September 08, 2026, 04:41:03 pm
Hoffman Amps Forum image Author Topic: Trimming paraphrase inverter ... hum question  (Read 6101 times)
Offline Diverted
« on: April 03, 2025, 07:54:34 am »
Hi all,
A friend of mine dropped a Benson Monarch Reverb at my house a few weeks ago, and I ended up tracing out the schematic and built my own. It's a very nice amp and everything sounds good.
One issue: As built, the original Benson had a 10KL pot to ground on the PI (V3B) grid, taking place of the 10K voltage divider resistor to ground (R2 in this schematic). The pot circuit is shown below.
When I built mine I used a resistor, not the pot.
Consequently I was getting some hum ... Pulling V1 reverb and V2 preamp had no effect. Only removing V3 PI eliminated it.
So I revisited that 10K pot and paralleled another 10K resistor across R2 to give me about 5K. This reduced the hum considerably.
There is still a tiny bit of hum left and I'm sure I could eliminate it more. My question is, what is the tradeoff? Am I in danger of shutting off one half of the phase inverter if I go much lower? Seems like that would be a possibility with that 10K pot, if someone just turned it all the way counter-clockwise, it'd be basically be grounding out that grid.
« Last Edit: April 03, 2025, 09:04:19 am by Diverted »
Offline Merlin
Re: Trimming paraphrase inverter ... hum question
« Reply #1 on: April 03, 2025, 10:51:01 am »
It's not clear whether your hum is mostly arriving at the grid of V3A and then being amplifed by it, or whether it is mostly leaking down from the B+ and arriving at the anodes of V3, or both. These would have different solutions.
What happens when you ground the grid of V3A?
Offline Diverted
« Reply #2 on: April 03, 2025, 01:30:35 pm »
Grounding out V3A grid doesn’t quiet the amp. It changes the tone of that hum to a lower, fatter version if that makes sense.
Grounding out V3B grid does about the same.
Grounding V3 shared cathode eliminates it.
I just replaced the shared cathode RC for one on each cathode (10uf/820 ohms). No change.
« Last Edit: April 03, 2025, 01:43:50 pm by Diverted »
Offline pullshocks
« Reply #3 on: April 03, 2025, 01:56:22 pm »
When I had my Monarch on the breadboard, I had the PI balance pot on the front panel.  I tried various settings.
I measured the SPL of the amplifier hum at various settings of the PI pot.
Offline Diverted
« Reply #4 on: April 03, 2025, 02:03:47 pm »
Interesting. Doesn’t seem like a giant impact but still, it’s there. Neat.
« Reply #5 on: April 03, 2025, 03:09:36 pm »
I think it's your grounding. Probably V3. How did you ground the amps circuit? Random grounding?
When you added the || 10K you cut the PI's output, so the humm was less, but so was the amps volume at the same setting.
A member here just got rid of the humm in his Magnatone vibrato/reverb preamp build using Merlin's grounding scheme.   https://el34world.com/Forum/index.php?topic=32605.msg361692#msg361692
Read Merlin's page on grounding, the bussed multi star grounding works great;
https://www.valvewizard.co.uk/Grounding.html
Offline Diverted
« Reply #6 on: April 03, 2025, 04:28:47 pm »
I followed the grounding scheme and layout of the original. This amp has five grounding points. Maybe I’ll shuffle them around and see how it reacts.
« Reply #7 on: April 03, 2025, 04:40:04 pm »
Got any many-µF caps?  like 100-250µF?  I would tack the big-cap across each cathode resistor for the inverter.  This will tell you whether the tube is leaking AC from heater-to-cathode (and I think that is the case based on the hum being killed when you directly-grounded the cathodes).
I'm not sure anything useful is done by separating the cathodes of a paraphase inverter.
FACT:  The pot would allow getting either equal-output from the sections of the inverter, or counteracting some imbalance of the output tubes.  "Perfect Balance" gives the loudest clean signal the amp can manage.
OPINION:  The useful aspect of the paraphase is that it is not balanced, and can contribute some even-harmonic distortion to the output stage because of that.  I would choose a paraphase when I want intentional-imbalance (which is partly the "fatter sound" you heard earlier).
Offline pullshocks
« Reply #8 on: April 03, 2025, 06:10:36 pm »
In the whole 33 page Benson Monarch thread on Amp Garage, I don't recall that the Benson factory setting of this pot was ever discovered or revealed.  I would love to know what your friend's amp is set at.
The AmpBooks paraphase calculator shows about 4K is balanced for this amp Paraphase Resistor Calculator
One thing I recall, playing guitar with the PI the pot  turned way down, volume was a lot lower, as you would expect with only 1 6V6 running.  Almost like turning it into a single ended amp.
« Reply #9 on: April 04, 2025, 02:30:16 am »
It was "almost like turning it into a single-ended amp" because, in fact, turning that all the way down will turn it into a single-ended amp.
The output transformer will have a tube on either side to pull "balanced idle current," but only one of those tubes will be driven with an AC signal.  The net effect is "a single-ended amp with a non-ideal load" (which causes it to deliver somewhat less power than if the load were "ideal").
Offline Merlin
« Reply #10 on: April 04, 2025, 04:19:57 am »
That suggests you could use a much bigger cathode bypass cap to kill the hum.
« Reply #11 on: April 05, 2025, 01:06:51 pm »
Or that the tube is bad
« Reply #12 on: April 05, 2025, 02:03:40 pm »
A lot of tubes have heater-to-cathode leakage, and will hum in the absence of a heavy bypass from cathode to ground.  I'm convinced that Fender used a 250µF bypass cap on the tweed Bassman to kill hum, not because they needed a lower cut-off frequency.
But most stages of most preamps have a bypass cap.  So it's only when we are unlucky with a tube-sample, and also unlucky with a socket/circuit that lacks a bypass, that we notice the tube humming.  So the "bad tube" might give acceptable performance in a different socket (not unlike throwing a microphonic tube in a blackface Fender amp's trem oscillator socket).
