April 26, 2026, 07:47:50 am
Hoffman Amps Forum image Author Topic: Princeton Build Questions  (Read 28668 times)
Offline BobL
« on: July 30, 2024, 11:04:12 am »
I am rebuilding an existing amp into a Princeton w/o Reverb or Trem (based on the Robinette layout) and really trying to use things I already have where possible.
I will be using Deluxe transformers, so if there are any things I need to consider because of that, let me know - I think I have the voltage figured out w/ the combo of rectifier and tap used from the PT.
The chassis I will be building into is a low powered tweed twin chassis, so space is at a bit of a premium, and my first question is about the bias board, and if I could move the bias board to the end of the main board as this helps me with mounting, or if I need to plan to keep that bias board away from the main board due to noise, etc?
Here is what I was picturing doing:
Second question:
I am not 100% sure if I can wire the center tap the way I have it layed out here - I am using 4x 22uF caps vs. a single can cap since this is what I have, and it doesn't involve punching holes in the chassis. So first question - is this location for the B+ node caps ok, and second question, is the center tap wiring correct here (going to the common ground at 2), or should I be going to the negative end of node A directly (at 3)?
I do this infrequently enough that I have to relearn things every time, so any guidance is much appreciated!
Re: Princeton Build Questions
« Reply #1 on: July 30, 2024, 11:33:26 am »
1. Sure it's ok to mount the bias ckt on the mainboard. Hoffman does it for his Princeton Rev.
2. The 5.3 vac center tap, the HV center tap and the main filter cap negative ends should all tie to the power supply grounding point. I think that was what you were asking. Those connections are shown on Robs layout as well the + lead of the bias cap, power tube pins 1 and 8 and the bias resistor ground are shown attached there.. Your filter caps will be mounted on the board instead of a cap can, but it is wired the same.
« Last Edit: July 30, 2024, 11:39:41 am by mresistor »
« Reply #2 on: July 30, 2024, 11:41:20 am »
Use a separate grounding point near the input jacks for the preamp grounding.
« Reply #3 on: July 30, 2024, 11:52:29 am »
Here's how Hoffman does it on his Princeton Rev ..    note   you can remote the bias adj pot or use a trimmer like shown here.
Offline BobL
« Reply #4 on: July 30, 2024, 03:13:41 pm »
Cool - I thought what I had done was okay, but wanted to make sure I wasn't missing something.
Yeah, that's my little black wire going off to the right of the board! :)
Thanks, guys!
Offline BobL
« Reply #5 on: August 20, 2024, 07:49:58 am »
About ready to get started on this build (once my new reading glasses arrive... when did I get old?)
I was hoping someone might be willing to check my work on this overall layout and let me know if there are any things I should consider doing differently?
EDIT: Oh, the bias pot I have currently mounted in this amp (I am rebuilding from existing) is 10k - guessing I can use a 22k or so resistor in place of the 10k coming off of the bias pot and that should get me into the range I need to bias?
« Last Edit: August 20, 2024, 08:11:31 am by BobL »
Offline labb
« Reply #6 on: August 20, 2024, 10:01:10 am »
I built that amp a while back. Just a note: expect B+ to be pretty high. Mine ran about 450. I used JJ power tubes. Guy has been playing it for about two years now with no issues. I have some marked up schematics for records. Will share what little knowledge I have. Good sounding amp.
« Reply #7 on: August 20, 2024, 08:17:07 pm »
Look at the B+ filter cap C node, it's not feeding anything.
Your grounding needs to be altered. The last B+ filter cap, D node, should be grounded with the preamp input jack ground.
Node C, because you have -FB, should be grounded with the PI.
The PT B+ CT should be grounded directly to the 1st filter cap's ground only. Then run a wire from there back to the chassis power amp ground.
Read this on grounding if you haven't yet.
https://www.valvewizard.co.uk/Grounding.html
And you don't have the 6V6 power tube grid stopper R's, 1K5 and screen grid R's, 470R on the 6V6 tube sockets.
« Last Edit: August 20, 2024, 08:25:20 pm by Willabe »
« Reply #8 on: August 20, 2024, 08:33:05 pm »
I just looked at the Rob Rob Princeton lite, no verb/trem, layout.
He's using a 4 section filter cap can. Your using 4 separate filter caps, which is better for grounding, separate ground for each cap.
