September 08, 2026, 04:41:34 pm
Hoffman Amps Forum image Author Topic: Using a 6Z4 to 6X4 adapter  (Read 4516 times)
Offline kasperbergholt
  • Kasper Bergholt, Copenhagen
    • bergholt.net
« on: May 20, 2025, 10:12:14 am »
Hello, clever people,
I have a DAC with a Chinese 6Z4 rectifier tube and an ECC88/6DJ8/6922 amplifier tube. The range of Chinese and Russian equivalents for the 6Z4 family is fairly limited compared to the 6X4.
Apparently, the only difference between the two types (6Z4 vs 6X4) is the pin layout.
Initially, I considered modifying the DAC, but I found that an adapter exists which would allow me to use both types of tubes.
This leads to my question: Are there any theoretical or practical concerns that could degrade the sound when using such an adapter in a rectifier tube position?
Thanks in advance,
Kasper
Offline scstill
  • https://stillampd.com
    • Still Amp'd
Re: Using a 6Z4 to 6X4 adapter
« Reply #1 on: May 20, 2025, 06:10:29 pm »
There is a 5pin 6Z4/84 tube (from the 30's) that evolved into the 7pin 6X4 (40's) and then apparently China made a 7pin tube and used the same 6Z4 designation as the 5pin (confusing). I suppose the 84 designation helps.
Follow successor link at this site for history...https://www.radiomuseum.org/tubes/tube_6z4.html
The great sounding Phirty6 design https://stillampd.com/phirty6 uses the 5pin 6Z4/84 rectifier as it was part of the original car radio. As well, old tubes are also pretty cool...
Should not be any degradation with the adapter you mention
https://www.thetubestore.com/6x4-to-6z4-tube-adapter?srsltid=AfmBOooekfPbkR1rclgu-sveEoCeQZ1xrBTthIOiqo42fdAdUe85sWVv
« Last Edit: May 20, 2025, 06:17:18 pm by scstill »
« Reply #2 on: May 21, 2025, 06:59:47 am »
What is a DAC?
Offline scstill
    • Still Amp'd
    • bergholt.net
« Reply #4 on: May 21, 2025, 11:58:31 am »
Thank you for the reply! Yes, very confusing with the naming, and I was close to getting the wrong type.
The Chinese version is on Radiomusem here:
https://www.radiomuseum.org/tubes/tube_6z4p~2.html
And the Russian equivalent here:
https://www.radiomuseum.org/tubes/tube_6z4p.html
I'll give the adapter a try and report back with results :)
    • bergholt.net
« Reply #5 on: May 21, 2025, 12:04:27 pm »
What is a DAC?
It stands for Digital Audio Converter - used for converting a digital signal from a CD player or a USB streamer into a line level signal that can feed a preamplifer or integrated amplifier.
Mine is based around a 6Z4 rectifier tube & and ECC8 amplifier tube. The converter chip is an Analog Devices AD1865 with a with a CS8412 interface chip.
