September 18, 2026, 12:59:36 am
Hoffman Amps Forum image Author Topic: Old Moviola SE 6v6 Squawk Box Conversion  (Read 5626 times)
Offline marczee
« on: November 07, 2024, 11:19:55 am »
Just joined! I have a grip of old reel to reel conversions and this Magnasync Moviola 1800 tube amp that I occasionally get off the shelf to tinker with. It's a hobby I guess..  The 1800 could be considered the big brother of the URS squawk box amp. It was installed inside the green Moviola film editing machines. For this one I tried to remove all of the extra optical head / film related stuff. For audio, it's a beast. Very high gain, hissy, barely need to turn it up. I modded the input resistance to V1 to "like a Fender".  I made note of the voltages after pulling out all of the film junk, those are taken with a 6.3v filament dialed in on the variac.
I would like to tame the circuit more. I lifted the V1 cathode bypass cap and it didn't change much. So just looking for some pointers here. Thanks!
Re: Old Moviola SE 6v6 Squawk Box Conversion
« Reply #1 on: November 07, 2024, 11:40:34 am »
for "simple" testing;
remove C3 and C2, re-wire R10 as a volume pot
does it move you in the correct direction?
AND....
do a re-draw!!  those X's n O's get me all distracted   :icon_biggrin:
Offline AlNewman
« Reply #2 on: November 07, 2024, 09:52:44 pm »
Yes, draw an updated as built schematic.
It looks like you're making extra gain in the 1st 2 stages, possibly more than the power amp was designed for.
Offline danhei
« Reply #3 on: November 08, 2024, 06:22:27 am »
Yeah, tons of gain without really any attenuation between stages. Aside from shooter’s good tips, if you’ve got a second 12AU7 sub that in for the 12AX7. That should take things down considerably.
« Reply #4 on: November 08, 2024, 07:01:51 am »
i was trying to sneak up on that  :icon_biggrin:
« Reply #5 on: November 08, 2024, 07:35:02 am »
You got caught.   :laugh:
Offline marczee
« Reply #6 on: November 09, 2024, 06:58:24 pm »
Thanks all, I'll try Shooter's suggestions! I just remembered I have some 5751 tubes as well to try. Definitely will be re-drawing this schemo in the near future.
