July 25, 2026, 09:36:42 am
Hoffman Amps Forum image Author Topic: OT primary impedance for push-pull amp  (Read 7576 times)
Offline gontek
« on: April 10, 2025, 05:30:26 am »
Hi, I'm trying to calculate perfect transformer for my project,
As I know (from Rob Robinette calculator) OT impedance = PlateVoltage^2/PlateDissipation,
but should I get idle or max PlateDissipation?
And, why typical tranformer for 50 El34 has 3.4K?
if we, let's say, have: 420 B+ and 25W PD ? it should be  aroud 7k
sorry for silly question...
Offline Latole
Re: OT primary impedance for push-pull amp
« Reply #1 on: April 10, 2025, 06:03:57 am »
50  EL34  !!   You mean 50 watts amp with EL34  ?
No need to break your head with calculation , see transformer manufacturer recommendations.
Hammond;
« Last Edit: April 10, 2025, 06:10:32 am by Latole »
Offline gontek
« Reply #2 on: April 10, 2025, 06:29:05 am »
Hammond;
thx, yep, I meant 50W,
my project uses pcl86 tubes, they are rated 9W plate dissipation, and with my, not typical B+ =~316V, there is no dedicated transformer
why 1750P & 1750Q impedance differs so much? If jcm800 & jtm45 plate voltages seems to be close
« Last Edit: April 10, 2025, 06:36:35 am by gontek »
Offline Latole
« Reply #3 on: April 10, 2025, 06:39:28 am »
Why 50 watts  (and why are talking about EL34)  if you use 9 watts tubes ?
Will you use 6 tubes ?
« Last Edit: April 10, 2025, 06:47:51 am by Latole »
Offline gontek
« Reply #4 on: April 10, 2025, 06:49:26 am »
Why 50 watts  and why are talking EL34 if you use 9 watts tubes ?
no, I'm just trying to resolve impedance calculations on real amp,
why jcm800 uses 3.2K, instead of ~7K like JTM45?
Is it just bias difference?
Is formula (B+*B+)/PlateDissipation correct?
« Last Edit: April 10, 2025, 06:52:46 am by gontek »
Offline Latole
« Last Edit: April 10, 2025, 06:57:28 am by Latole »
« Reply #6 on: April 10, 2025, 07:02:15 am »
May this be of some help ?
Note the relation from B+ Voltage -- G2 Voltage and Zout
« Last Edit: April 10, 2025, 07:05:05 am by kagliostro »
Offline Merlin
« Reply #7 on: April 10, 2025, 07:07:06 am »
It is a simplification, a ball-park figure, an approximation, not a precise design formula.
Offline gontek
« Reply #8 on: April 10, 2025, 07:21:26 am »
thank you for your patience,
I see, maybe, my question is not so stupid,
I've got a great idea, I will order Hammond 125E, which has a lot of different ratios, and will experiment :)
Offline Latole
« Reply #9 on: April 10, 2025, 07:25:12 am »
Référence: 125E
Audio transformer, universal push-pull tube output, 15 watts
« Reply #10 on: April 10, 2025, 09:23:10 am »
Ohm's Law:  Resistance = Volts / Current
Or ---------> Impedance = Volts / Current
Or ----> Impedance is a ratio of (AC) Volts to (AC) Current
Forget "Idle Bias" & "Idle Plate Dissipation" as those are mostly irrelevant to the output transformer.
The Output Transformer primary Impedance is about AC Volts and AC Current present when we play the amp.
What AC Volts do we need across each Primary Impedance to develop 50 Watts?
    Volts = √(Power x Impedance)
    JTM45:  Volts = √(50w x 7kΩ) = 591.6v AC   ----> ~418v Peak per side
    JCM800: Volts = √(50w x 3.4kΩ) = 412v.3 AC   ----> ~291.5v Peak per side
With "Volts" lower and "Impedance" lower for the JCM800 output transformer, then how did "Current" change?
    Ohm's Law
    Current = Volts / Impedance
    JTM45:  Current = 591.6v AC / 7kΩ = 84.5mA ----> 119.5mA Peak
    JCM800: Current = 412v.3 AC / 3.4kΩ = 121.3mA  ----> ~171.5mA Peak
For the same power output, the JCM800 must pull more Current through the output transformer while the voltage-drop developed across the Primary Impedance is smaller.  The Ratio of Volts to Current changed.
Where this matters is output tube screen voltage, and how hot the tube runs when driven.
The screen voltage needs to be high enough to support the peak plate current pulled by the tube.
The higher peak plate current means the tube runs hotter when driven with audio.
The hotter operation of the tube (with high peak plate current) when driven means its Idle Bias needs to be cooler, so it spends a little longer in cut-off to cool the plate.  This usually is not accounted for in the simple Bias Calculators that work on idle plate dissipation.
Using lower or higher output transformer Primary Impedance can also change how the output tube distorts.
Offline WiderGates
« Reply #11 on: April 11, 2025, 03:53:12 am »
First of all:
Va max for PCL86 is 250V.
« Last Edit: April 11, 2025, 04:00:04 am by WiderGates »
Offline Latole
« Reply #12 on: April 11, 2025, 04:41:40 am »
First of all:
Very low !
« Reply #13 on: April 11, 2025, 08:56:42 am »
First of all:
Whether you know it or not you are asking, "How do I design an Output Section?"
Since we're probably not gonna learn Electronic Design in a day, copy an existing plan:
Hammond AO-44
PCL86 = ECL86 with a different heater
Data Sheet says "250v max" but Hammond had 310v at their plate.  Nobody makes "new PCL86" so whatever you get your hands on will be able to tolerate the same.
Page 4 of the linked ECL86 data sheet shows load impedance for push-pull ECL86 pentodes at 8-9kΩ.  You can assume anything 7-10kΩ will be "close enough."
The Hammond AO-44 schematic has notes at the output transformer that can be used to calculate a similar result.
« Last Edit: April 11, 2025, 07:35:16 pm by HotBluePlates »
Offline Merlin
« Reply #14 on: April 11, 2025, 09:00:46 am »
First of all:
Wut?
« Reply #15 on: April 11, 2025, 09:40:56 am »
First of all:
This notes 300V?
https://tube-data.com/sheets/010/p/PCL86.pdf
First of all though might rather be the heater supply:- how to provide 13.3V?
« Reply #16 on: April 11, 2025, 03:52:44 pm »
HBP, links not working.
Offline Latole
« Reply #17 on: April 12, 2025, 02:58:34 am »
This one ? It work for me
Offline WiderGates
« Reply #18 on: April 12, 2025, 03:42:13 am »
I have from the Philips Datasheet oft he PCL86:
Offline Merlin
« Reply #19 on: April 12, 2025, 06:14:47 am »
That's the 1961 datasheet, up-rated to 300V in 1968.
