September 08, 2026, 04:40:34 pm
Hoffman Amps Forum image Author Topic: voltage divider between treble and master?  (Read 6485 times)
Offline joesatch
  • save me from myself.
« on: September 23, 2024, 09:44:38 am »
trying to understand what this voltage divider accomplishes also the way the tonestack is wired. never seen this
Offline Dave
Re: voltage divider between treble and master?
« Reply #1 on: September 23, 2024, 10:08:11 am »
To me, it looks like it's not part of the tone stack. It's just squeezing off a little signal. I would presume that the signal was a little too hot going into the next stage. It may also serve to knock down a little bit of high end content (maybe the tone was a little too bright?)
Dave
Offline Merlin
« Reply #2 on: September 23, 2024, 10:18:45 am »
The tone stack is a passive James/Baxandall. The two extra resistors just attenuate more signal. Apparently somebody couldn't handle the gain. Wimps. B-)
« Last Edit: September 23, 2024, 10:20:52 am by Merlin »
Offline Latole
« Reply #3 on: September 23, 2024, 03:29:01 pm »
Dave
Right
Offline joesatch
« Reply #4 on: September 24, 2024, 09:09:28 am »
what if i remove the 1M to ground? no longer a voltage divider so what would the 499K in series do?
Offline Merlin
« Reply #5 on: September 24, 2024, 09:20:50 am »
It still forms a divider with the volume pot, but the attenuation will be less.
« Reply #6 on: September 24, 2024, 05:22:36 pm »
what if i remove the 1M to ground? ...
Original circuit is electrically, "A Variable Resistor you can only turn up halfway."
When you remove that 1MΩ resistor you now have, "A Variable Resistor you can turn up two-thirds of the way."