This is why your groundings off. I would not use Rob Rob's grounding, I would use Merlin's grounding.
And you have a 5Y3 for your rectifier tube, B+ dcv will be low. You are going to need a GZ34/5AR7 or a 5U4, depending on your PT.
I'm really surprised Rob Rob has no screen grid and grid 1 stoppers.
« Last Edit: August 20, 2024, 08:45:52 pm by Willabe »
« Reply #9 on: August 20, 2024, 08:44:27 pm »
You have a faux CT for the heaters, 2x100R and you have the 6.3acv wind CT grounded.
You don't use both, 1 or the other.
Offline BobL
« Reply #10 on: August 20, 2024, 11:51:46 pm »
I think this matches the layout on Rob's site? Is this just to get the right voltage drop at D?
Can this tie to the preamp ground buss just to the right, or does it need to go all the way to the lug by the input on its own?
I think I follow... center tap to ground side of node A, wire from A to the lug.
Less clear on node C grounding with the PI and where that would be?
I was just following what was in the original schematic here, but more below...
I just looked at the Rob Rob Princeton lite, no verb/trem, layout.He's using a 4 section filter cap can. Your using 4 separate filter caps, which is better for grounding, separate ground for each cap.This is why your groundings off. I would not use Rob Rob's grounding, I would use Merlin's grounding.
Are you saying run individual wires for the ground of each node? Seems that was alluded to in the previous post...
On one of his mod layouts he has the grid stop and screen resistors... I can add those easily enough.
I had it in my head that I wanted the 392VDC that this classictone deluxe PT would give me with a 5Y3, but I think you are right... I want as much voltage as I can get from this, which would be a 5AR and give me 406VDC? Is this close enough? Attaching info on the PT...
RE: the 2x 100R and the CT being grounded... I think the red/yellow is actually my high voltage CT to ground mislabled in my layout.
I do appear to have a 6.3V CT on this PT as well, green/yellow wire... so I could just run that to ground and omit the 100Rs.
« Reply #11 on: August 21, 2024, 09:38:04 am »
This is why your grounding's off. I would not use Rob Rob's grounding, I would use Merlin's grounding.
You need to read the Merlin link I posted on grounding. Then it will be much easier to answer your grounding questions.
I can write it all out, but Merlin already did that. And you'll learn more if you read it all for yourself and then ask questions. You want what Merlin is calling a buss ground with local stars.
The way you have the grounding will probably be noisy/buzzy. Merlins grounding will quite the amp way down. New build way worth doing it now then having to go back and try and re-wire the grounds to quite the amp down. You won't like that.
« Last Edit: August 21, 2024, 10:00:26 am by Willabe »
« Reply #12 on: August 21, 2024, 09:48:45 am »
Yes.
You ground each B+ filter cap with the circuit grounds from the circuit that filter cap feeds. They call it a local star. Each B+ filter cap has it's own star ground. Then you string/daisy chain the individual stars to with a wire. So local stars bussed together with a buss wire.
Example 1st preamp tube grounds, tubes input grid R - the grid leak R, the cathode (K) R, the input jack ground and the B+ filter cap ground that feeds that tube.
Your going to end up with 2 chassis grounds for the ac circuit. 1. power amp ground, and 2. a preamp ground.
« Last Edit: August 21, 2024, 09:55:07 am by Willabe »
Offline Lectroid
« Reply #13 on: August 21, 2024, 01:48:09 pm »
Willabe is right about grounding.  You'll build better amps with just a few basic principles. The valvewizard.com has a good brief tutorial.   It seemed really daunting when I first looked at it.  But it will really pay off in reduced noise and reliability all through the amp.   Read some and ask some questions and you'll have the gist of it in no time.   :icon_biggrin:
Free Beer Tomorrow!
Offline labb
« Reply #14 on: August 21, 2024, 03:27:03 pm »
More on grounding. Go to EL34 world and search for chassis grounding. Find Doug’s grounding drawing. Ground as shown except use a pre amp grounding buss grounded on a lug at the input jack instead of soldering to back of pots. All others ground including B+ cap ground on a lug near B+ cap. Pre amp caps ground on pre amp bus. Ground 120 volt mains on a lug near where the power cord enters the chassis.
