September 08, 2026, 04:41:11 pm
Hoffman Amps Forum image Author Topic: Wiring mutiple taps different jacks  (Read 6334 times)
Offline Ariel tube fanatic
« on: September 15, 2024, 04:56:25 pm »
Hello,
I have an ab763 clone with a multi tap ot, 2,4,8 i would like to wire.
I will not use the 2 ohm tap, i can just heat shrink it right ? And not connect to anything? And how so i go about the other jacks?
Connect each tap to a shorting jack (switch to gnd and tip is the tap?)
Thanks to anyone that would help
Re: Wiring mutiple taps different jacks
« Reply #1 on: September 15, 2024, 05:05:11 pm »
Hello,
Depends on which type of AB763 amp, and which type of OT
« Reply #2 on: September 15, 2024, 05:11:15 pm »
Its a mojotone kit
Attached layout,
This ia the OT
« Reply #3 on: September 15, 2024, 05:25:58 pm »
Yes, just heat shrink the unused tap.
No, you can not use any shorting jacks.
« Reply #4 on: September 16, 2024, 01:12:33 am »
sorry link wasn't attached for a reason
this is the OT
https://www.mojotone.com/Blackface-Bassman-Super-Reverb-Vibroverb-Output-Transformer
the reason i can't use shorting jacks is because if i short one tap to gnd it basically shorts the entire secondary ? and if i use the aux as a 4 ohm tap i will get lower volume because the 8 ohm is grounded via the shorting jack?
thanks everyone, it's running in my head but i can't reach the answer fully, your replies help
Offline Latole
« Reply #5 on: September 16, 2024, 07:01:47 am »
You need to use only one ohms output.
Leave other not connected.
Look any Marshall amp with few OT output, you'll understand
« Reply #6 on: September 16, 2024, 09:12:18 am »
the reason i can't use shorting jacks is because if i short one tap to gnd it basically shorts the entire secondary?
Correct.
....and if i use the aux as a 4 ohm tap i will get lower volume because the 8 ohm is grounded via the shorting jack?
No.
It will short the entire secondary.
« Reply #7 on: September 17, 2024, 02:35:49 pm »
If it’s an amp head, you could wire the switch lug of a tip-switch jack to a chunky wire-wound dummy load resistor (to ground) - for dummies who forget to plug a speaker in. (I.e. This would be for the main speaker tap)
« Last Edit: September 17, 2024, 02:41:20 pm by tubeswell »
