August 30, 2026, 09:56:56 am
Hoffman Amps Forum image Author Topic: Solid State Amp/Troubleshooting Resource  (Read 5004 times)
Offline jukelemon
  • It's always in the fingers
« on: December 18, 2024, 12:21:54 pm »
Hi all!
I don't see much SS posts here so I was hoping if someone knows a good amp forum for these types of questions etc.
I am working on a Crate BT350 that has several things wrong with it and i am using it as a practice amp if you will on learning :)
Right now I have 2 blown low voltage secondary fuses, a preamp that is not getting any of the higher voltage DC to run the tube preamp, and a completely dead preamp board in general (which makes sense of course given no low voltage supply)
So ideally...looking for the Hoffman Forum of SS amps :)
Thank you!
Offline mmrxcsr01
Re: Solid State Amp/Troubleshooting Resource
« Reply #1 on: December 18, 2024, 12:31:31 pm »
Juke, there's a solid state section on the "other things" section of this forum- maybe someone will move your post there....
Offline jukelemon
Re: Solid State Amp/Troubleshooting Resource (please delete)
« Reply #2 on: December 18, 2024, 12:39:41 pm »
Ah..thank you!  I was not aware lol.  Never been on it :)
Mod: please delete this post and sorry for the churn.
« Last Edit: December 18, 2024, 12:45:38 pm by jukelemon »
« Reply #3 on: December 18, 2024, 12:53:34 pm »
No, we can leave it here and guys will see it. If they think they can help with the SS amp, they can go over to that section.
Offline Latole
« Reply #4 on: December 19, 2024, 03:13:08 am »
1- Disconnect preamp from power supply. ; Voltages / fuses ok or not ?
2- Fuse blow : Check the 4 rectifier diodes ( d15 to D19), filter caps
3- Voltage / fuse ok , check preamp board for short - circuit.
     Start by unplugging all tubes
« Last Edit: December 19, 2024, 03:15:47 am by Latole »