Offline BobL
« Reply #15 on: August 21, 2024, 04:04:04 pm »
Thanks all -
Ok, so... I read the Merlin grounding document... I understood... a good chunk of it. :D
Some basic principles I am taking away from this:
I should try to have the grounds be based on the section of the amp the current is looping through, but be cautious about doing this when it would result in long ground wires, which could also be noisy. Node A is my reservoir, and B is a power amp smoothing cap, feeding the power tubes, and should share a common ground on the power amp end of the amp. Node D is feeding V2, and that's why it should share a ground with the preamp circuitry that node is feeding, so should go to my preamp ground bus. More on Node C below...
Questions:
I'm not 100% clear on why there is nothing attached to the positive end of Node C? Is that to replicate the filtering scheme from the version of this amp that has trem/reverb and needs more nodes to feed those?
The Wizard text talks about creating local stars, then tying those ALL to the same ground point connection, but it seems more common to see a ground for the power amp near the power amp section, and a second ground at the input end for the preamp section (which I'm understanding to include Node D now).  I'm unclear what the best way to actually do this in the context of the amp would be?  Is the disconnect I have there that I need to think of the preamp and power amp as their own separate amps w/ their own separate 'single' ground?
The chassis grounding on el34world says do NOT do star grounding, so seems at odds with the wizard article... and also shows the two ground points, but that may be answered by the question above...
My understanding is that I would run a separate wire to my power amp ground from nodes A, B, (and C?), and then ground node D to the preamp ground - should this be a short wire that runs from the negative end of D to the preamp bus, or a longer wire that goes to the preamp grounding lug (also connected to the bus)?
I also wanted to go back to this comment: "Node C, because you have -FB, should be grounded with the PI." - perhaps this means that nodes C and D should be tied together and then go to the preamp ground, or possibly go individually to the preamp ground?
Thanks for helping me figure this out. My brains are leaking out just a little bit...
« Last Edit: August 21, 2024, 04:06:36 pm by BobL »
« Reply #16 on: August 21, 2024, 08:45:37 pm »
Your getting it, but not all yet. I'll explain as best I can so you have enough to look for in Merlin's drawings. Look how he wires each node.
Lets get this out of the way 1st;
Fender use a 'random chassis' ground system. Fender used a random ground system. Many most Fender amps are pretty quite. But with a new build or a complete re-build  want a 'wired' ground system.
And with that 'wired' ground system, there's a difference between 1.wired star ground system, 2. wired bussed local star system. We want 2, bussed local star with Doug's split buss. (See below.)
With a star grounding system, each B+ filter cap has all the grounds for the circuit it feeds grounded with that single B+ filter caps ground wire. It makes a single local ground star. Then they hook up a wire to that local ground star and do the same with all the other local ground stars and run all the ground star leads together to 1 single chassis ground. That's a chassis star ground.
With a bussed local star system it's similar, but each local ground star is hooked up to a common buss wire, 1 at a time, in the order of the circuit, end to end in the chassis. Then the buss wire is grounded to the chassis at 1 end and 1 end only. If you ground it at both ends you get a ground loop and it will buzz. Merlin with the local star buss system only uses 1 chassis ground, at the input jack.
Doug is saying to use the buss grounding, not the single star ground. Doug then splits the buss into 2 sections; 1. Power amp  2. Preamp and has each grounded to it's own chassis ground. He does this so the current in the power amp ground can't modulate (cause noise/buzz) in the lesser current tubes.
What we're trying to do is reduce chassis grounds so there's not all these different ground paths going through the chassis crossing each other/disturbing each other. The less chassis grounds the better.
The power amp has the most current in the amp because of the power tubes. This is why we isolate the reservoir filter cap and PT B+ CT from everything else, because this makes it THE noisiest ground in the amp. To deal with this we wire the PT CT directly to the reservoir filter cap's - lead, then run a wire from there to the chassis ground. That way it can loop all it want's without disturbing any other tube. See Merlin's drawings. See Merlin's drawing.
Power tube as an example; A tube pulls current up from ground through the tubes K (cathode) goes out through the tubes plate, then back through the OT's CT back to the B+ reservoir filter cap's  + lead, back down through that cap, out it's  - lead back to the power tubes K. And round and round it goes. All tube circuits we work with work this way.
Look at Merlin's drawings. Look how he wires each node.
Local ground star preamp tube example; 1st preamp tube grounds; tubes input grid R - the grid leak R, the cathode (K) R, the input jack ground and the B+ filter cap ground that feeds that tube.
