June 13, 2026, 03:32:36 am
Hoffman Amps Forum image Author Topic: Feedback help  (Read 11548 times)
Offline seriesnuns
Feedback help
« on: November 12, 2024, 08:12:18 pm »
I swapped a couple tone caps in my Allen brown sugar. Since then 5-20 minutes after the amp is warm I get a high pitched feedback, reverb that is bypassing the reverb pot, volume that is bypassing the volume pot. I have made it stop by touching the v2 pin 7 in like resistors and also testing the B+ power.
I’ve pulled measures and cleaned all eyelets multiple times now. I’m starting to work my way out and replace wires because i can’t figure this out.
I was able to catch it on video tonight.
Offline AlNewman
Re: Feedback help
« Reply #1 on: November 12, 2024, 08:22:47 pm »
Share an original schematic, and all the changes you made.
Offline seriesnuns
Re: Feedback help
« Reply #2 on: November 12, 2024, 08:27:18 pm »
Swapped the 3 caps highlighted in yellow.
https://imgur.com/gallery/7Aubc15
I’ve tripled checked all the connections around the area for continuity. They all line up. De soldered and re soldered about 3 times now.
« Last Edit: November 12, 2024, 08:29:24 pm by seriesnuns »
Offline AlNewman
Re: Feedback help
« Reply #3 on: November 12, 2024, 08:46:36 pm »
That's a layout, not a schematic.
If all your connections line up, that's great.
Nobody knows what you did or are trying to do.
What about the layout made you decide to change it?
Offline seriesnuns
Re: Feedback help
« Reply #4 on: November 13, 2024, 04:51:28 am »
Here is the schematic.
https://imgur.com/gallery/sUHqo6N
I didn’t change any signal flow or values. Just swapped orange drops for Jupiter and sozo in the tone section.
Offline Latole
Re: Feedback help
« Reply #5 on: November 13, 2024, 04:59:22 am »
Thank's
Offline Latole
Re: Feedback help
« Reply #6 on: November 13, 2024, 05:13:14 am »
As built  ?
Offline Latole
Re: Feedback help
« Reply #7 on: November 13, 2024, 05:18:56 am »
You'd probably have moved some wires.
 The layout of the wire  is often important. The wires should run along the frame and cross each other at 90 degrees as much as possible, and never be parallel to each other.
Offline Merlin
Re: Feedback help
« Reply #8 on: November 13, 2024, 05:24:30 am »
Six triodes all running from one 22uF power supply cap is... concerning...
EDIT: My bad, it's only four.
« Last Edit: November 13, 2024, 10:57:41 am by Merlin »
Offline seriesnuns
Re: Feedback help
« Reply #9 on: November 13, 2024, 05:52:35 am »
That is a current picture. I’m keep double my wiring..
It’s interesting the issue isn’t present for the firm 5-10 minutes then flares up. I can get it to calm down by interrupting the b+ flow or downstream of v1 pin 6
Re: Feedback help
« Reply #10 on: November 13, 2024, 06:38:52 am »
What is the black wire with the white tape on the end by the reverb jacks?
It looks cut?
Offline Latole
Re: Feedback help
« Reply #11 on: November 13, 2024, 06:40:29 am »
It looks cut?
Yes it is cut !
Re: Feedback help
« Reply #12 on: November 13, 2024, 06:40:42 am »
The blue wire that goes to the sozo cap, move it away from the yellow/white twisted pair.
Offline Latole
Re: Feedback help
« Reply #13 on: November 13, 2024, 06:43:25 am »
Many wires need a better routing
Offline seriesnuns
Re: Feedback help
« Reply #14 on: November 13, 2024, 06:45:25 am »
The black wire with tape is ground from the raw pot. In case I wanted that foot switchable.
Re: Feedback help
« Reply #15 on: November 13, 2024, 06:45:30 am »
And move that white wire going to the Jupiter cap away from the wire going to the R to the left of it.
It looks like the wires to those 2 caps, Jupiter and sozo, you moved them when installing those caps. Play with chop sticking them around a little.
Re: Feedback help
« Reply #16 on: November 13, 2024, 06:48:51 am »
Not enough information.  :dontknow:      :BangHead:
Did the amp come like that?
Did you put that wire in? I don't see an open jack for it on the back of the chassis.
Offline seriesnuns
Re: Feedback help
« Reply #17 on: November 13, 2024, 07:01:05 am »
Will do.
I put it in as an option. There is an rca jack that has reverb defeat. I also had it as a raw defeat for a bit to see which one I needed more.
Offline SEL49
Re: Feedback help
« Reply #18 on: November 13, 2024, 08:29:41 am »
Connect this wire to ground. Any better?
Offline seriesnuns
Re: Feedback help
« Reply #19 on: November 13, 2024, 09:06:50 am »
Sorry that black wire is tied to the left lug of the raw pot. When you ground it it grounds the raw pot out.
https://imgur.com/gallery/HpntEgr
Offline SEL49
Re: Feedback help
« Reply #20 on: November 13, 2024, 09:41:44 am »
That was the point. Does the feedback go away if you ground that wire?
Offline stratomaster
  • Don't guess, measure.
Re: Feedback help
« Reply #21 on: November 13, 2024, 09:56:45 am »
I think your description is off about that wire in question. It is wired to the "left lug" of the MID pot, not the Raw pot.  Grounding that would short to ground across the raw pot. It's bad practice to have long unterminated leads in an amp, so just remove the wire if it's not in use.  Defeating the Raw pot is exactly the same as just turning the Raw pot down to minimum.
