September 08, 2026, 04:42:18 pm
Hoffman Amps Forum image Author Topic: Gretsch (Valco) 6165 Amp "Pop" sound  (Read 11811 times)
Offline wsscott
« on: October 06, 2024, 07:49:19 am »
I got this amp new back around 1965, and it hasn't been played much over the years.  The only work done to it was to replace one of the filter caps and one of the 6L6 tubes.  So it's in great shape, I think.
The issue is that I've noticed for several years is that after I turn it on, and even if its in Standby Mode (which I think is just a muted speaker connection and not a Standby like Fender--am I correct about this), after several minutes of warming up it will occasionally make a loud Pop sound.  Scares me every time it happens.  It doesn't do it every time it's turned on and so it's not predictable.
It might do this once or twice over a couple hours of being turned on.
Any ideas on what it could be?  I'm attaching the schematics for the Preamp and Power amp sections.  Thanks.
Re: Gretsch (Valco) 6165 Amp "Pop" sound
« Reply #1 on: October 06, 2024, 08:30:48 am »
from within the amp, or at the speaker?
a "popping" sound is typically a sudden discharge, think of a cap holding a "charge" then momentarily "shorts"
a switch with "stored up" potential on one side closes and an "inrush" happens.
a sketchy tube socket, plug/jack, solder connection, builds up a potential then "arcs over", builds up, arcs over.....
Offline wsscott
« Reply #2 on: October 06, 2024, 08:34:19 am »
It comes through the speaker.
« Reply #3 on: October 06, 2024, 10:31:46 am »
I'd start with a spit-n-polish on the 2 connectors from the pre-section, and the tube pins n sockets
Offline wsscott
« Reply #4 on: October 06, 2024, 12:00:15 pm »
Cleaning just the Output tube pins and sockets, or all of them?
Am I correct that when this amp is in Standby, nothing from the Preamp section would be getting to the Speakers to make the Pop sound, so the noise must be coming from the Power Amp section?
« Reply #5 on: October 06, 2024, 12:52:01 pm »
the jury is still deliberating on that one  :icon_biggrin:
It appears the standby switch grounds ONLY one power tubes grid, so my sense is there is a sneaky Pete way for a PoP to get through.
my logic thinks if that "grounded" connection is gritty, tarnished n varnished, in standby a "potential" could build up on the grounded grid then "arc over", thus Popping.
Offline Platefire
« Reply #6 on: October 06, 2024, 04:21:55 pm »
Hay wsscott
I got a 6164(Gretsch Variety) new in 1965. Was my first good quality amp. Wish I had kept mine! :sad2: If you got a picture of it, post it if you don't mind
On the right track now<><
Offline ALBATROS1234
« Reply #7 on: October 06, 2024, 10:58:39 pm »
Valco's of that era are known for cheap tube sockets which cause weird problems. Definitely clean, and retension all of those too although my first thought would be a cap going bad in the power supply.
Offline wsscott
« Reply #8 on: October 07, 2024, 07:31:31 am »
Platefire-Mine is the Variety Plus--35 Watts--2 12" Jensen speakers.
The amp is with a buddy being used in a recording session, but I'll take some pics when I get it back and post them.
Offline wsscott
« Reply #9 on: October 07, 2024, 08:15:59 am »
Shooter-I see what you mean about the Standby switch only grounding one of the grids.
But why would they do that?
Could it be that the GND connecting the Pin 7 grid between the 12K and 470K resistors may be the culprit, and that's how its getting through?
« Reply #10 on: October 07, 2024, 08:53:26 am »
Could it be
there were 2 types of Field Engineer during my 32 years, those educated in Military Electronics and those from 4yr Colleges
while we from military ed were busy checking the "known to cause problems" areas, the College kids were drinking coffee asking
 "could it be......."   :icon_biggrin:
when you have a unknown, intermittent problem, you do as I mentioned above, if the problem should still poke it's head up in the future, you'll have a "list" of things already "taken care of"
Offline SEL49
« Reply #11 on: October 07, 2024, 09:22:28 am »
This is a paraphase inverter. That simple SPST standby switch directly kills the signal sent to one of the power tubes. It also kills the signal sent to the grid of the lower half of the phase inverter and this removes the signal sent to the other power tube. Think "kills two birds with one stone."
