September 08, 2026, 07:29:54 pm
Hoffman Amps Forum image Author Topic: Ab763 build with original drri pt  (Read 8416 times)
Offline a_e_a
« on: January 29, 2025, 09:47:16 pm »
Hey guys,
Just getting a bit lost figuring out the wires for the drri in my 2 channel ab763 build. In Australia so we are 240v here.
I did try a search and couldn't find the info. If this has been asked often I'd be happy to be directed to another thread or get some advice.
I've added a pic which shows the ptand the excess of wires.
Cheers.
AA
Offline SEL49
Re: Ab763 build with original drri pt
« Reply #1 on: January 29, 2025, 10:00:22 pm »
Offline Latole
« Reply #2 on: January 30, 2025, 03:32:32 am »
Offline Latole
« Reply #3 on: January 30, 2025, 03:35:25 am »
Home built AB763 ; where this power transformer comme from ?
Offline a_e_a
« Reply #4 on: January 30, 2025, 05:06:49 am »
Thanks for the replies. I well give them a look and see how I go.
Sorry for the confusion, it's not a scratch build. It's a drri conversion with the hoffman 2 channel ab763 board. So the transformers are being utilised for the time being.
It's a big learning curve and a bit of a departure from previous straightforward builds I've done.
Offline Latole
« Reply #5 on: January 30, 2025, 05:26:10 am »
Look here ; many hoffman and other  transformers.
And show schematic and all information about this Hoffman 2 channel ab763
https://el34world.com/schematics.htm#Transformer%20wiring%20diagrams
Offline glass54
« Reply #6 on: January 30, 2025, 06:07:58 am »
Hi a_e_a
Successfully did this with Doug's board.
See attached photos
Made one change, removed C31+C32, used 47u 500V F+T Electro, more reliable  :laugh:
Regards
Mirek
"To measure is to know"
Offline Latole
« Reply #7 on: January 30, 2025, 06:32:00 am »
C31 in series with C32 =  1/2 capacitance
2 X 47 mfd = 23.5 mfds . IMO it is very small, why not two 100 mfds ?
Offline SEL49
« Reply #8 on: January 30, 2025, 07:17:03 am »
No. C31 is 220µF and C32 is 47µF. Put those two caps in series and the total capacitance is 39µF. You must use the reciprocal of the sum of reciprocals formula to solve for total capacitance when caps are not equal values.
Notice the two balance resistors are not equal value either. Seems illogical to me. Who can say what the Fender engineers were thinking. Maybe they were shooting for 32µF as found in the original AB763 and were working with common cap values that they had on hand. Could be a bean counter decision.
Offline Latole
« Reply #9 on: January 30, 2025, 07:23:30 am »
I'm talking about what Glass54 do ;
To  replace C31, C32 by 2 X. 47 mfd
Offline SEL49
« Reply #10 on: January 30, 2025, 07:28:39 am »
Your link ;
Not the same wires colors
Are you sure? What looks different to you?
Offline Latole
« Reply #11 on: January 30, 2025, 07:32:08 am »
Your link ;
Where is the violet wire I see on the transformer primary picture
« Reply #12 on: January 30, 2025, 07:36:02 am »
Where is the violet wire I see on the transformer primary picture.
It's on the top side of the picture.
« Reply #13 on: January 30, 2025, 07:39:37 am »
The Fender schematic shows 396dcv at the 1st B+ filter cap. And the amp uses a slow warm up rectifier tube, 5AR4/GZ34.
I think glass54 used just 1 ecap at 47uF/500v. His hi-lited scemo says "Fit 47uF 500v." Doesn't say Fit 2 x 47uF 500v.  Should work.
« Last Edit: January 30, 2025, 07:59:34 am by Willabe »
Offline SEL49
« Reply #14 on: January 30, 2025, 07:40:49 am »
I clearly see a violet wire on the top side of the PT. The only primary wire I can't positively identify is the BLK/RED, but I bet it's there. Need a different camera angle or perhaps a_e_a will verify the colors match the schematic.
