September 08, 2026, 05:45:48 pm
Hoffman Amps Forum image Author Topic: 6N5P Russian made  (Read 4842 times)
Offline Cliff Rogers
6N5P Russian made
« on: February 28, 2025, 06:56:28 pm »
Anybody tried using these in a preamp?
Low gain, approximately 27, twin triode.
Should be similar to a 12AU7 with different heater pin out requirements and the current draw is also higher.
https://frank.pocnet.net/sheets/113/6/6N5P.pdf
Re: 6N5P Russian made
« Reply #1 on: March 01, 2025, 02:00:45 pm »
When I want a comparision between russian and USA/EU tubes I go to https://tubes-store.com
They sell russian tubes and refer to the correspondent USA/EU tubes
but about your tube, the 6N5P no comparision is made and so I suppose that that tube hasn't a correspondent
https://tubes-store.com/product_info.php?products_id=674
Other seller say there is correspondece with some USA/EU tubes but seems odd to me that at tubes-store they ignore that (???)
https://soviet-tubes.com/product/russian-6n5p-double-triode-tube-with-separate-indirectly-heated-cathodes-low-frequency-preamplifier-near-analogue-6au7-7au7-ecc804-b729-6ga8/?srsltid=AfmBOooOOWhVY6MRrL3fJybYYNak36MpEcEz0u7fybLZEHq75d0G4zyJ
« Last Edit: March 01, 2025, 02:05:24 pm by kagliostro »
« Reply #2 on: March 01, 2025, 06:28:44 pm »
Should be similar to a 12AU7 with different heater pin out requirements ...
Judging from data sheet curves, the 6N5P is close to a 12AU7, but not quite the same.
I've never used one because I have no trouble finding a 12AU7 for the rare cases when I need one.
Offline jansch
« Reply #3 on: March 02, 2025, 09:56:53 am »
www.radiomuseum.org says the tube is equivalent to 1539 but in different quality class (probably consumer as opposed to military).