You ground each B+ filter cap with the circuit grounds from the circuit that filter cap feeds. They call it a local star. Each B+ filter cap has it's own local star ground. Then you string/daisy chain the individual stars to with a wire. So local stars bussed together with a buss wire.
(The 3rd wire on the power cord, usually green safety ground wire, has it's own chassis connection. Nothing else gets connected with it. It's not part of the ac circuit grounds.)
« Reply #17 on: August 21, 2024, 08:46:11 pm »
Fender and Rob Rob (copying Fender) have all the filter caps at the PT end of the chassis. Some Fenders have them in a 'dog house' on the back of the chassis near the PT. Rob Rob went with a multi filter cap can close to the PT.
But with a 'wired' local star buss ground system, you move the filter caps to be located close to the circuit they feed. Keeps the filter cap wires short. Doug does this too.
If you do this you can move some of the resistors/caps on the board towards the PT end and closer to the tubes and pots they are wired too, ie, shorter hook up wires. That's a very good thing.
Yes, pretty much.
The B+ filter caps; 1. Reservoir filter cap, 2. Screen grid, 3. Phase inverter (PI) 4. Preamp.
Look at Merlin's drawings. Look how he wires each of these nodes.
You ground the PI with the power amp IF the amp has a negative feed back loop (-FB). This is because the -FB loop comes from the OT secondary/output. If no -FB, you ground the PI with the preamp. (See Merlins drawings.)
Look at Merlin's drawings. Look how he wires this node.
I need to say; I know Rob Rob is very knowledgeable on tube amps. With that; I don't know why Rob Rob put the PI on the D node, it's a lower dcv. I'd move the PI to the C node, higher dcv, cleaner, more output and less on the D node. You don't want too many tubes on 1 filter cap, causes stability problems.
« Last Edit: August 21, 2024, 09:04:47 pm by Willabe »
« Reply #18 on: August 21, 2024, 09:30:09 pm »
The Fender schematic shows 215dcv on the 6V6 plates.
Edit: Should be 415dcv, Willabe
« Last Edit: August 21, 2024, 11:48:22 pm by Willabe »
Offline BobL
« Reply #19 on: August 21, 2024, 10:57:31 pm »
Ok, thank you for taking the time... that was a lot of information...
I'm confused by some of this... it is almost clicking but I can't quite put it together, which is frustrating.
A = reservoir
B = power amp filter
C = nothing right now, but you are suggesting the PI
D = all of the preamp?
Seems the key things are, have a bus, and connect that bus to a single chassis point (or one for each section, but make sure that the connections to the buss occur in the order of the circuit flow (is that the right way to phrase that?) rather than just the physical location of the components on the board. Additionally, you are saying that the best case would be to move the filter caps on the board to be as close as possible to the part of the circuit/tube they are related to...
Got it.
Your power tube example is a good representation of what makes this difficult for me to wrap my head around. I do this infrequently (the last thing I built was in 2021), and as a result, I'm trying to learn enough to accomplish what I want in terms of a useable amp, but because my exposure to the circuits and technology is infrequent, it's a lot of information to try and take in at once each time I do it. Anyway... also my layout is upside down from Merlin, which confuses me. :)
So I want a local star for each section of the amp, and then a wire from each local star to the bus, and the bus to ground.
So what I need to determine is which grounds belong together on each local star, and then what order in which to attach those to the bus, and then run the bus to the appropriate chassis grounds for preamp/power amp?
...green safety ground wire, has it's own chassis connection....
Yep, already done.
Ok, so if I take a crack at what I *think* is correct here, it looks like the attached... what'd I get wrong? I am sketchy about the ground bus between A and B, and the location of the ground wire for D as well... also a lot of the rest of it. :D
Changes:
1. CT -> - lead of A
2. A & B bussed and then to ground.
3. PI using C instead of D (I think), and C ground sharing the ground for the PI... I think.
4. Preamp using D, and moving the D ground to the bus where the V2A connects?
It seems you are suggesting that the filter cap for D could move down the board in between the PI section and the V2A section, which would also move the PI stuff closer to the power tube connections - am I understanding that correctly? The CT for the 6.3V winding can go to ground as shown?
Offline BobL
« Reply #20 on: August 21, 2024, 11:04:59 pm »
I'm not seeing that? I'm seeing 410v on the plates?
