September 08, 2026, 04:40:47 pm
Hoffman Amps Forum image Author Topic: Inductor EQ  (Read 8061 times)
Offline hylaphone
Inductor EQ
« on: September 14, 2025, 08:40:45 am »
Hiya, I once had a schematic (which has since grown legs) of an amp from the 70's with an inductor based EQ along the lines of the SVT, but perhaps a few more bands?Does this ring a bell with anyone?
Offline CrimsonGhost
Re: Inductor EQ
« Reply #1 on: September 14, 2025, 09:38:09 am »
Not a valve amp but some old Peavey solid state amps use inductors in the EQ section.
Offline hylaphone
Re: Inductor EQ
« Reply #2 on: September 14, 2025, 11:51:43 am »
Thanks, but IIRC this was happening between a couple triodes. Pretty sure it was one of the big 70's amps (400PS, SVT, etc.) just can't remember for the life of me
Re: Inductor EQ
« Reply #3 on: September 14, 2025, 12:51:12 pm »
i spent hours look'n through Doug's porn collection, maybe you'll find that special TS  :icon_biggrin:
https://el34world.com/charts/TubeAmpSchematics.htm
Offline Carlsoti
Re: Inductor EQ
« Reply #4 on: September 14, 2025, 11:03:52 pm »
It's not the 400PS.
Re: Inductor EQ
« Reply #5 on: September 15, 2025, 12:18:44 am »
... Pretty sure it was one of the big 70's amps (400PS, SVT, etc.) just can't remember for the life of me
Ampeg SVT
Careful if you copy:  coils like to pick up hum.
(EDIT: Sorry, this is wrong because it's not multi-frequency as requested.)
« Last Edit: September 16, 2025, 04:11:29 pm by HotBluePlates »
Offline hylaphone
Re: Inductor EQ
« Reply #6 on: September 15, 2025, 08:53:53 am »
Ah, I found it.Fender 300PSThanks
Re: Inductor EQ
« Reply #7 on: September 15, 2025, 09:00:10 am »
Which is your interest on the equalizer ?
Years ago at DIYItalia a forumer developed an equalizer borrowed from SVT but without inductors, instead of inductors it used gyrators
If you have interest I can search the resulting schematic
Offline hylaphone
Re: Inductor EQ
« Reply #8 on: September 15, 2025, 09:20:54 am »
Thanks for the offer, got a fellow who wants inductor mid control for bass guitar. I remembered this Fender design as a simpler approach than the SVT, figured it was worth experimenting with.
Re: Inductor EQ
« Reply #9 on: September 16, 2025, 12:23:44 pm »
... got a fellow who wants inductor mid control for bass guitar. ...
Gibson had a Varitone that use inductors and caps, but it's worth seeing that like a Wah pedal:  you can get a lot of Treble or a lot of Bass, though a lot of Mids is also sort of a lack of Treble/Bass.  You also don't have control of "How Much."
If you use inductors, you need to fit them in a shielding box of some kind, tied to cable-shields for the internal wiring.  Because that inductor will pick up hum & noise out of the air to add to the signal (which is the basis of hum-cancelling dummy-coils).
Of course, there are also pedals that do this:  WahFul (where you also get to adjust the amount of mid-boost), graphic EQs, parametric EQs.
I'm sure the player believes he needs finger-tip control of the Mid.  However, I bet after 1 gig he will pretty much know what sound he will want to kick on, and the need to have this mid-boost in the Bass itself will vanish.
Offline hylaphone
Re: Inductor EQ
« Reply #10 on: September 16, 2025, 01:59:10 pm »
Sorry, I should have clarified - this is for a bass guitar preamp. I tacked it together today with parts I had on hand, it works really well.
