September 08, 2026, 04:41:33 pm
Hoffman Amps Forum image Author Topic: 5879 tube data sheet question  (Read 5797 times)
« on: September 02, 2025, 08:18:29 am »
I have always loved what I hear as a fat chimey tone with 5879 tubes.  From what I read this is a low-medium gain tube?
5879.pdf
It looks like the "amplification factor" for the triode is 21?  I don't see any indication for the pentode amplification factor?
I am curious how the pentode amplification factor compares to a 12AX7?
12AX7 datasheet(1/4 Pages) GEC | TWIN TRIODE
Offline Merlin
Re: 5879 tube data sheet question
« Reply #1 on: September 02, 2025, 08:30:25 am »
The datasheet quotes:
Plate resistances approx 2 megohms
Transconductance 1000 umhos
mu = gm * rp
Therefore:
mu = 0.001 * 2000000 = 2000
As you can see, pentodes have colossal mu! It's also very difficult to determine accurately, so it's not a very useful metric which is why datasheets don't quote it.
Offline Jonas
« Reply #2 on: September 03, 2025, 04:23:52 pm »
i also love this tube. Why is 12.6 v heater operation not listed? I looked at a few other pentodes which only show 6.3v option in the TDS?
« Reply #3 on: September 04, 2025, 01:05:28 am »
Because of construction, It was thinked that a single heater winding will be better in a tube devoted to low noise apparatus like HiFi and a double winding will add construction difficulties and require more space
« Last Edit: September 04, 2025, 01:17:34 am by kagliostro »
« Reply #4 on: September 04, 2025, 05:34:45 am »
I am curious how the pentode amplification ... compares to a 12AX7?
mu = gm * rp
Therefore:
Further, the formula we use to determine in-circuit gain recognizes that the external plate load resistor forms a voltage-divider with the internal plate resistance of the tube.  Amplification = Mu x [Rl / (Ra + Rl)]
For a Triode "Rl" (the external plate load resistor) is usually bigger than the internal plate resistance of the tube.  But the pentode's internal resistance is almost always higher than the plate load resistor, so we don't use that formula to estimate in-circuit gain of a pentode.  That's because if you put 100kΩ in parallel with a 2MΩ internal plate resistance, the total resistance is "nearly 100kΩ."
So as Merlin noted here, we calculate Pentode Gain as "Gm x Plate-Load."  Within this framework, there are approaches that seek to maximize Gm and different-approaches that use lower-Gm and a larger plate load resistor.  Gm for the tube is controlled by choice of screen & bias voltages, with higher idle current leading to higher Gm for the tube.
« Reply #5 on: September 06, 2025, 12:31:01 pm »
I start with the cheat sheets. Nearly all audio pentodes have published data on bias parameters.
Resistance Coupled Amplifier chards provided in most tube reference. The attached an excerpt from the RCA Receiving Tubes Manual. Link to the rest charts below. V.G. colum is that what you seek.
RCA Charts here.
