September 18, 2026, 06:24:51 pm
Hoffman Amps Forum image Author Topic: Champ build questions  (Read 6806 times)
Offline walteralter
« on: October 23, 2024, 01:22:07 pm »
Hello everyone,
new to this forum. Thinking about building a second amp (built Robs Blackvibe 2 years ago).
Option 1) Basically a Champ circuit with reverb. To get higher voltages for the AT7 reverb driver I was thinking using a GZ34 and adding an additional filter stage (see attached schematic).
Option 2) Champ circuit but with 1 6BM8 Tube Reverb (see schematic). My question now is what to do with the 2nd half of the Preamp 3 12AX7, could a Princeton style cathodyne phase inverter work in this circuit and is it advisable?
Any input would be appreciatedd, thanks!
Re: Champ build questions
« Reply #1 on: October 23, 2024, 01:34:31 pm »
I'd go with the 12AT7 for the verb. Run it in || (parallel) like a Fender.
Use a 40uF/500v for the 1st A node B+ filter stage.
You can't use a PI with a SE (single ended) power amp. Push/pull (PP) power amps use a PI.
« Last Edit: October 23, 2024, 01:39:22 pm by Willabe »
Offline walteralter
« Reply #3 on: October 23, 2024, 03:40:47 pm »
thanks, found the uraltone site 2 days ago - option 1 is based off of their schematic
« Reply #4 on: October 23, 2024, 04:28:47 pm »
I'll not use a vacuum tube rectifier, in an SE amp it didn't give advantages (the disadvantage is you have a higher B+ if you don't change the TA)
Offline labb
« Reply #5 on: October 23, 2024, 06:55:22 pm »
There are some really good reverb pedals.
Offline walteralter
« Reply #6 on: October 24, 2024, 05:19:06 am »
nothing comes even remotely close to a real tube driven spring reverb.
Got a UA Golden Reverberator after all the hype and didnt like it.
Offline Lectroid
« Reply #7 on: November 01, 2024, 10:27:42 am »
@walteralter,
You can build a one-tube reverb with a 12DW7. It's a low-µ triode plus a high-µ triode.  I've done it and it produces pretty good reverb.  Not quite up to surf music like the old Fenders, but otherwise it's completely acceptable.  It's a more feathery, jazzy reverb rather than the sharper, "clattery" reverb sound like a Fender design.
If you haven't already, check the Archives sub-board for "one-tube reverb."
If you have a triode left over, maybe add in a switchable gain stage?
Magis bos clocca!
Free Beer Tomorrow!
