August 30, 2026, 09:57:54 am
Hoffman Amps Forum image Author Topic: Can any one ID these old vintage pots?  (Read 6287 times)
Offline pbman1953
« on: December 16, 2024, 10:07:47 am »
HI All.
I have 3 vintage pots that may have come out of some old guitars or amps-
23-6504     / 23-5943-   1965 era- 4th week- 500k
304-6923   /23-6504-  1969 , 23rd week-  no value mentioned
304-6914     /23-1598-  1969, 14th week-  no value mentioned
Besides the 500k can anyone ID the others?
Also, would you know if they have any value? For the ones with no value shown, would you know what they were used in?
Thanks!
Offline AlNewman
Re: Can any one ID these old vintage pots?
« Reply #1 on: December 16, 2024, 05:40:19 pm »
Well, you can measure the values across outside legs to find resistance, and also test resistance through the sweep to find out if they are audio or linear, etc.
If they are long shaft, or short shaft, smooth or knurled, may help determine what application they were used in.
Long story short, they're probably worth nothing more than a good replacement in the spare parts bin.
Offline bmccowan
  • Better builder than player
« Reply #2 on: December 16, 2024, 10:16:00 pm »
Mac
John Prine
Offline uki
  • Hot Tube Hot Sound
    • Uki's Guitar Trip
« Reply #3 on: December 17, 2024, 07:04:58 am »
hi-rez pics are very useful to help in those cases
https://soundcloud.com/ukiuki
Offline pbman1953
« Reply #4 on: December 17, 2024, 08:02:52 am »
Here you go
Offline Latole
« Reply #5 on: December 17, 2024, 09:47:26 am »
Value in $$$ ?
« Last Edit: December 17, 2024, 09:50:49 am by Latole »
Offline SEL49
« Reply #6 on: December 17, 2024, 10:00:47 am »
304 = Stackpole
Offline acheld
« Reply #7 on: December 17, 2024, 10:02:49 am »
Would Jay Codie's EIA code spreadsheet help?
https://el34world.com/Forum/index.php?topic=27470.0
Offline pbman1953
« Reply #8 on: December 17, 2024, 11:21:55 am »
Value in $$$ ?
2@ 500k
1-  25k
« Reply #9 on: December 21, 2024, 02:05:07 pm »
The first line is "mixing metaphors" and therefore makes a mistake.
   - The 2nd grouping of codes correctly derives the date of manufacture from the numbers beginning with "304" which is the EIA code for Stackpole.
   - The 2nd grouping of numbers also includes numbers beginning with "23-____" that appear to be some kind of part-number.
   - So the first line of numbers with "23-6504" cannot mean "4th week of 1965" as the other pots show this is a part-number of some kind.
   - Your photo of this pot shows the EIA/date code is over near the solder lugs, and is partly-obscured.  But "___6943" is visible to indicate 43rd week of 1969.
Folks have gathered together several published lists of EIA codes.  This one from 1962 shows there is no manufacturer with the EIA code "23" or "25" and so offers further proof these were part-numbers on your pots.
... would you know what they were used in?
Only the person who removed them from equipment could answer that question.
