September 08, 2026, 04:41:49 pm
Hoffman Amps Forum image Author Topic: What Is this circuit ???  (Read 4473 times)
« on: September 14, 2025, 05:05:39 pm »
I've find the attached schematic on the web
There were no explanation and I'not able to understand what exactly It Is
The upper section looks like a Preamp with lo impedance output
But about the lower section I'm not able to understand what It do, which Is the pourpose
Any explanation or idea about ?
Offline SEL49
Re: What Is this circuit ???
« Reply #1 on: September 14, 2025, 06:02:41 pm »
Looks like a preamp for a phono magnetic cartridge (pickup). It has switch selectable equalization.
« Reply #2 on: September 14, 2025, 07:24:29 pm »
RIAA Equalization Curve
Notice when Recording that Bass is cut (to keep the needle from jumping out of the groove), and Treble is emphasized.
On Playback, Bass is boosted to restore "natural Lows" and Treble is cut (reduces Hiss while also restoring "natural Highs").
There were several different curves used by different record-manufacturers, or standards-setting groups.
A Phono ("PH") signal was also weaker than other sources, and needed extra amplification.  The output of the PH-channel's EQ section feeds the rest of the preamp when the Selector is in the "PH" position.
« Reply #3 on: September 15, 2025, 12:58:25 am »
Many thanks Friends, now I understand
Thanks you very much
