it to be an exacted copy of any particular B15 preamp circuit.
2/ A valve guitar/bass amp is a system, not just a preamp; what's the rest of your system?
In the absence of a power amp, speaker and cab that respond closely to those of a B15, even if it was an exact copy, a B15 preamp shouldn't inherently be expected to sound like the full amp. eg a B15 preamp into a full range flat response rig won't sound like a B15.
...The B15 s nice but I like a softer midrange ...
How about inserting a good graphic eq device between the preamp and the rest of your system?
That may be by far the simplest and most effective way forward.
« Last Edit: March 15, 2024, 09:48:38 am by pdf64 »
Offline pbman1953
« Reply #18 on: March 15, 2024, 10:12:42 am »
Great responses.
I use a Bergantino 212 cab and Sumo Class D amp
I'm thinking of getting a parametric eq. Please keep in mind that both my B15 and SVT have switchs to filter out the peaky mids. This has the sweep range pot which doesn't lower the peaks.
« Reply #19 on: March 15, 2024, 10:39:23 am »
I disagree with several points above.
1/ it seems contradictory to describe the Fender tone stack as being 'all cut', whilst describing the Ampeg as being able to both 'boost and cut'.
As I see it, all such tone stacks enable at least treble and bass to be adjusted above and below some notional nominal level.
2/ If Fender is cut only, then so is the Ampeg.
3/ Rather than the Ampeg being quite different design to the others, all such tonestacks use a network of passive RC low and high pass filters to achieve their effect.
4/ on a 1-10 scale, noon or halfway or 50% rotation is at 5.5.
But pot tapers of the low spec pots used in MI gear are completely untoleranced, so it shouldn't be expected for that point to align exactly or even closely with the corresponding resistance on the published taper chart.
This site has more tonestack simulations than most versions of TSC https://www.guitarscience.net/tsc/info.htm
« Last Edit: March 15, 2024, 10:43:44 am by pdf64 »
« Reply #20 on: March 15, 2024, 02:28:18 pm »
Great responses.
Such an amp should be pretty 'transparent', zero natural compression, with a high damping factor keeping the speaker cones under tight control. All those will characteristics be very different for the B15 power amp.
Does the cab have tweeters?
Whatever, I'd expect much faster attack than from the B15 cab.
How about the 'hi' switch, by the gain control?
I guess that with hi engaged, balancing the gain and master will help to fine tune the hi mids.
Offline pbman1953
« Reply #21 on: March 15, 2024, 03:21:00 pm »
The high switch makes it too bright. No tweeters on this can. Dont need them.
Please take 5ge can out of the equation. The sound of this pedal, let's say, sounds like an Ampeg type sound. Very strong in the midrange. I didn't realize it would be that strong but, it sounds better than anthing I've heard or played with.
I'm trying to draw up the wiring diagram. I have all parts Id'd so I'll send this drawing soon
Thanks to all!
« Reply #22 on: March 15, 2024, 03:49:35 pm »
... an Ampeg type sound. Very strong in the midrange. ...
You do realize that Ampeg's way to scoop-Mid is done by cranking up Treble & Bass, right?
Turn Treble to max, turn Bass to max.  Still mid-heavy?
« Last Edit: March 15, 2024, 03:52:42 pm by HotBluePlates »
Offline pbman1953
« Reply #23 on: March 15, 2024, 04:19:58 pm »
You're 100% right. Arkham told me to max both the bass and treble and still it's barky in the midrange. I'm using my tube amps as a comparison. Comparisons were made with my Fender Studio bass head and my Sunn 2000s. Much smoother in the 600-1k area
« Last Edit: March 16, 2024, 03:38:21 pm by pbman1953 »
Offline pbman1953
« Reply #24 on: March 15, 2024, 04:59:54 pm »
I made a very crude drawing so I apologize first.
2 drawings- Input and tone controls.