Chart in my PT documentation is attached...  the fender schematic looks like 340v AC with the rectifier putting out 420V with a 5U4GB and feeding that to node A...
My PT seems to only be able to put out a max of 406v B+ from the rectifier with a 5AR4?
Have I completely lost the plot here? I might be way confused...
« Reply #21 on: August 21, 2024, 11:46:45 pm »
Very sorry, yes, 410dcv or 415dcv depending on which Fender BF 6V6 amp you look at.
« Last Edit: August 21, 2024, 11:49:45 pm by Willabe »
Offline ac427v
« Reply #22 on: August 22, 2024, 07:05:16 am »
Your transformer voltages are specified for 120 ma load (Deluxe Reverb). A Princeton Reverb amp without reverb and trem will draw much less than 120 ma so the amp voltages will run higher than predicted.
You may like that or you may want to use the r/w taps to correct for over voltage.
Heater voltage will run higher than expected too so check that after you get the tubes in but before you start playing:-)
Offline BobL
« Reply #23 on: August 22, 2024, 08:57:47 am »
If the heaters are too high, how would I handle that? I would imagine I'd need to shunt some tiny amount of voltage to ground?
« Reply #24 on: August 22, 2024, 11:23:18 am »
That's a different wind on the PT. It may be fine, have to wait and see.
« Reply #25 on: August 22, 2024, 11:25:39 am »
Why did you change the Rob Rob design from a multi cap can to using 4 single e-caps?
I don't like multi cap cans because of grounding, but that's just me. Many guys use them and their builds are quite.
Then you could just go with most of his layout. Just move the -bias over to the main board like you did.
And if your B+ is too high you can try using a 5U4. That PT has a 3A supply at 5acv.
« Last Edit: August 22, 2024, 11:28:51 am by Willabe »
Offline BobL
« Reply #26 on: August 22, 2024, 11:46:42 am »
I am building the amp into a chassis that I originally built a 6G3 into, didn't like, and then built a version of a Benson Monarch into - I am trying to use existing components I have (so I already have these 4 single caps) and avoid cutting new holes in here while I have things like all the tube sockets etc wired already.  Hence the transformers I'm using as well.
« Reply #27 on: August 22, 2024, 12:45:03 pm »
 :icon_biggrin:
A = reservoir
Close, but no; A reservoir is 1 of the power amp filters, so is B, screen grid, screen grid is in the power tube, so it gets grounded with the power tube ground.
A= reservoir, B= screen grid, C= PI, D=preamp.
On most amps the power tubes have 2 filter caps, 1 for the PT CT that feeds the tubes plate and the other for the power tubes screen grid. On this amp it has a split load PI = V2b. Rob Rob is calling V2a preamp. But it's the driver for the split load PI. I'd call it part of the PI. A split load PI has no gain so it needs a driver before it.
So; A = PT CT going to power tube plates, B = power tube screens, C = split load PI and it's driver = V2b/V2a, D = preamp V1a/V1b. That's how I'd do it.  (PT CT = power transformer center tap.)
Yes.
But almost always when you do the layout, "the connections to the buss will occur in the order of the circuit flow rather than just the physical location of the components on the board." They will/should be the same. And yes you phrased it right.
Yes, and for node C and node D, I would use a small modern radial e cap, instead of an axial lead cap. They are much smaller and less $$, so they work great for this. The current demand for the PI/driver V2 tube and V1 preamp tube is very low. So these small caps are more than enough. You need them at 450dcv and either 20uF, for V2, but you could go as low as 10uF or 8uF for V1. Some guys like a lower uF cap for the preamp, they say it's more touch sensitive.
I was trying to get you to see the 'current loop' in the tube circuit. It's just to get the grounding reasoning. That 'current loop' is how we determine what's wired into the local ground star.
Yes, very close. But not for each section of the amp, but for each B+ filter cap node. That will mostly line up with each section of the amp most of the time.
« Reply #28 on: August 22, 2024, 02:12:41 pm »
Yes.   :icon_biggrin:
Like I said before the order is already there in the chassis/board layout. That is, if it's a good layout.  :think1:  And Rob Rob's is fine.
Changes:
Close.
1. Yes, but..... see below.
2. Yes.
3. Yes.
4. No.
On 1. You moved the PT CT to the correct place, the A node filter cap  - lead. But, move the chassis power amp black ground wire from the A node filter cap eyelet to the B node (screen grid) filter cap eyelet. That's all, just move that 1 black wire.
On 4. You have the C node B+ connected to the right place now, V2b, but you still have it's  negative lead wired to the preamp ground buss. Disconnect V2b from the preamp ground buss at the junction of the 47R NFB Tail resistor and the 56K PI Tail Load R. But leave the black ground wire from that junction of 47R NFB Tail resistor and the 56K PI Tail Load R going to the - lead of the screen grid node C cap. Now connect node C's ground lead eyelet to node B's ground eyelet. It should now be; B+ node A, node B and node C negative lead eyelets are daisy chained together, with the black power amp ground wire connected to node B's ground lead eyelet, and run over to the power amp chassis ground.
Next; string that same B+ C node wire over to V2a, which is the PI's driver. Now you have to;
1. Disconnect the PI's driver ground wire (V2a) from the preamp ground buss at the junction of the 1K5 R and the K 25uF/25v bypass e-cap.
2. Disconnect the black D node ground wire at the same junction of the 1K5 R and the K 25uF/25v bypass e-cap.
3. Now run that same V2a ground junction wire over to the 47R NFB Tail resistor and the 56K PI Tail Load R. So that V2a and V2b are daisy chained/grounded together.
4. Lastly, connect node D's - ground lead to the preamp buss.
Now let me see the layout drawing after you do all this.
« Reply #29 on: August 22, 2024, 02:13:44 pm »
Close, I would move the C node cap between or close to the V2a/b R's/C's and move the D node cap close to the V1a/b R's/C's. I'd use the small radial caps I already wrote you about.
Amp lead dress; Try to keep the grid lead wires short, it's better to have to plate wires longer if needed. Once the signal goes through the coupling/blocking cap it is now a grid wire. Grid wires are very sensitive to picking up noise and bug a boo problems. So you try and move the coupling cap closer to the next tube stage it feeds if possible, and leave the plate wires long. K wires are usually not a problem.
This way you often don't need to use shielded wire for the grids.
The power tube plate wires in that layout are pretty long. At the very least you should twist them tightly together. The PI is probably putting out enough signal to be able to do this and not need shielded wire, but you still might need it.
If you move the C and D node caps, then you could turn the V2b circuit 90 degrees counter clockwise. That would shorten those power tube grid wires a lot.
Yes.
For clarity;
Power amp chassis ground;
1. Power tube caps, PT CT cap
2. Screen grid cap.
3. Heater CT ground.
4. -grid bias circuit ground.
5. If amp has -FB loop, then the PI ground.
And some say;
6. Power tube K's.
7. Speaker jack/OT ground lead. You have to use an isolated speaker jack to do this. OT has most of the current running through it. Akin amps talks about doing this.
And all the control pot grounds should go to the preamp buss, not to the back of the pots. Input jacks should be isolated from the chassis too.
Do you really need all this? Probably no. Part of it depends on how much gain the amp has, more can be more noise problems.
But the more you do these things as good amp build layout design, the more you nip things in the bud from being a problem.
I do a lot of these things on any new build or complete re-build. Many/most guys don't.
« Reply #30 on: August 22, 2024, 02:34:15 pm »
Ok, that's fine, makes sense.
I think you can finish this. But, and not to discourage you;
That it can be fairly easy to go with a proven amp circuit and layout. And yet many guys still have problems doing that.  :dontknow:
But if you don't do that, change things, then you need a whole lot more understanding of amps and grounding and lead dress and layout, etc.
When I've built an amp, I've spent 10 to 20 times more time on the computer working on the circuit changes, mods, grounding, chassis, eyelet/turret board, layout for all these things, with all the parts in my hands so I can measure them and lay them in/on the chassis and eyelet board, etc., than actually soldering it up. Not an exaggeration. But I've never had a problem at start up, not that I can remember. (Only 1 time, I had a bad preamp tube socket.)
I understand guys just want to get to soldering and get the amp built, but, then they often have problems with things, sometimes a lot of things. And they then have to spend hours trying to get the build to work.   :think1:
That is what I try to avoid with spending the time I need to get it right on paper 1st.
« Last Edit: August 22, 2024, 02:38:52 pm by Willabe »
Offline BobL
« Reply #31 on: August 22, 2024, 04:08:38 pm »
Oh for sure - that's what I'm hopefully doing a decent job of now - I appreciate all the guidance to try to get this right to begin with!  I wish I had the time to mess with this stuff more often than I do so that the knowledge would stick better - it's interesting, and I always learn new things as I do each build (I think this is the... 7th one I've built?)
I really don't need additional hobbies between 2 bands, riding a ton of mountain bikes, skiing, and raising kids... but I am interested in most things. :)
I will work through your previous posts and update here... thanks again!
Offline BobL
« Reply #32 on: August 22, 2024, 10:10:14 pm »
Attached. I'm understanding what is going on now... hopefully I understood what you were telling me to do there.
Why does the ground for A/B/C attach at B and not at A? You had previously mentioned isolating A since it was the nosiest part, and I'm wondering how that plays into this setup.
If this looks good I will look at how those C/D nodes could be moved.
Yeah, the layout isn't really representative of the space of things in this chassis, which is pretty tight... are you talking about the control grid wires from pins 5/1 that go to the coupling caps? Looking at what is currently wired in this amp they are probably 5 - 6" long. The plates are connected to the OT on pin 3, right?
Ok, seems like that's what you are saying here... if I moved D to the other side of that PI/V2B group and rotated the components...
Would it make sense, layout wise, just speaking positionally on the board, to go V2B stuff -> Node C ->V2A stuff -> Node D -> right side of the board as is?
« Reply #33 on: August 23, 2024, 03:08:35 pm »
Grounds are now wired right.  :icon_biggrin:
Reply #16;
See Merlin's drawings. Go back and read what Merlin says about it.
The long orange and red wires from the PI coupling caps to the 1k5 grid stopper R.
Yes. Look at Merlins drawing of a small preamp tube and it's filter caps grounding.
Look at how Doug puts a big filter cap on a eyelet/turret board. I like using the small radial e caps for this.
« Last Edit: August 23, 2024, 03:15:54 pm by Willabe »
Offline BobL
« Reply #34 on: August 23, 2024, 06:13:20 pm »
Ok... how do we feel about something like this?
I have some radial caps, but they are all 50v, and I'm also not sure what benefit they would have on this particular board... seems like using the caps I have would work fine?
« Reply #35 on: August 23, 2024, 06:47:34 pm »
Yes that's it.  :icon_biggrin:
Now save that, and see if you can play around with moving the C node over too.
Look at some of Dougs layouts, he hangs the filter cap off the back of the board, it's another option.
« Last Edit: August 23, 2024, 06:49:40 pm by Willabe »
Offline BobL
« Reply #36 on: August 23, 2024, 09:49:53 pm »
Yes that's it.
Ok... I'm a little less confident about this one in two spots:
1. The grounding around the - lead of C... I think I have it functionally equivalent now?
2. The leads from the + lead of C to the board... do I need to daisy chain like this, or should I have two leads directly from the + node to the two spots on the board C feeds, or is this the right way?
3. confirming that the V1B K ground is correct to go to the power amp ground and not the preamp ground? I know you had said to do that, but I'm not totally clear on why, as that is fed by D, yeah?
Offline SEL49
« Reply #37 on: August 23, 2024, 10:20:58 pm »
Node C was never used in the original PR. Hoffman followed the original schematic and didn't use it either. The only thing node C does is provide a lot more filtering (ripple reduction) for node D. With that in mind maybe just follow the original design but ground the node C cap with the node D cap since you have that option. Remember, the original used a 4-pole cap can and did not have the option of separate grounds. Fender sold thousands and thousands of successful clones have been built using that original circuit.
« Reply #38 on: August 24, 2024, 11:04:03 am »
1. is right, 2. is right.
3. is wrong.
The ground wire in the #1 green box connected to the 1K R going to the #3 green box move the 1K R end to the preamp buss, leave the #3 green box connection alone. So #3 green box eyelet V1b 1K5 K R and 25uF/25v bypass cap are now connected to the preamp buss. Next disconnect the D node filter caps ground lead from the preamp buss and move it to the #3 green box eyelet with the V1b 1K5 K R and 25uF/25v bypass cap. Should now be D node filter cap ground lead, V1b 1K5 K R and 25uF/25v bypass cap all 3 in #3 green box eyelet going over to the preamp buss.
Now disconnect the C node filter cap - lead from the PI 1K R, gray wire in the layout drawing.
