September 08, 2026, 05:40:39 pm
Hoffman Amps Forum image Author Topic: Bridge rectifier output voltages for 6.3v relay power supply  (Read 5234 times)
Offline Randy Lahey
« on: November 29, 2024, 12:15:35 pm »
Forgive me if this has been asked many times in the past - I did a quick search but couldn't find a solution.
I am installing Hoffman's relay switching circuit in an amp and I am only measuring +3vdc and -3vdc on either output of the bridge rectifier which is fed 6.3vAC from a dedicated 6.3v transformer.
I understand I should see 9vdc at the output - why the low voltage? It's obviously not enough to actuate the relay.  I have measured and confirmed the correct orientation for all components on the relay switching power supply board.
I should also mention that the 6.3vac filament supply has a virtual centre tap with 150R resistors.  I have also not grounded the relay power supply board.
Any suggestions?
« Last Edit: November 29, 2024, 12:20:27 pm by Randy Lahey »
Offline SEL49
Re: Bridge rectifier output voltages for 6.3v relay power supply
« Reply #1 on: November 29, 2024, 12:22:52 pm »
The output is taken BETWEEN the negative and positive terminals of the bridge so that would give you about 6V pulsed DCV. Add a filter cap between the negative and positive terminals to increase the voltage to about 9VDC.
« Reply #2 on: November 29, 2024, 12:41:54 pm »
Lots of relay information in this thread, Relay circuit & layout board & ft. switch;
https://el34world.com/Forum/index.php?topic=14348.0
It's found in Archives of favorite topics, 2nd in the list;
https://el34world.com/Forum/index.php?board=11.0
Offline SEL49
« Reply #3 on: November 29, 2024, 12:51:12 pm »
Since this is a dedicated transformer that is not being used for tube heaters, you don't need a center tap. So remove the 150Ω resistors and just connect the bridge negative terminal to chassis ground.
Offline acheld
« Reply #4 on: November 29, 2024, 04:05:29 pm »
I highly recommend Doug's little relay power supply board.  Small, inexpensive, works great.
Voltage also depends on the voltage regulator you're using, right?
https://hoffmanamps.com/MyStore/perlshop.cgi?action=template&thispage=Lamps&ORDER_ID=559940839#google_vignette
Offline rake
« Reply #5 on: November 29, 2024, 10:01:41 pm »
+1! It's also neat, clean & all the bugs have been worked out of it already. Simply feed it the heater supply and it's ready to go!
Offline Merlin
« Reply #6 on: November 30, 2024, 11:03:24 am »
This guy asked exactly the same question four years ago. May be helpful to you:
https://ampgarage.com/forum/viewtopic.php?t=33226