You will see this "Point "B":
4 parts are connected together on a terminal:
.004uf cap- terminal from the treble pot
.001uf cap from the Low Boost sw
220k resistor from the Bass control pot
.002uf cap from the pin 1
Please let me know if this makes sense and if it does, would changing any these values help my issue? If not thanks very much for looking!
Offline pbman1953
« Reply #25 on: March 16, 2024, 03:39:31 pm »
Anyone want to take a stab at this?
Offline passaloutre
« Reply #26 on: March 16, 2024, 04:04:55 pm »
Playing around with the TSC, turn both Bass and Treble up to ten, then back off the bass to like 7-8 or so. That cuts out a lot of those lower mids without losing the fundamental.
Offline pbman1953
« Reply #27 on: March 16, 2024, 04:41:22 pm »
I've worked through many of the suggested adjustments from Arkham and others. Still nothing truly moves enough mid out to be satisfied with.
The next question is, from the drawing, if any of the parts could be subbed, or look for another preamp unit
Offline AmberB
« Reply #28 on: March 16, 2024, 05:18:28 pm »
Here's something that may be of interest to you.
Offline AlNewman
« Reply #29 on: March 16, 2024, 05:36:26 pm »
I've built a few amps with the James tonestack, and it's very versatile, that being said, everything has an effect on tone and gain.  I think it's fairly similar to the fender TMB stack, with the mids on 10 all the time.
If I were trying to reduce mids, I would look into reducing the value of the 22k resistor at the bottom of the bass control.  It's fairly easy to experiment with, as you can parallel different value resistors to find what you're looking for.
Offline pbman1953
« Reply #30 on: March 16, 2024, 07:07:31 pm »
You're a genius!
Yes that worked and made a difference to take some of the honk out of the mods. It is suttle, but could be enough. I started with all controls flat, all boosts off with a 15k, then 10k, then 5, the 1k and I settled on 470 ohm.
Thanks for taking on the challenge  with me!
« Last Edit: March 18, 2024, 05:08:12 pm by pbman1953 »
Offline pbman1953
« Reply #31 on: March 17, 2024, 11:22:00 am »
Any other parts hat come into play?
Offline AlNewman
« Reply #32 on: March 17, 2024, 06:56:14 pm »
I wouldn't have thought that 470 ohm would have been the value chosen, but if it works for you then that's good.  Try playing it for a while, and figure out what works for you.
Offline pbman1953
« Reply #33 on: March 17, 2024, 06:59:26 pm »
What would you of expected?
Offline AlNewman
« Reply #34 on: March 17, 2024, 07:27:28 pm »
Whatever sounds good.  I would have probably went with a 10k resistor to test.  470 ohm, I would think you're basically dumping all your signal at certain settings.
Offline roseblood11
    • Layouts and Pictures
« Reply #35 on: March 17, 2024, 08:31:37 pm »
Why not use a pot?
Carvin hat some amps with James tonestacks with B25k mid control, for example the Nomad, Vintage 33 and Bel Air.
Offline pbman1953
« Reply #36 on: March 18, 2024, 05:10:38 pm »
Why not use a pot?
Maybe that's what the Range pot is doing. It's controlling the 2 caps on the bass control and a resistor
Offline AlNewman
« Reply #37 on: March 19, 2024, 06:31:09 pm »
If you want a fender sound with 2 knobs, build a deluxe reverb tonestack.  It will likely perform how you want.  As I mentioned earlier, everything is reactive in your James tonestack.  Just look at where the volume is positioned.
Offline pbman1953
« Reply #38 on: March 19, 2024, 06:38:13 pm »
Thanks for all your help, but I've decoded to sell it t. I put it back to stock, resistor wise. Since better weather is coming,  I'll deal with taking out my tube amp, a Fender Studio Bass head. Weight wise it's not so bad and I'll get exactly what I want. Meanwhile I'll research more for something that suits my tastes.
Thanks!