After you've removed that wire test if the problem still arises with the Raw pot rolled all the way down.  If you still have the problem, and it isn't related to lead dress you may have moved during your cap swap, try disconnecting the wire at pin 3 of V3.  This is the wire that spans across the socket.  Leave the first connection intact then try your test again.  Report what happens.
Re: Feedback help
« Reply #22 on: November 13, 2024, 10:53:48 am »
I only see 4 plates fed off the last filter cap on the schematic.
Re: Feedback help
« Reply #23 on: November 13, 2024, 11:13:42 am »
Yes, it can act like an antenna and pick up anything in the air that's around it.
So you put that black wire in at the same time you changed the caps? Was it hooked up to the reverb RCA jack to ground out the raw pot? Or did you never hook it up to the RCA jack?
I'm asking because I want to know if the amp started acting up when you installed that black wire and it was not hooked up to the RCA jack so it is just floating in the amp.
He probably wanted to use it as a boost with the foot switch.
Offline seriesnuns
Re: Feedback help
« Reply #24 on: November 13, 2024, 11:17:51 am »
You are correct. I originally had it as a boost but disconnected and opted for the reverb.
Does anyone think if I burnt the silver mica 500pf could cause my issues?
Re: Feedback help
« Reply #25 on: November 13, 2024, 11:22:21 am »
But when did the amp start acting up?
After you disconnected that black wire?
Re: Feedback help
« Reply #26 on: November 13, 2024, 11:29:05 am »
Since your not going to use that raw boost, snip that wire out, snip it at the mid pot.
Maybe, but the leads look fairly long. Always use a heat sink when soldering up silver mica caps and get in and out quickly.
Snip that black wire out 1st, if that doesn't fix it, then play with those 2 cap wires I talked about. If still no help, then maybe go ahead a change that SM cap.
Re: Feedback help
« Reply #27 on: November 13, 2024, 11:43:52 am »
Did you mess with the bright switch SM cap?
If so, why?
I can't see it very well, but that bright switch SM cap looks like it's wired up wrong.
In reply 26, I was looking at the TS treble SM cap. That's what I thought you were asking about. Now I'm thinking you meant the bright switch SM cap.
« Last Edit: November 13, 2024, 11:46:02 am by Willabe »
Offline seriesnuns
Re: Feedback help
« Reply #28 on: November 13, 2024, 12:26:44 pm »
If so, why?
No the 500pf silver mica with the 0.02 Jupiter yellow
Re: Feedback help
« Reply #29 on: November 13, 2024, 12:53:55 pm »
We need more information.
Did you change all 3 TS caps at the same time you added that black wire for the raw control to ground it out with a foot switch?
Or did you just change the 3 TS caps by them selves?
« Last Edit: November 13, 2024, 12:58:41 pm by Willabe »
Offline seriesnuns
Re: Feedback help
« Reply #30 on: November 13, 2024, 01:06:06 pm »
Sorry for the lack of background.
Yes the 3 caps I highlighted in yellow were swapped at the same time. 0.02 .1 and. 0.05
The black wire has been around for a while. If you look close I shrink wrapped the tip and the white tape is just a label.
Re: Feedback help
« Reply #31 on: November 13, 2024, 01:18:03 pm »
Ok, when did you disconnect the raw pot's foot switch wire from the reverb jack?
Did you disconnect it at the same time when you changed the 3 TS caps?
Offline seriesnuns
Re: Feedback help
« Reply #32 on: November 13, 2024, 02:25:25 pm »
2 months ago
No the caps were disconnected or swapped out this past weekend.
Re: Feedback help
« Reply #33 on: November 13, 2024, 03:10:58 pm »
2 months ago
And the problem started after you changed the 3 TS caps?
Offline seriesnuns
Re: Feedback help
« Reply #34 on: November 13, 2024, 03:36:02 pm »
Correct
Re: Feedback help
« Reply #35 on: November 13, 2024, 04:00:30 pm »
Yes, I read that but there was no mention of the raw pot mod.
I just want to get it cleared up.
Offline seriesnuns
Re: Feedback help
« Reply #36 on: November 13, 2024, 04:02:09 pm »
I think I got it.
Found the ground lug on the raw pot was loose inside the bundle of grounds.
Moved to a better spot and soldered on. Removed the black wire for good sakes.
Re: Feedback help
« Reply #37 on: November 13, 2024, 04:02:51 pm »
Why the amp still has sound when you turn down the volume pot on the amp all the way doesn't make sense.
Seems like you miss wired something.
Did you do any other mods?
Re: Feedback help
« Reply #38 on: November 13, 2024, 04:08:44 pm »
The only path to go past the amps volume control is the bright switch cap.
Do you keep that bright switch on all the time?
Edit; I see in the video clip the bright switch is off.
« Last Edit: November 13, 2024, 04:12:01 pm by Willabe »
Re: Feedback help
« Reply #39 on: November 13, 2024, 04:09:38 pm »
Good.   :icon_biggrin:
Offline seriesnuns
Re: Feedback help
« Reply #40 on: November 13, 2024, 04:15:10 pm »
Amp has no mods. Wired per kit layout and schematic.
David does say the raw pot boosts and raises mids..
Re: Feedback help
« Reply #41 on: November 13, 2024, 04:21:25 pm »
This amp was a kit? Did you build it?
Yes, that's what a raw control does, it takes out the mid scoop.
Offline seriesnuns
Re: Feedback help
« Reply #42 on: November 13, 2024, 04:25:01 pm »
Yes I did build it. My third amp to date. I’m hooked. I am thankful for these forums along the way.
Hopefully this post will help someone in the future with the same issue
