September 08, 2026, 04:42:15 pm
Hoffman Amps Forum image Author Topic: Mesa Boogie MKIII bias supply issues. Please check my logic  (Read 13017 times)
Offline jukelemon
  • It's always in the fingers
« on: September 23, 2025, 04:31:51 pm »
Hi all!
I have a MKIII with not only a complete lack of bias supply but adding insult to injury...a bias supply of 186vdc :)
I have attached the schem as well as points 1 and 2 on another attachment.
Amp had a burnt screen resistor on one of the 6CA7s.  Repaired that and went ahead replaced all the screen resistors 5 watters for safe measure.
Bringing up the amp via a Variac I noticed a good NEG bias supply on the left pair but a climbing POS bias supply on the right pair.
So shut it down and remove the tubes.
In the middle of tracing the bias supply to Point 1 (on attachment), the left side pair goes positive as well :(
And by POS, I mean 180+VDC.
So... I can measure an expected -59vdc at Point 1 BUT when I cross the 220k resistors (Point 2), I get the 180+vdc bias supply and that follows on down to the pins.
So...I measure the .1 caps that are coming off the Phase Inverter.  Both (odd I know) are shorted.  I measure continuity between the leads on both.
So, I am assuming the shorted coupling caps are allowing DC into the bias supply and that is why I am seeing what I am seeing.  Make sense?
On another note...i don't think the schem is written correctly because those .1 caps are not on the side of Point 1.  They are actually on the side of Point 2 which makes sense as to what i am reading as far as component location/leads.
Offline stratomaster
  • Don't guess, measure.
Re: Mesa Boogie MKIII bias supply issues. Please check my logic
« Reply #1 on: September 23, 2025, 04:48:05 pm »
Boogies have a reputation for using under spec caps in this location.  They're typically 400V where a 600V+ cap would be better.  Replace with the equivalent value in a higher voltage and then check again with the tubes out. There's also a chance the filter caps in the bias supply were reverse biased if you had voltage leakage. You may need to inspect and possibly replace those.
Offline jukelemon
« Reply #2 on: September 23, 2025, 04:59:59 pm »
Thanks.  I have read that too and was planning on 600v caps for sure.
So....my logic is accurate then?
I traced the bias supply all the way from the PT so I am thinking I am good up to the junction of those .1 caps.
« Reply #3 on: September 23, 2025, 05:42:52 pm »
your logic is sound, redraw of find a better schematic though because the schematic makes your logical conclusions illogical  :icon_biggrin:
this is one of their 50W  make it look like that
Offline jukelemon
« Reply #4 on: September 23, 2025, 11:41:34 pm »
Thanks Shooter and yes, that schem looks more like what I’m seeing in real life.
Of interest .. the schem I posted is identical to what came with the amp :) The original yellow documentation papers are still with the amp.
The schem also doesn’t show the 2.7k screen resistors on the 6ca7s.
Weird
« Last Edit: September 23, 2025, 11:43:48 pm by jukelemon »
Offline jukelemon
« Reply #5 on: September 24, 2025, 07:42:17 pm »
In the event others are in a similar boat…c511 and c512 are the offenders.
Pulled them out today and both are dead shorts between leads.
« Reply #6 on: September 25, 2025, 11:16:13 am »
I don't see them labeled on the schematics.
Which 2 caps do you mean? The power tube coupling caps?
Offline jukelemon
« Reply #7 on: September 28, 2025, 08:25:45 am »
Sorry. Yeah. The actual board is labeled in the amp. Why the schem is not and the board is .. not sure.
I’m referring to the the 2 x .1 caps off the PI and connecting to the bias circuit
Offline jukelemon
« Reply #8 on: September 30, 2025, 08:29:30 pm »
Closing the loop...
2 x new .1 caps and the amp is back to life and healthy!
Can't say I like the sound of them and damn...how heavy can it get lol.
Offline Merlin
« Reply #9 on: October 01, 2025, 09:15:59 am »
Out of interest, were the original caps only 400V rated?
Offline jukelemon
« Reply #10 on: October 01, 2025, 10:20:47 am »
Yes. 400v spec on the original 2 x .1uf orange drops
« Reply #11 on: October 02, 2025, 11:09:49 am »
Why are 400v rated PI to power tube blocking caps getting killed in that amp?
« Reply #12 on: October 02, 2025, 12:28:15 pm »
The voltage across them at initial power up, for the 30ish seconds until the valves warm up and start to draw HT current, can be well above 400V.
eg 500V unloaded HT on one side, -50V bias on the other.
« Reply #13 on: October 02, 2025, 07:40:49 pm »
Ok, thanks.
The schematic in Doug's library for the MkIII shows a stand by switch. I know you guys don't like stand by switches but here seems it would stop the PI blocking caps from being eaten. Or like suggested, just use a 600v cap. But the amp has the switch already, just use it.
Offline jukelemon
« Reply #14 on: October 04, 2025, 04:13:25 pm »
Ok, thanks.
Yes, there is a SB switch and it is my understanding that it is less a voltage issue than than not so great Orange Drop QC in the 80s AND the fact that they are 35+ years old at this point.
I don't know... :dontknow:
