September 08, 2026, 04:39:50 pm
Hoffman Amps Forum image Author Topic: Question: Hoffman 1 & 2 Channel AB763 bus voltage design  (Read 7368 times)
Offline RoadShow
  • Disturbing the Peace Since 1955
« on: August 26, 2024, 12:32:34 pm »
Hi,
So, while digging in researching a design question I have, I came up with a different question regarding the Hoffman 1 & 2 Channel AB763 bus voltage design.
I've included 3 screen shots below:
One is a screen shot where the bus system on the 2 channel design has the trans followed by the B+ voltage followed by 2 10k power resistors to develop the C and D bus voltages.  The agrees with the layout for the other Fender AB763 designs by Fender, Sluckey's Deluxe Reverb and Mojotone's Deluxe Reverb.
One is a screen shot where the bus system on the 1 channel design has the trans followed by the B+ voltage followed by a 1k power resistors to develop the C bus voltage and a 4.7k power resistor that develops the D bus voltage.
I also have a table that shows voltages in the system from the relative schematics (??? where there was no documented voltage), and while there is variance, they are in the same ballpark/general range except the Hoffman 1 channel is much higher on the C and D bus voltages.
So, my question is, why the lower resistor values on the 1 channel design with higher voltages on the C & D buses?
I built the Hoffman 1 channel a year ago and have been using it trouble free so far, but now I'm curious.
Thanks.
Re: Question: Hoffman 1 & 2 Channel AB763 bus voltage design
« Reply #1 on: August 26, 2024, 12:48:08 pm »
Doug might have wrote why in the amps write.
Read them.
« Reply #2 on: August 26, 2024, 12:58:28 pm »
Probably because Fender did that from whatever schematic I used at the time.
There are many AB763 amps and not all are the same
Look at these schematics , these are all AB763 amps
Deluxe reverb, Vibrolux reverb, Bandmaster reverb, Pro reverb, Super reverb, Twin reverb and Dual Showman Reverb
Offline RoadShow
« Reply #3 on: August 26, 2024, 01:15:36 pm »
Read them.
I did, nothing there.
Offline RoadShow
« Reply #4 on: August 26, 2024, 01:17:10 pm »
Gotcha, that explains it then.  Just thought that both of those would be the same.
Fender even flipped the 1k & 4.7k on some...
Offline stratomaster
  • Don't guess, measure.
« Reply #5 on: August 26, 2024, 02:39:15 pm »
The hot swapped rectifier/standby could be improved.
« Reply #6 on: August 26, 2024, 07:08:28 pm »
I can't think of any AB763 models that hot switch their valve rectifier.
« Reply #7 on: August 27, 2024, 06:22:00 am »
It all depends on which AB763 you are building
Go to the library here and look at some of the models I mentioned above and see what each one uses in those positions.
A deluxe Reverb is different than a Twin Reverb and so on
A Deluxe Reverb has two 10k's
A Super Reverb has a 1k and a 4.7k
Here's our Schematics library for Fender amps
https://el34world.com/charts/Schematics/files/Fender/Fender_Schematics.htm
« Last Edit: August 27, 2024, 09:16:04 am by EL34 »
