September 08, 2026, 04:41:36 pm
Hoffman Amps Forum image Author Topic: How would this boost work???  (Read 7870 times)
Offline rake
« on: October 15, 2024, 08:48:08 pm »
I always thought losing a cathode bypass cap would negatively effect the signal.
This is from the Bedrock Royale Reverb schematic. (Second gain stage)
Solid state has no soul........
Offline stratomaster
  • Don't guess, measure.
Re: How would this boost work???
« Reply #1 on: October 15, 2024, 09:11:42 pm »
That will work as a boost.  I prefer to short across a higher value resistor (33k-100k, 1/4w) instead of just closing the switch. Less of a pop that way.
« Reply #2 on: October 16, 2024, 12:35:31 am »
More readable
Offline Merlin
« Reply #3 on: October 16, 2024, 05:45:44 am »
Losing the bypass cap causes a gain reduction. Therefore adding the cap back causes a gain boost.
Offline SEL49
« Reply #4 on: October 16, 2024, 07:03:35 am »
You can also make the gain adjustable.
https://sluckeyamps.com/smoky/smoky.pdf
Offline rake
« Reply #5 on: October 16, 2024, 08:16:38 am »
So, "normal operation" would be with the boost switch open and boost is when the switch is closed?
Offline Merlin
« Reply #6 on: October 16, 2024, 08:28:35 am »
Yes
Offline rake
« Reply #7 on: October 16, 2024, 12:49:14 pm »
Thanks Merlin. For some reason my brain was in bass ackwards mode and couldn't see it the other way around! LOL!  :BangHead: :dontknow: :l2:
« Reply #8 on: October 16, 2024, 01:12:19 pm »
seem to recall it also "narrows" bandwidth, lower frequencies "fall off" ?
« Reply #9 on: October 16, 2024, 01:20:50 pm »
Losing the bypass cap causes a gain reduction. ...
Not really, because there's no frequency-dependent element to the local negative feedback.
Adding a "small" cap would boost gain for highs, while adding a "big" cap would boost gain for lower frequencies, too.
Offline acheld
« Reply #10 on: October 16, 2024, 09:51:56 pm »
Go to https://ampbooks.com/mobile/amplifier-calculators/cathode-capacitor/calculator/ and you can easily see how size affects frequency response and signal strength.
