September 08, 2026, 04:40:39 pm
Hoffman Amps Forum image Author Topic: Can anyone ID this tube?  (Read 12364 times)
Offline pbman1953
« on: September 08, 2024, 09:20:15 am »
Can anyone tell from the marking/font what brand this could be?
Re: Can anyone ID this tube?
« Reply #1 on: September 08, 2024, 07:16:53 pm »
The label is meaningless, nearly always.
I assume there is no diamond mark between the pins?  If not, then the flat-plate construction reveals this is an Ei tube.
Offline pbman1953
« Reply #2 on: September 09, 2024, 06:11:43 am »
There is a mark between the pins but hard to make out. I took a picture of it and after zooming in could be a diamond
« Reply #3 on: September 09, 2024, 07:41:53 am »
If there is a small diamond between the pins then it's a Telefunken. Oh sorry I see HBP already elicited this in the link he provided.
Is that a dab of RTV between the pins?
« Last Edit: September 09, 2024, 07:45:52 am by mresistor »
Offline pbman1953
« Reply #4 on: September 09, 2024, 07:57:40 am »
Rtv?
« Reply #5 on: September 09, 2024, 08:37:59 am »
Silicon Sealant, comes in a tube usually. What exactly is this substance on the bottom of the tube between the pins?  It ain't normal, does this tube have a crack in the glass at the base?
« Last Edit: September 09, 2024, 09:33:32 am by mresistor »
Offline pbman1953
« Reply #6 on: September 09, 2024, 09:30:28 am »
That's true there was
Offline pbman1953
« Reply #7 on: September 09, 2024, 03:45:38 pm »
Good eye, no crack,  this came out of a tube pre-amp and the tech used the sealant on the tube stabilize it
« Reply #8 on: September 09, 2024, 03:48:03 pm »
Thanks for the reply   I did finally think that maybe it was for some purpose like that..   cheers.
« Reply #9 on: September 09, 2024, 05:10:43 pm »
There is a mark between the pins but hard to make out. ...
99% chance it's an Ei tube.
Try looking at the getter ring instead, where the vertical post attaches.  There's an obvious tell there that will definitely say whether this tube is a
Telefunken:
   - If the getter is not a complete ring, but dips inward where the post attaches, that's a Telefunken.
   - If it doesn't dip inward (and remains a complete circle), then it's an Ei tube.
Offline pbman1953
« Reply #10 on: September 09, 2024, 05:24:26 pm »
Telefunken:
« Reply #11 on: September 09, 2024, 07:16:40 pm »
That is an Ei ECC83.  Flat plate (which makes people think "Telefunken"), but no inward dip at the getter mounting post.
« Last Edit: September 10, 2024, 04:03:52 pm by HotBluePlates »
Offline pbman1953
« Reply #12 on: September 09, 2024, 07:34:20 pm »
Thanks! Still good tube, right?
« Reply #13 on: September 10, 2024, 04:04:31 pm »
Still a 12AX7, yes.
And Ei was at least some part of the Philips family of companies in Europe.
Offline pbman1953
« Reply #14 on: September 10, 2024, 05:22:23 pm »
If it were you. would you say the EI or a long plate RCA would sound better?
Offline acheld
« Reply #15 on: September 11, 2024, 10:13:48 am »
It's ALWAYS in the ears of the listener.
As for me, I can't tell the difference between good (meaning "normally functioning") tubes of one brand vs another.
I've had more, but very intermittent, problems with microphony from long plate ECC83  tubes than the others; and various brands seem to be more reliable in my hands, but this is only my very biased opinion, based on scarce personal data.  I admit that I like Telefunken tubes based on the name alone.
Once upon a time, I tried to listen to as many tubes in this comparator https://www.tubedepot.com/pages/tube-comparison-tool as I could.  I really couldn't tell any differences.   But I am old.   You certainly may hear differences!   That's why it is dealer's choice!
« Reply #16 on: September 11, 2024, 10:33:32 am »
They say that Telefunken tubes were some of the finest vacuum tubes ever made. They say they last forever because of the build quality, the materials and the vacuum.
« Last Edit: September 11, 2024, 01:59:34 pm by Willabe »
Offline pbman1953
« Reply #17 on: September 11, 2024, 01:44:33 pm »
Thanks for the link! I swapped back and forth and the Ei won. The Ei was similar to the RCA in mid and high end but the lows were tighter and not as blossomy.   Can't say blossom is bad but for what I do t sounded better
« Last Edit: September 12, 2024, 07:03:00 am by pbman1953 »
Offline bmccowan
  • Better builder than player
« Reply #18 on: September 12, 2024, 06:59:41 am »
Those "They" folks are really smart. And I'm wondering, did Telefunken use up all that special vacuum or is it available somewhere? Very funny Willabe! :laugh:
Mac
John Prine
« Reply #19 on: September 12, 2024, 11:07:13 am »
What the hell is going on here?
You got a problem with me?
Offline bmccowan
« Reply #20 on: September 12, 2024, 11:47:30 am »
Being funny is never a problem. Is it?
Cheers
Mac
John Prine
« Reply #21 on: September 12, 2024, 12:03:45 pm »
Really?
Your not being funny, your takin a poke at me, being a smart ass and you know it.
What's the real problem?
Offline bmccowan
« Reply #22 on: September 12, 2024, 12:37:35 pm »
There is no problem.
I thought you were being funny - maybe I was mistaken? I always think the "they" pronoun is funny. So I thought you were poking fun at some Telefunken (they) promo claims. ("last forever") forever is a long time. No?
Definitely no poke at you - just the opposite - as humor helps keep us out of drudgery.
Again, cheers!
Mac
John Prine
« Reply #23 on: September 12, 2024, 12:41:15 pm »
I hope this is true because I always thought you were a good guy and enjoy your input here.
I'm truly sorry if I got this wrong. Forgive me.
Offline bmccowan
« Reply #24 on: September 12, 2024, 01:03:50 pm »
Willabe, It is absolutely 100% true. I am an extremely honest person. I am one of those Scots that believes that honor is the most important virtue we can hold.
I am also a person who tends to see humor all around us. I often hear, "why are you laughing?" So no worries - no foul, as they say. (see what I mean?)
I have great respect for you and the other moderators here and strive to contribute productively, along with the occasional attempts to make people smile.
Regards
Mac
John Prine
« Reply #25 on: September 12, 2024, 01:06:39 pm »
Ok, good. Sorry again, my mistake.
