August 29, 2026, 09:12:16 pm
Hoffman Amps Forum image Author Topic: Resistor worries.  (Read 7936 times)
Offline joesatch
  • save me from myself.
Resistor worries.
« on: June 13, 2024, 08:04:06 am »
ordered some metal oxide 2W resistors. i see they have a limit of 350V.  My B+ is over 400 volts. what do i do in this situation?
Re: Resistor worries.
« Reply #1 on: June 13, 2024, 08:19:52 am »
Ignore the voltage rating.
« Reply #2 on: June 13, 2024, 08:52:45 am »
^^what he said
pretty sure you won't be dropping 350V across the resistor, 50-60v maybe
Offline acheld
« Reply #3 on: June 13, 2024, 10:26:49 am »
I avoid TE Connectivity if possible due to variance and mislabelling (not common, but I've seen a half dozen instances in the past 4 years).
KOA Speer seems more reliable and has higher voltage specs.
I know it's not considered "correct," but I will use Vishay metal film resistors in some portions of the power supply.  Not suggesting this as best practice . . .
Offline joesatch
« Reply #4 on: June 13, 2024, 12:08:05 pm »
this makes me angry. i was under the impression Koa were the cheapest. So my order has already shipped. I'm very displeased
« Reply #5 on: June 13, 2024, 01:55:54 pm »
welcome to the 21st century  :icon_biggrin:
Offline acheld
« Reply #6 on: June 13, 2024, 03:04:38 pm »
a) Life's too short for that.
b) Just my opinion (and many might not even agree !)
c) I use a fair number of KOA Speer power resistors, so far so good. Not sayin' they're the best, but have been ok for me so far.
d) No one except you, me, and Shooter will know
e) And it will all work out . . .
« Reply #7 on: June 13, 2024, 05:30:06 pm »
At power up, the surge voltage across HT droppers can approach the full HT voltage.
Hence I suggest that a resistor type with voltage rating of the HT volage is selected.
As I've learned the hard way, some power resistor types might only have a 250V rating, these might fail in this application.
Offline stratomaster
  • Don't guess, measure.
« Reply #8 on: June 14, 2024, 11:05:31 am »
I'm having trouble internalizing this concept of a 'voltage rating'.  The maximum voltage drop across a specific resistor would be determined by its resistance and power rating.  The voltage rating must mean something other than "do not drop more than voltage rating across resistor".
Furthermore, ratings like this are usually set under very specific conditions (temperature, humidity, etc) and are therefore subject to derating if you know the curve/formula to derate to other conditions.
Until I understand further I'm in the "ignore" camp only because I've never seen a resistor failure that I could attribute solely to exceeding its voltage rating.  Always there was a short of another component nearby that caused over dissipation.  Maybe I've just been lucky.
Offline Merlin
« Reply #9 on: June 15, 2024, 11:42:40 am »
You'd be right if it weren't for transients. Power rating is for continuous dissipation, but it's still OK to exceed it on transients, when the voltage across the resistor is momentarily higher -but not beyond the voltage rating.
Offline joesatch
« Reply #10 on: June 17, 2024, 09:28:29 am »
i might toss these. even the mouser invoice says 350v.
« Reply #11 on: June 17, 2024, 12:52:44 pm »
But if they’re doing jobs where they’ll never see 350v, they’ll be fine. Lots of 1/2W resistors in lots of amps only have a 350V rating. (Leo’s schematics have a standard note stating ‘all resistors are 1/2W unless otherwise specified’, those are all 350V rating. Lots of commercially made tube amps have 1/4W resistors - and those only have a 250v rating).
« Reply #12 on: June 17, 2024, 01:15:26 pm »
Don't throw them out. Even if you don't want to use them in a build, you can use them just to temp something your trying with gator clips.
