September 08, 2026, 04:40:24 pm
Hoffman Amps Forum image Author Topic: Questions about Sluckey's 1960 Vox AC-15  (Read 5144 times)
Offline Stymie
« on: August 25, 2024, 04:20:00 pm »
I have just completed my build of SLuckey’s 1960 Vox AC-15.  I included 4 of the 5 modifications he also has with his documentation.  They are: More Brilliance, Delta Tremolo/Vibrato, Standby Plus, and Channel Select Switch (the last mod).
I made the following changes for my amp:
I used the Hammond 1750Y output transformer to match my Celestin Blue 15W speaker
I replaced the Vibrato/Tremolo toggle switch with a jack and foot switch.
I installed two 1 ohm 10W resistors connected to pin 3 of V7 and pin 3 of V8 to the R60 and C39.
My first issue is the Channel Select Switch makes a loud pop when I change channels.  I am not sure how to solve this issue.
My second issue is with the channel 2.  The tremolo is very faint.  Is there any way to increase the tremolo volume?
I have not been able to determine what the original foot switch and the Vibrato/Tremolo switch change.  When I turn them “On”, grounding them there is almost no noticeable difference in the sound.  What do these two switches do?
My last issue is that I would like to install a red LED in the oscillating circuit similar to the Warbler, but am not sure where to place it and any components I would need to add or delete.
Thank you for any assistance.
Re: Questions about Sluckey's 1960 Vox AC-15
« Reply #1 on: August 25, 2024, 04:58:14 pm »
the RED LED would replace R59 n C38 on the schematic i'm looking at.
roll a bunch of tubes through the trem circuit, you need a strong tube
« Reply #2 on: August 25, 2024, 06:44:06 pm »
Is sluckey's web site still up?
Anybody have the link to it?
Offline Stymie
« Reply #3 on: August 25, 2024, 09:03:35 pm »
Thanks Shooter for the LED solution.  I will try some other tubes I have for the tremolo circuit.
Here is slucky's web site:  https://www.sluckeyamps.com/index.htm
Hopefully someone will have a solution to the channel select switch popping issue.