Offline SEL49
« Reply #15 on: January 30, 2025, 09:31:39 am »
Wire that DRRI PT for 240V mains like this. Connect the BLK/GRN and BLK/YEL wires together. Connect the VIO and BLK wires to the mains circuit. Tape off the three unused primary wires, ie, BLK/RED, WHT, and WHT/BLK).
Offline glass54
« Reply #16 on: January 30, 2025, 04:32:02 pm »
Thanks Willabe. See attached photo of final Dogbox. 500V was sufficient. and replaced the second Electro as well (47u 500V F+T)
..and Sel49: Fender's DRRI PS with 220uF and 47u in series seemed to be a common point of failure here in Aussie.
so better solution was the 47u 500V F+T
I also built a Single channel "DR style" with custom toroidal Tx and SS Bridge into C1with 100uF 500V (Gives a fairly stiff PS but not everyone's cup of tea) I used Doug's Turret Board for that project. (Fantastic result Doug  :laugh:)
Kind Regards
Mirek
Offline a_e_a
« Reply #17 on: January 31, 2025, 05:49:17 pm »
Violet and blk/red are there.
Thanks for all the info guys. It's so handy to have such knowledgeable people here. I'll keep you updated with how it goes.
I had also replaced c31 and 32 with a 47uf before I gutted it. I was going to run the caps inside rather than use the doghouse this time.
Here is a pic
Offline stratomaster
  • Don't guess, measure.
« Reply #18 on: February 08, 2025, 09:25:45 pm »
Be sure to keep the two pole filtering on the bias supply (you can just add a 100v 8-22μF cap to the wiper and shell of the pot, with correct polarity) with these PTs.  For some reason, the 100μF filter cap isn't enough with these.
Offline glass54
« Reply #19 on: February 08, 2025, 10:51:21 pm »
As Strato said.
Best performance is with a 2 stage RC Filter, Not recommended to go too big with C values.
See attached Sluckey's schematic (typical 6V6 application).
Adj R38 and R42 to suit application ie AC supply voltage and DC Bias range  :laugh:
If you're keen, you can read more http://www.valvewizard.co.uk/bias.html This explores failsafe Bias mod in case the trimpot goes open circuit
Kind regards
Mirek
« Last Edit: February 08, 2025, 11:00:20 pm by glass54 »
Offline a_e_a
« Reply #20 on: February 09, 2025, 03:47:15 am »
Thanks guys. All worked well. Hooked it all up now and the only problem I have is the reverb not working. Couldn't expect to have everything work right straight up though. haha. So the project continues...
Thanks again for all the help guys!
« Last Edit: February 09, 2025, 04:30:34 am by a_e_a »
Offline a_e_a
« Reply #21 on: February 09, 2025, 05:42:03 am »
Just to inform you all, I’m an idiot. I left the foam in the new reverb tank when I installed it, hence the no reverb. That could’ve been a lengthy exercise if I hadn’t checked everything!
Offline a_e_a
« Reply #22 on: February 10, 2025, 03:14:39 am »
Some photos. Happy for some feedback. It sounds pretty spiky and bright. Figure there is something going on somewhere. Gonna have to run through the circuit again to check it all.
Offline a_e_a
« Reply #23 on: February 10, 2025, 03:15:23 am »
More
Offline a_e_a
« Reply #24 on: February 10, 2025, 03:16:00 am »
And more.
« Reply #25 on: February 10, 2025, 09:49:04 am »
Offline SEL49
« Reply #26 on: February 10, 2025, 09:50:25 am »
You forgot to connect the feedback wire from the speaker jack to the 820Ω on the board.
EDIT...added pic
« Last Edit: February 10, 2025, 11:07:21 pm by SEL49 »
Offline a_e_a
« Reply #27 on: February 11, 2025, 12:25:17 am »
Thanks!
I did go through the layout but the output jacks are on another page so I missed it. You just saved me hours of going through the layout before checking the other docs.
