September 08, 2026, 04:41:19 pm
Hoffman Amps Forum image Author Topic: Should I get a tube tester?  (Read 9846 times)
Offline Dumbmonkey
« on: October 02, 2025, 06:48:26 am »
Hi,
I found someone in a nearby town with a Hickok 725 tube tester for sale.  What does anyone think about this?  She says it was well cared for, but hasn't been used in years.  Should I consider purchasing this, or a tester like it?  She's asking $200.
Re: Should I get a tube tester?
« Reply #1 on: October 02, 2025, 07:44:32 am »
what's your end-game?  bench tech? just the cool-factor?  do you have a scope, since that will come in way more often fixing broke stuff.
most "bad" tubes can be found by swapping, catastrophic fails will be quite obvious.
does the tester come with all the 'ol tubes laying around the tester bench?  score a pile of audio PA tubes, makes the cost more effective.
« Reply #2 on: October 02, 2025, 03:40:51 pm »
That tester probably needs a re-cap. $200 you say? She's trying to mine gold out of it.
« Reply #3 on: October 02, 2025, 06:02:18 pm »
I found someone in a nearby town with a Hickok 725 tube tester for sale.  ...  She's asking $200.
I think you mean "Hickok 752."
If I'm correct, those should easily sell for $400-600.  I would personally buy it sight-unseen (if it is a "752").
« Reply #4 on: October 02, 2025, 07:06:42 pm »
Lol this auction says 725a but the book says 752
https://ebay.us/m/jEZbsZ
Offline Dumbmonkey
« Reply #5 on: October 02, 2025, 07:53:34 pm »
Hi and thanks for the replies everyone,
I stand corrected, it is a 752.  I'm not sure if I would really get much actual use out of it, but I thought it might be good to have just in case.  Now I'm having 2nd thoughts, and think it might be overkill for any work that I actually do.
Thanks again!
« Reply #6 on: October 03, 2025, 12:34:16 am »
Don't think about
Get It
Offline triode
  • Use the silver solder
    • TheAirtightGarage
« Reply #7 on: October 03, 2025, 05:15:47 am »
That is completely different. I'll buy it. :)
The 725a is an early model that you do not want. The 752 is a serious tube tester. I have one with a broken selector switch so when I use it I have to be _really_ careful with it.
Honestly, do you have a huge stash of tubes and check them? Matching on a 752 is not _really_ accurate, you would want a maxi-matcher or in-circuit tests for that. After about, I am not sure, 30+ years of fixing amps, I find that my tube tester is something I use on amps in-frequently, but on my large stash of tubes very frequently. I can not advise you to get it or not, but for those of us who use a tester, a 752 is a very nice unit.
Offline Merlin
« Reply #8 on: October 03, 2025, 06:07:40 am »
Do you already own an oscilloscope and signal generator? If not, that two hundred bucks would be better spent on those instead! That's opportunity cost ;)
« Last Edit: October 03, 2025, 06:19:08 am by Merlin »
Offline Dumbmonkey
« Reply #9 on: October 03, 2025, 08:03:00 am »
Hi,
Now I'm tempted...
I did by one of those $40 oscilloscope/signal generators on Amazon, but I'd really like to know how to use it better for amp diagnostics.  (I got it mostly for the signal generator).
Any recommendations for an oscilloscope that would be more user friendly, and maybe some info on how to use it with tube amps.  I know there are tons of youtube videos, but if someone has one they like and recommend for newcomers like me, that would be great!
Offline Merlin
« Reply #10 on: October 04, 2025, 05:36:00 am »
Any bench osciloscope is worth having. Where I live the best value for money seems to be the Rigol DS1102 or the Hantek DSO2C15, but there may be other bargains where you live.
« Last Edit: October 31, 2025, 06:09:51 am by Merlin »
