September 08, 2026, 07:35:30 pm
Hoffman Amps Forum image Author Topic: 6g15 Mojo Build Woes  (Read 8561 times)
Offline macfadyb
« on: July 28, 2024, 06:48:41 pm »
After many fruitless hours of close inspection and hair-pulling despair I am here with the hopes that someone might be able to point me in the right direction to getting my Mojotone 6g15 spring reverb build working!
I’ve gone through the schematic and checked all the expected voltage points there, and compared them to my fluke meter readings with all tubes attached.
I have systematically checked every wire, every ground point, every component value 3 times, all parts are correct.
Build photos:  https://imgur.com/a/jSEMmmR
Schematic (with voltage points), and a chart of my recorded voltages with all tubes in: https://imgur.com/a/ekh0nLo
Any advice or suggestions would be greatly appreciated, thank you!
Offline AlNewman
Re: 6g15 Mojo Build Woes
« Reply #1 on: July 28, 2024, 07:16:41 pm »
Your 12At7 seems like it's drawing too much current.  With the amp off check resistance to ground from pin 3 and 8.  Also look under board for stray wires or solder blobs.
Offline SEL49
« Reply #2 on: July 28, 2024, 07:42:53 pm »
You missed one wire.
« Reply #3 on: July 28, 2024, 07:43:10 pm »
Can you tell us what the problem is? (Saying it ‘Isn’t working’ is too generic)
Offline macfadyb
« Reply #4 on: July 28, 2024, 07:56:06 pm »
Thank you all for the quick replies, pin 3 and 8 to ground are both around 1.48k respectively, as for actual 'problem' the unit will turn on but no audio will pass, and as for the missing jumper it is actually soldered on the other side of the board!
Offline AlNewman
« Reply #5 on: July 28, 2024, 08:06:26 pm »
Maybe there's something shorted in the socket?
Could be a bad tube...?
Offline AlNewman
« Reply #6 on: July 28, 2024, 08:12:57 pm »
Try pulling the 12At7 and recheck voltages.
Offline macfadyb
« Reply #7 on: July 28, 2024, 08:26:21 pm »
Will try this tomorrow and report back, thanks guys!
« Reply #8 on: July 28, 2024, 08:52:03 pm »
Here's a great way to check a new build that's not working;
https://el34world.com/Forum/index.php?topic=17701.msg178630#msg178630
Offline SEL49
« Reply #9 on: July 28, 2024, 09:02:54 pm »
Really. I bet you will measure no continuity between the two eyelets that the jumper should be connected.
Offline AlNewman
« Reply #10 on: July 28, 2024, 09:59:50 pm »
Oh, this wire...
Yes that would do it...
Offline macfadyb
« Reply #11 on: July 29, 2024, 06:53:49 pm »
 :worthy1: :worthy1: :worthy1:
Indeed that jumper connection was no good!  Pulled everything out to access the bottom of that board and the jumper was not making proper contact with one of the eyelets.  Reflowed solder joint and all is well.
Thank you all so much for your thoughtful responses!
« Reply #12 on: July 29, 2024, 09:51:26 pm »
That, sir, was a savage display of skill!
