September 08, 2026, 04:41:05 pm
Hoffman Amps Forum image Author Topic: Impact 60 rev trem hum issue  (Read 6568 times)
Offline Leevi
    • Rikstone
« on: August 27, 2024, 07:17:00 am »
I have a hum issue with Impact 60 reverb tremolo. The preamp stages are identical if tremolo and reverb are disconnected from the circuit. I get a pretty loud hum (close to 50Hz) from the second channel even if tremolo and reverb are disconnected. If I remove the channel 2 preamp tube the hum drops to an acceptable level and channel 1 works fine. I cannot believe it is not a filtering issue since the voltage supply is common for both channels and channel 1 works alone fine. The hum does not increase with volume. Of course I have tried with several tubes and measured voltages which are ok.
/Leevi
Re: Impact 60 rev trem hum issue
« Reply #1 on: August 27, 2024, 08:00:12 am »
with NOTHING plugged in?
I would check the input shorting jacks n the grounds in that area
Offline Leevi
    • Rikstone
« Reply #2 on: August 27, 2024, 09:30:32 am »
It hums nothing plugged in and on zero volume.
I recently changed the tube socked, no progress.
/Leevi
« Last Edit: August 27, 2024, 10:00:36 am by Leevi »
Offline Latole
« Reply #3 on: August 27, 2024, 03:02:23 pm »
Any mods in the amp ?
Can you post pictures of wiring ?
Connect both positive input jacks  to ground ; hum or not ?
« Last Edit: August 27, 2024, 03:05:20 pm by Latole »
« Reply #4 on: August 27, 2024, 04:12:04 pm »
Buzz/humm with nothing plugged in;
Offline Leevi
    • Rikstone
« Reply #5 on: August 27, 2024, 11:31:36 pm »
The grounds are ok there.
Have attached a picture which is quite difficult to follow.
The most of the filter caps are located under the tag board.
There some small mods.
/Leevi
Offline Leevi
    • Rikstone
« Reply #6 on: August 28, 2024, 12:13:43 am »
I solved it with a workaround.
The noise comes from the reverb recovery and I wired the reverb pot in another way by swapping the wiper and lug 3.That reduces the noise if the reverb is not fully open.
I also biased the amp cooler which reduced the noise.
/Leevi
Offline Latole
« Reply #7 on: August 28, 2024, 03:00:14 am »
/Leevi
Power tubes matched help to reduce noise.
Match don't need to be 100 % same.
15mfd bias filter, if bad, will induce hum. I'll put a 25 mfd
« Last Edit: August 28, 2024, 03:03:23 am by Latole »
