September 08, 2026, 05:45:38 pm
Hoffman Amps Forum image Author Topic: Building a JMI Vox AC30/6  (Read 25612 times)
Re: Building a JMI Vox AC30/6
« Reply #50 on: January 28, 2025, 05:00:41 am »
Are the EL84 control grids lug 2 definitely very close to 0V DC?
Individual cathode bias resistors with each require their own bypass cap. eg 220R // 47uF.
Another option to enable monitoring of each EL84, whilst retaining the shared bias response, is to insert 1R cathode current sensing resistors between each lug 3 and the 50R // 220uF cathode bias.
Unfortunately the rough handling of shipping can bugger up valves, they may have matched fine at the vendor's facility.
« Reply #51 on: January 28, 2025, 05:02:30 am »
your old numbers for example;
31.3VDC / 50 ohms = .626 divided by 4 (tubes) = 160mA per tube!!
you had about 400VDC plate so 400 * .16 = 64WATTS from a 14W tube, boom, send in the new quads!!!
Just to note that when the cathode voltage measured 31V, the 50R cathode resistor was actually open circuit, so current was 0mA.
« Reply #52 on: January 28, 2025, 07:29:58 am »
so I can maybe alligator clip a 100 ohm resistor,
That's what I do, "roll resistors" till I find the closest. and YES, all the voltages change, NORMAL.  GET the bias to 10-14W a tube
Don't worry about G2's current, it's about 5% of the math you're doing, since your 100+% off it's just wasting time n cooking tubes
« Reply #53 on: January 28, 2025, 08:17:40 am »
That's what I told him to do, use the 1 ohm on each tube before the 50R/220uF.
You really want to do that so you know for sure what each tube is drawing by itself.
« Reply #54 on: January 28, 2025, 08:42:46 am »
agree, but he simply needs to get it to the point where tubes ain't frying, the amp works as designed....Then maybe mod it properly.
Offline four_corners
« Reply #55 on: January 28, 2025, 09:25:39 pm »
Woohoo! We have a non-burning up AC30!
After swapping tube placement and V6 still smoking, i started looking right there, and there was a cold solder on the jumper between pin 1 and 2 (*facepalm*).
PDF64 mentioned I should check the mains transformer HT winding resistance, which was 52ohms and he said it should be at least 120ohms. I had two 10W 15ohm resistors, so I put them in series between the rectifier output and the reservoir HT cap (C39) and it cooled things down a bit.
So new EL84 numbers:
Cathode - 10.05 VDC
Plate - 331 VDC
Screen - 320 VDC
______________
Only thing left is to figure out what the heck is going on with V7 (Vibrato preamp and gain).
heaters are fine, but getting wacky voltages for everything else:
pin 1:  22 mV DC (changes +/- 30mV with the Vib Speed knob, I put a push/pull pot instead of rotary)
pin 3:  31 mV DC
pin 6:  about the same as pin 1
pin 7:  -670 mV DC
pin 8:  1.3 mV DC
These are the expected voltages:
pin 1: 140 VDC
pin 3: 1.2 VDC
pin 6: 200 VDC
pin 8: 18 VDC
I tried swapping tubes, and it wasn't the tube.
« Last Edit: January 28, 2025, 09:49:28 pm by four_corners »
« Reply #56 on: January 28, 2025, 10:48:35 pm »
One thing to add, I realized I had put the 30ohms of resistance between the rectifier output and the reservoir cap before finding the error I had made on V6, so I decided to quickly desolder it, and just put the direct wire back to see the voltage without the added resistors, and this is what I got...
WITHOUT 30ohm:
Cathode - 10.3 VDC
Plate - 339 VDC
Screen - 327 VDC
WITH 30ohm:
Cathode - 10.05 VDC
Plate - 331 VDC
Screen - 320 VDC
Maybe this is splitting hairs, but which seems more "ideal" for a classic AC30 with the 47ohm cathode resistor?
« Reply #57 on: January 29, 2025, 04:43:55 am »
"ideal"
as a Tech, anything less than MAX dissipation
as a Guitarist, anything that get's the girl
 :icon_biggrin:
« Reply #58 on: January 29, 2025, 09:06:05 am »
"ideal"
 :icon_biggrin:
:smiley: I trust your expertise as both a tech AND rockstar :smiley:
Now to just track down this Vib/Trem pre/gain stage voltage issue...
Tube is glowing and heater AC voltage is correct, and it is not the tube as I've swapped tubes in V7. I went through and reflowed all (I think) the component around that area.
My plate and cathode voltages are basically non-existant. Plate voltages (1 and 6) will modulate +/- but in the low mV's, and the cathode pins are both way too low.
I'll just start working backwards from V7 pins 1,3,6,8  I guess? Cathode resistor and cap, plate resistors, etc. Would be cool to know more than just the correct voltages directly at the valve, but I guess all I really need to know is where the voltage is "coming from" and try to find a big voltage drop/s.
Hoping to have a fully functional Vox AC30/6 by the end of the day! My first ever amp build. Thanks for all the help everyone, and humoring my dumb questions!
Offline SEL49
« Reply #59 on: January 29, 2025, 10:23:56 am »
You have no plate voltage on V7. That explains why none of the V7 voltages are good. So, you gotta find out why the plate voltage is missing. I suspect a missing wire.
First, check the voltage on V9 pins 1 and 6. What have you? This will provide a good clue about the missing voltages on V7. Once you provide the voltages for V9 it should become easy to find the cause for the missing voltage on V7.
« Reply #60 on: January 29, 2025, 10:36:20 am »
Okay cool, I'll go from V7's plate. All the other tubes seem to have the correct voltages, including V9.
Offline SEL49
« Reply #61 on: January 29, 2025, 10:57:37 am »
Check the wire I've indicated in the pic. You can also check for zero resistance from the bottom of R39 to the bottom of R60. I suspect a missing or broken wire.
Offline SEL49
« Reply #62 on: January 29, 2025, 10:58:49 am »
BTW, hi rez pics of your build would be verrrry helpful.
« Reply #63 on: January 29, 2025, 11:49:43 am »
Well... you were spot on! I did not have that wire from R39 to R60, as I remember someone somewhere saying it wasn't needed (maybe it was for a different build, or a mod of some sort), and then I found another layout that also disregarded that wire. Wouldn't be surprised if the first person said it wasn't needed because they referenced that same layout!
I can officially say all tubes are performing as they should be! Now time to fully test this bad boy!
« Reply #64 on: January 29, 2025, 06:34:17 pm »
A quick video for everyone who helped! And a couple photos of the head.
https://streamable.com/n2abc7
« Reply #65 on: January 31, 2025, 10:25:36 am »
It sounds and looks amazing, you should be proud of yourself, well done!
