September 08, 2026, 07:29:15 pm
Hoffman Amps Forum image Author Topic: voltage divider assistance.  (Read 4542 times)
Offline joesatch
  • save me from myself.
« on: April 01, 2025, 08:27:32 am »
this friedman circuit. has the option to bypass the first triode gain stage and rout the input to the second gain stage (done with a relay).  If i wanted to not incorporate this option and wanted to just take the output of the first gain stage and cascade it into the second gain stage. What voltage divider would i use? F
« Last Edit: April 01, 2025, 08:30:38 am by joesatch »
Re: voltage divider assistance.
« Reply #1 on: April 01, 2025, 09:03:29 am »
don't understand the question?
with the switch in the "both tubes" option it's already "cascaded" into the 2nd tube, V-divider n all
Offline joesatch
« Reply #2 on: April 01, 2025, 09:49:17 am »
I want this cascade permanent and dont want to use two voltage dividers like the schematic shows. i want to use one voltage divider into the second gain stage. wont be using this switched option.
« Last Edit: April 01, 2025, 09:52:12 am by joesatch »
Offline Merlin
« Reply #3 on: April 01, 2025, 10:03:14 am »
C'mon man, you should be able to do this by now
Offline joesatch
« Reply #4 on: April 01, 2025, 10:14:50 am »
i thought so . was calculating the voltage dividers and both vs one are very close output voltage with 1v going in
Offline SEL49
« Reply #5 on: April 01, 2025, 12:09:51 pm »
There's only ONE voltage divider. R7 and R8 do not form a voltage divider.
Offline joesatch
« Reply #6 on: April 01, 2025, 12:50:42 pm »
you're right! :l2:
