September 09, 2026, 12:16:43 am
Hoffman Amps Forum image Author Topic: JMI Vox AC10 add-on top boost?  (Read 7028 times)
Offline fazeka
  • When in doubt, crank it!
« on: January 09, 2025, 11:28:15 am »
Hi there,
I am planning out a Vox JMI AC10 build/clone. The normal channel is known for being somewhat whimpy. Had a chance to play an original one recently that was just serviced and I would agree with that sentiment.
So I got to thinking about adding top boost to it, if that would be possible?
Based on some high level research, seems I can add it in a similar location as in the AC30 (red arrow):
JMI schematic:
Thomas schematic:
Top boost schematic, for reference:
What do y'all think?
Re: JMI Vox AC10 add-on top boost?
« Reply #1 on: January 09, 2025, 11:49:23 am »
Why an AC10?
Why not single channel AC15 or 1/2 of a single channel AC30?
Offline fazeka
« Reply #2 on: January 09, 2025, 12:12:03 pm »
Why an AC10?
Because I'm planning an AC10 build. Been there/done that with both an AC30 TB I've owned and a AC15 I've built.
Not that it matters, but here's a pic of my AC15 build:
Offline bmccowan
  • Better builder than player
« Reply #3 on: January 09, 2025, 10:35:58 pm »
Nice AC-15! I'm wondering if this Mojo Schematic offers some ideas. I have not built it as is, but used parts of the circuit in a 6973 build.
Mac
John Prine
« Reply #4 on: January 10, 2025, 04:35:16 am »
Yes, sure a TB section can be fitted in there.
Personally I find Vox designs somewhat half boiled, in how one channel has the trem, another has TB etc.
If it was me, I'd mix the channels then feed them into the TB section.
The unused LTP input cap would then need to be grounded.
Offline fazeka
« Reply #5 on: January 10, 2025, 11:18:56 am »
Hi Pete,
If I'm understanding you here, you would have the two channels both go into the TB?
To be clear, I actually like the EF86 channel as-is. Even the ECF82 normal channel has a place on my sonic palette. I was hoping to top boost just the normal channel but also have it switchable for stock normal channel tones. Best of both worlds (?). DPDT switch in between the normal volume wiper and 0.01 (C12 on the Thomas schematic)?
« Reply #6 on: January 10, 2025, 12:46:27 pm »
Hi Pete,
Yes, that's just my preference, if you want to keep the stock circuit then my idea's no use to you.
Offline fazeka
« Reply #7 on: January 10, 2025, 01:00:03 pm »
Hi Pete, yes OK, understand.
Any problem you see adding in a DPDT to switch the TB circuit in/out of the Normal Channel (see red arrows in schems above)?
« Reply #8 on: January 10, 2025, 01:10:32 pm »
The main issue I foresee is getting the layout and lead dress such that the darn thing keeps stable.
Removing the cathode bypass from the TB's pin3 can help with that. It drops the maximum available gain a tad but the TB adds plenty anyway, so no real downside.
Offline fazeka
« Reply #9 on: January 10, 2025, 02:00:46 pm »
Understand! I am not married to TB but it would be nice to have it switchable so if I build it and it's unstable, I still have a great (IMO) sounding normal channel.
Help me out with this as I've never unbypassed a cathode... :icon_biggrin: ...would bypassing mean eliminating only the cap or eliminating both the cap and the resistor?
Otherwise, thank you Pete. Very helpful advice!
« Reply #10 on: January 10, 2025, 02:45:55 pm »
Yes, only leaving out the cap. The tube stills needs a cathode (K) R to bias properly.
And it's a 'bypass' cap, so what's it bypassing? If you leave the K R out, there's nothing to bypass.
Offline fazeka
« Reply #11 on: January 10, 2025, 02:48:11 pm »
Gotcha, thanks for the explanation.
Offline fazeka
« Reply #12 on: January 11, 2025, 03:36:34 pm »
Leaving this here for future reference (thanks to sluckey):
