September 08, 2026, 04:41:19 pm
Hoffman Amps Forum image Author Topic: 800 circuit power section hum help!  (Read 5075 times)
Offline joesatch
  • save me from myself.
« on: May 26, 2025, 08:07:15 pm »
ok i have tried many things. currently i have both preamp tubes removed and the input to the P.I. from the master disconnected.  reservior cap is grounded to chassis along with the PT CT and power tube grounds.  Heater is artificially grounded to chassis with two 100R resistors (i have tried removing this as a test no difference).  B+1 grounded to chassis along with bias ground, OT ground, presence ground.  With the master connected to the P.I. i get good signal and preamp section works fine but the hum is there.
« Last Edit: May 26, 2025, 08:24:17 pm by joesatch »
Offline AlNewman
Re: 800 circuit power section hum help!
« Reply #1 on: May 26, 2025, 08:22:37 pm »
Sounds like you have your thumb on the input cable.
« Reply #2 on: May 27, 2025, 06:25:49 pm »
... currently i have both preamp tubes removed and the input to the P.I. from the master disconnected.  ...
What happens if the Phase Inverter tube is removed?
Offline joesatch
« Reply #3 on: May 27, 2025, 08:42:05 pm »
noise goes away if the PI tube  is removed. this is 60 cycle hum correct? so it's in the audio path?  PI input is disconnected.
« Last Edit: May 28, 2025, 08:33:31 am by joesatch »
« Reply #4 on: May 28, 2025, 12:15:36 pm »
Sounds like 60hz to me. Check all grounds for good connection.  could be injected into signal via a problem with small bottle tube.  So have you substituted all the tubes?
« Last Edit: May 28, 2025, 12:20:53 pm by mresistor »
Offline joesatch
« Reply #5 on: May 28, 2025, 02:19:19 pm »
i pulled the board. i believe it's conductive. built too many amps and this is a simple circuit. must be the board. i'll put a turret board in
Offline joesatch
« Reply #6 on: May 29, 2025, 08:55:50 am »
 :huh:
Offline danhei
« Reply #7 on: May 29, 2025, 08:16:56 pm »
Why do you believe the board is conductive? That doesn’t seem particularly likely for what appears to be a fiberglass/epoxy PCB.
Offline joesatch
« Reply #8 on: May 30, 2025, 06:31:36 am »
entire bottom of the board has a ground plane around all holes
« Reply #9 on: May 30, 2025, 07:35:24 am »
Are you using it as a shield, by only making a single connection between the chassis and ground plane, or are you using it as a conductor for 0V common, with 2 or more connections to it?
Whatever, the likelihood of a good question board substrate becoming conductive seems low, much lower than other possible causes of hum.
Offline joesatch
« Reply #10 on: May 30, 2025, 09:06:53 am »
spent too many hours troubleshooting the hum. i ripped the board out will build a turret board over the weekend and be done with it
