September 08, 2026, 04:41:00 pm
Hoffman Amps Forum image Author Topic: AA1164 Startup Problems  (Read 4926 times)
Offline sclinchy
« on: September 10, 2024, 01:40:23 pm »
I just went through my previously functioning Hoffman AA1164, resoldering, replacing some wiring, etc.  I’ve started it up with just the rectifier tube installed, and I’m getting voltage readings that don't make sense to me. I’m hoping to get some insight into where I might have gone wrong.
This is what I’m seeing:
Capacitors [/t]
[/t]
Y
440
[/t]
X
470
[/t]
U
475
[/t]
O
470
Rectifier[/t]
[/t][/color]
2
[/t][/color]
4,6
[/color]V5, V6[/t]
[/t][/color]
3
467
[/t][/color]
8
0
[/color]V1[/t]
[/t][/color]
1
465
[/t][/color]
3
0
[/t][/color]
6
465
[/t][/color]
8
0.02
[/color]V2[/t]
[/t][/color]
1,6
476
[/t][/color]
3,8
0
[/color]V3[/t]
[/t][/color]
1
467
[/t][/color]
3
467
Thanks for any and all help!
Offline Dave
Re: AA1164 Startup Problems
« Reply #1 on: September 10, 2024, 01:55:40 pm »
At a glance, it looks like it's just because there is no load.
I don't know what all the X's and O's equate to, but you've got similar voltages all down the chain. Seems normal to me. When you start loading them down with tubes, they will seperate.
Dave
« Reply #2 on: September 10, 2024, 04:10:02 pm »
As Dave said, nothing is visibly wrong.  You will need to install tubes to have some current drawn from the power supply, which will also drop voltages (and make cathode voltage rise due to voltage-drop across cathode resistors).
If you're concern there's a wiring fault waiting to burn something up, consider making & using a "lightbulb limiter."
