September 14, 2026, 06:09:11 pm
Hoffman Amps Forum image Author Topic: Electric Sitar buzz bridge adjustment  (Read 14060 times)
« on: May 19, 2025, 01:30:23 pm »
Anybody ever adjust 1 of these buzz bridges?    :BangHead:     :cussing:
Can't seem to get the 3 variables lined up, intonation, action and a good solid buzz/'whirring' sound like it should be.
I have a Jerry Jones Sitar Supreme, has the short 6 string fret less drone sting neck. And I bought a new Gotoh buzz bridge, they 'improved' the bridge for intonation. All the new electric sitars use the new Gotoh buzz bridge, Danelectro, Eastwood, Modena, Star's, etc.
If you look at the old bridge style on the sitar and the new style, you'll see what they did.
« Last Edit: May 19, 2025, 01:35:10 pm by Willabe »
Re: Electric Sitar buzz bridge adjustment
« Reply #1 on: May 20, 2025, 08:53:06 am »
I spent at least 5, maybe 6 hours working on getting it to sound/play right.  :BangHead:   :cussing:
A couple hours in, I ended up taking off the big plastic see through string guard, it was much easier to work on. Lubed it's wood screws while it was off. Also lubed the buzz bridge screws while it was off too. I used D'Addario friction remover (like Big Bend Sauce) The screws are just going into wood. The buzz bridge screws move very smoothly now with little turning force needed. It was much easier to work on
I set the 2 front screws 1st for action height, 4/64" high E, a hair over 4/64" low E side. Then I adjusted the single back screw that pivots the bridge to change where the strings actually have their 'take off' spot. This adjusts the intonation.
I got the action and intonation really good, it's hard to see with the harmonics from the buzz bridge. I had to check each string at the 10th fret sometimes to get a clearer reading of where I was at.
But, the problem I kept running into was getting enough sustain from the high strings with the intonation and action set right. The high strings had way too much contact with the bridge and the string then had almost no sustain. I was getting great buzz from the 3 low strings but the top 3 were choked off. So close!   :BangHead:        :cussing:
I did find a guy at a guitar store here that has had 3 of these electric sitars. He still has 1 of them. He said he had to the shim the bolt on neck on 1 of his to get it to work right. He said I could bring it in and he'd show me how he sets them up. I might end up doing that. It's a 4 bolt neck like a strat but no metal plate. I have some maple strat shims for Stu-Mac. I think I'll try that today.
This bridge is very sensitive to any adjustment. And there's only so much play in the amount you can pivot the bridge. Plus there's too much downward pressure from the strings on the back side of the bridge. And that's with a set of 9-42. At a certain point when you loosen the back pivot screwq the bridge can't tip up in the back anymore because of the back sides downward string pressure. I added a 2nd spring to that back screw, didn't help much.
So if I can shim the neck a little and give the neck a little relief it might do the trick.
« Last Edit: May 20, 2025, 08:57:28 am by Willabe »
« Reply #2 on: May 20, 2025, 09:49:05 am »
Should sound like this. This sounds great to me!    :blob8:
i=lNkG4fnDnVOnJERf&t=4
Offline Platefire
« Reply #3 on: May 20, 2025, 06:23:57 pm »
Boy, I can't tell you nothing about that. I may have picked one up in a music store in the 60's and rattled off a few notes. I do hope you get it sounding right and make us a sound clip when you get it going! :m11
On the right track now<><