V2b pin 8 K wire move from the .1 uF filter cap over to the PI 1K R. This will shorten that wire a little.
Last thing, I know I said to turn the PI 90 degrees counter clockwise, but;
Since you have moved both c/d filter caps you now have moved the PI over towards the power tubes enough to put the PI caps/R's back like they were. The grid wires will be shorter now. And the orange and red wires will be about the same length.
« Last Edit: August 24, 2024, 11:25:01 am by Willabe »
« Reply #39 on: August 24, 2024, 11:33:12 am »
And fix your V2b pin 6 wire in your layout, it got bumped a little.  :laugh:
Offline BobL
« Reply #40 on: August 24, 2024, 05:48:42 pm »
I think this is what you described - I also had a number of V2 leads that needed to be lined up better...
I guess the C/D filtering difference here vs. the stock princeton is a setup... I don't want to change the character of the circuit too much, so that'd be something to consider... if I did use D for everything ala the original circuit, I think I'd need to fix that preamp ground coming off of the V1B K wire to go to the preamp bus as you described above for this one?
I have build the stock princeton reverb circuit before, and definitely one of my favorites. Hrmm.
« Reply #41 on: August 24, 2024, 06:53:15 pm »
Looks good.
Except, flip/flop the orange and red power tube grid wires at the top ends of the .1uF coupling caps, they got moved. That way the 2 grid wires will be about the same length (and the -FB should be correct). And when you run them over to the power tube sockets, tightly twist them together for noise cancellation.
But I forgot a ground. Sorry.
Ground the junction of the -FB 47 ohm tail R, it's labeled NFB Tail, and the 56K R, labeled PI Tail load, to the C node filter cap - lead eyelet.
« Last Edit: August 24, 2024, 07:06:00 pm by Willabe »
« Reply #42 on: August 24, 2024, 07:03:23 pm »
I wouldn't put both 12AX7's on the D node cap and nothing on the C node cap.
If you have a small choke from the old build, use it instead of the 1k8/2w B+ dropping R.
And, shorten that last B+ dropping R by moving it to the left side of the last 39K/2w dropping R and the 100K V2a plate load R.
It's buggin me. :icon_biggrin:
« Last Edit: August 24, 2024, 07:07:04 pm by Willabe »
Offline BobL
« Reply #43 on: August 24, 2024, 07:58:48 pm »
Like so?
I do not have an extra choke.  I guess I could run the node C/D wires to the board on top of the board and if I want to try running everything off of D after hearing it they'd be easier to get to... but curious how this will sound.
« Reply #44 on: August 24, 2024, 09:10:17 pm »
C node ground is good now.
Orange/red wires are good.
Sorry I meant to say shorten that last B+ dcv feed wire. Put that 39K B+ dropping R back in between node B and node C like it was.
Now take out the wire that goes from the PI 56K plate load R to the V2a plate load 100K R. Now run a wire from the V2a 100K plate load R eyelet over to the left side of the last 39K/2w dropping R eyelet that's directly below the .02uF/630v coupling cap.
« Last Edit: August 24, 2024, 09:12:50 pm by Willabe »
Offline BobL
« Reply #45 on: August 24, 2024, 09:41:43 pm »
Oh, you mean this... that makes more sense... this was sorta what I was asking yesterday - I wasn't sure if that was ok or not...
« Reply #46 on: August 24, 2024, 09:44:18 pm »
Yes!     :happy1:
That's it.    :bravo1:
Offline BobL
« Reply #47 on: August 24, 2024, 09:49:25 pm »
Guess I should build it, eh?
Again, all the guidance has been very much appreciated, and it has been an interesting process. Thanks you!
I have a lot of tear down to do before I can actually start putting this together. Slightly daunting... solder sucker is gonna earn its keep.
Offline AlNewman
« Reply #48 on: August 24, 2024, 10:38:26 pm »
The grounding looks really good.
Before building, you could also remove most of the components that say reverb in front of them.  It's making my OCD go off, and I'm not OCD.
If space is an issue you can also place a lot of the tone stack components across the pots, instead of on the board.
Offline BobL
« Reply #49 on: August 25, 2024, 01:14:07 am »
I think I'm ok on space.
I don't think I want to remove those things as the design replicates the existence of those aspects of the original design so that the overall character of the amp feels more like an amp w/ the trem/reverb... but turned off...