« Reply #12 on: October 07, 2024, 11:03:17 am »
... after I turn it on ... after several minutes of warming up it will occasionally make a loud Pop sound.  ...
See the Servicing Fender Amplifiers page that Doug put in the Library of Information.  Specifically the "Jacks, Pots and Tube Sockets" section, as well as the "Oddball Amp Noises" section.  The point of these is that there are some routine maintenance items one can do that resolve most noise issues in old amps.
For a first-pass, don't even try to localize & isolate the noise-source, just clean & re-tension everything.  Most of the time, you will kill the problem (and there could be multiple individual "problems") just because everything got touched.
If you still have the popping noise afterward, report back & we can attempt to isolate the noise-source.
Separately, your amp's schematic is in the Gretsch section of the Tube Amps Schematic library.
Whenever possible, try to create a link to the schematic, rather than adding it as an attachment.  That saves server space, and makes it easy for folks to view the document.
Offline wsscott
« Reply #13 on: October 07, 2024, 11:14:22 am »
Thanks for the leads, and also info about posting.
Offline Platefire
« Reply #14 on: October 07, 2024, 03:06:27 pm »
wsscott
Here is an old ad that outlines the difference between the Variety and Variety Plus. For some reason there is not many regular Varieties around, most of Variety Pluses.
« Last Edit: October 07, 2024, 03:09:40 pm by Platefire »
Offline wsscott
« Reply #15 on: October 07, 2024, 03:56:51 pm »
Yes, I've actually got the full sales brochure that shows the various models.
Offline Platefire
« Reply #16 on: October 10, 2024, 09:18:55 pm »
Would love to here the "Rest Of the Story" on outcome of the "Pop" of from where it came from and where its gone?
Offline wsscott
« Reply #17 on: October 10, 2024, 09:30:20 pm »
Will do.  I just don’t have my amp now.  A buddy has it for some recording sessions.  So it will probably be a few weeks before I can get back to it.  He says it’s been fine and no pops, so it will be a challenge, most likely.
Offline wsscott
« Reply #18 on: October 11, 2024, 01:18:43 pm »
I had my buddy take some pictures.
Offline wsscott
« Reply #19 on: October 11, 2024, 01:20:18 pm »
Here's the last photo.
Offline Platefire
« Reply #20 on: October 11, 2024, 02:16:23 pm »
Thanks! Looks like She's in very good shape. You were wise to hold on to it. Attached is the only picture I have of mine taken with my Kalamazoo Electric Guitar (Gibson's Fender Mustang copy). If I remember correctly, think I traded mine in on a Silverface Deluxe reverb
« Last Edit: October 11, 2024, 02:20:47 pm by Platefire »
Offline wsscott
« Reply #21 on: October 12, 2024, 02:51:10 pm »
A question about discharging the reservoir and filter caps in this amp and other tube amps with rectifier tubes.
Can you properly discharge the caps by unplugging the amp, removing the rectifier tube, and then grounding the cathode Pins 2 or 8 using a normal capacitor discharge tool connected to ground?
In a Fender you'd leave the Standby switch in the "play" position, but in this amp it wouldn't matter since the filter caps aren't isolated.
« Reply #22 on: October 12, 2024, 04:09:42 pm »
I would go pin 2 to chassis
« Reply #23 on: October 12, 2024, 06:07:22 pm »
You can use a gator clip cable on a preamp tube plate R.
Hook 1 clip to ground and the other to the tube socket side of the plate R.
Always do a quick dcv check after you think you've discharged the filter caps. Just to confirm you did drain them fully.
« Reply #24 on: October 12, 2024, 06:11:27 pm »
Does this discharge tool have a resistor in series, so the caps don't discharge instantly?
Offline wsscott
« Reply #25 on: October 13, 2024, 07:56:22 am »
Yes, it’s a snuffer stick.  I also use a 22k, 3 W, resistor in a banana plug adapter that I plug into my DMM and then plug the probes into that, so I can discharge and read the voltage at the same time-a D-LAB trick.
