July 25, 2026, 09:32:18 am
Hoffman Amps Forum image Author Topic: Increasing OPT Primary  (Read 6034 times)
Offline clyde
« on: June 30, 2024, 08:29:58 am »
For 4 EL84's, common value is 4k, I have a 6k transformer on hand and am wondering what it will do to the tone, power output and the effect on the tubes if I use it.  Thank you.
Offline Merlin
Re: Increasing OPT Primary
« Reply #1 on: June 30, 2024, 08:41:33 am »
Higher impedance puts greater stress on the screen grids, so it may be a good idea to increase the screen stoppers. You will also get a little less power, althought that may hardly be perceivable in terms of volume. Tonally it's difficult to say. You'll be running more in Class-A than AB, for what it's worth.
« Last Edit: June 30, 2024, 08:46:17 am by Merlin »
Offline Glenn
« Reply #2 on: June 30, 2024, 09:58:38 am »
I have. 6.6 k OT in my Liverpool and i can’t tell the difference between my Rocket which has a 4K OT in terms of sound loudness, they are both too loud for my house.
I believe the is a 4x el84 Orange amp that also uses a 6k OT
Just my 2 cents….
Offline clyde
« Reply #3 on: June 30, 2024, 11:45:11 am »
1k?
Offline Merlin
« Reply #4 on: July 01, 2024, 06:00:51 am »
1k?
1k is standard, I'd go for 2.2k or even 4.7k.
« Reply #5 on: July 01, 2024, 06:15:21 am »
fwiw
did a qSE PA 6BQ5's into a 1250:8 ohm OT, 2 speakers for 4 ohms.  probably my best mono-block audio amp.  did pretty good with guitar n pedals up front also.
« Reply #6 on: July 03, 2024, 08:33:09 pm »
I have. 6.6 k OT in my Liverpool and i can’t tell the difference between my Rocket which has a 4K OT ...
The "right" impedance is about balancing factors:
   - Supply Voltage
   - Tube Current Capability (at the Supply Voltage)
What is Ohm's Law?
   - Volts / Current = Impedance
What often happens is the supply volts are raised and the tube can't manage more current, so the OT impedance is increased.  That results in same-current dropping more-volts across the output transformer.
If a tube is shifted to running in Class AB rather than Class A, peak plate current goes up (often a lot).  To allow more-current with same-voltage, the OT impedance is reduced.
   - If nothing else changed, the tube would overheat (because same-voltage, more-current).
   - But when we go from Class A to Class AB, we also cool off the idle bias, so the tube spends a greater period of time cooler to offset the added heat when conducting hard.
