July 28, 2026, 04:32:11 am
Hoffman Amps Forum image Author Topic: Princeton Reverb circuit refinements  (Read 32560 times)
Offline stratomaster
  • Don't guess, measure.
Re: Princeton Reverb circuit refinements
« Reply #50 on: June 18, 2026, 01:17:59 pm »
Yes. I run a 1M input resistor and a 1.2k bias resistor. Its a much smoother overall sound to my ear, but I don't have an A/B comparison.
« Reply #51 on: June 18, 2026, 03:21:14 pm »
a 'side kink' that moves up and down the wave with volume setting
those can be "transients", an AC signal riding on your fundamental Frequency
does your scope have a FFT/spectrometer mode?
IF so;
look for a spike that comes n goes, usually it's a harmonic of the fundamental you're using for testing
Offline johnfromcyrene
« Reply #52 on: June 18, 2026, 03:29:04 pm »
do you have a pi grid stop resistor?
Offline tristanc
« Reply #53 on: June 18, 2026, 03:52:19 pm »
Can you temporarily solder a 3.3k resistor in parallel with the 1.5k cathode resistor on your cathodyne?
There's a thread on TDPRI where the role of this resistor was investigated thoroughly. The conclusion was that the 5E3 value of 1k gave a much better PI balance than the 1.5k used on the 1164.
Thanks - I think I've just found that thread. In the spirit of trying to alter the bias point, I quickly swapped in a 12AT7. Messes up the tremolo but the distortion / fuzz is still there. I'll have a think about what that could mean. Next time I've the chassis out I'll clip in the 3.3k and report back.
IF so; look for a spike that comes n goes, usually it's a harmonic of the fundamental you're using for testing
The FFTs are in the PDF along with some harmonic values. I've pulled the graph out (attached).
I also spotted another thread on here from a few years ago. Still wading through it, but it was suggested issues with the OT could explain things like I'm hearing. I may have a spare OT so temporarily hooking that up may be another option to try.
« Reply #54 on: June 18, 2026, 05:02:44 pm »
looks like there's a low freq oscillation riding on your fundamental or something is breaking down with signal load.  since it's affected by volume, it's probably creeping in before the PA section.
Offline tristanc
« Reply #55 on: June 19, 2026, 06:04:41 am »
Interesting - I'll check the cap can, wiring around it and do a bit of chopsticking. Could the oscillation be cancelled out by the push-pull output until it starts to break up, when the feedback collapses and the rogue signal appears?
I'm using the standard JJ cap, and would hope 40uF would be enough filtering. But another thing I could do would be to clip in another big cap to see what happens.
Offline tristanc
Reverb Driver Oscillation
« Reply #56 on: June 22, 2026, 10:39:18 am »
Some progress. I pulled out the chassis to get a 4 channel scope on it. In doing so I didn't bother connecting the reverb tank. "Hmmm, that's strange, why's the trace changed from yesterday..."
Then I realised that probing the reverb driver grid(s) could make the waveform change. A lot of playing about made me realise without the reverb tank connected the distorted tone was great. Plug it in and I get this high 'hash' behind the notes. I also could see some ringing on the reverb send.
Great - a line of inquiry. So I added some capacitance from the grid to ground. That seemed to help a bit. Doing some googling suggested adding some stoppers - so I put a 1k from the PCB to the 1st grid, then bridged to the 2nd grid with a 470ohm.
That 'seemed' to partially resolve it. However, putting everything back in the cabinet and listening just now the overtone is still there... Darn it.
The traces captured suggested I've had an impact but perhaps not enough? Channel 1 is input, 2 is speaker output (resistive load), 3 is reverb out, 4 is reverb return. State 2 is just as the ringing appears and clipping about to be seen. 3 is clipping, 4 is amp up full. A very different picture to the previous traces, so something has changed.
This post was useful: https://www.tdpri.com/threads/silverface-princeton-reverb-reverb-related-distortion.1171963/
He seemed to sort it by moving the 10pF cap a little bit.
« Last Edit: June 23, 2026, 04:28:16 am by tristanc »
« Reply #57 on: June 22, 2026, 11:22:13 am »
Recent Fender amps use a 10k grid stopper at the socket of the reverb driver.  You can try this.
I've also seen 560pF caps from plate to cathode on certain reverb driver tubes.
An overlooked place for tweaking the hash out of Fender reverb is the recovery triode plate resistor.  A fairly aggressive 470pF cap can be used without losing much of the useful reverb information due to the mid-focused and bandwidth limited nature of the circuit.
You can also temporarily install a dwell pot to see if attenuating the input to the reverb driver kills the hash.  If so, then warming the bias or slightly raising the plate voltage (or a little of both) may be in order.
Offline tristanc
« Reply #58 on: June 23, 2026, 05:41:56 am »
Thanks - this is really useful and gives me a few things to try.
With fresh ears this morning I gave another listen. Still there as before. However, unplugging the tank (something I hadn't done before yesterday) removes the annoying tone almost entirely. So it gives me a sole area to focus on.
Annoyingly, I had planned on putting a 100pF 2kV cap across the reverb transformer primary (I assume the equivalent of plate to cathode?) and a 1k across the secondary following Merlin's book. But got lazy when the layout would get messy and left them off... So:
1) I'll try plate to cathode with the cap I have.
2) add in the 1k at the reverb send
The driver is running at ~343V B+, with 6.2V at the cathode - so 4.2mA going through both triodes. A quick look at the tube curves shows this is pretty cold (and/or a weak JJ tube from the looks of it). Maybe too cold?
3) clip in more capacitance across the recovery plate resistor
4) clip in another resistor across the 1.5k Rk? Get it down to 1k perhaps?
5) Increase the stopper(s) to 10k (and the 'bridge' stopper too, if appropriate)
Will report back.
[EDIT] thinking about it and looking at the later 019320 schematic - could this all be due to the driver being biased too cold? c.v. the ~ 3.2V on the later version, 6 is close to cut off. If I'm feeding it a hot signal that could be causing something to 'leak' back in to the clean signal line? Hence hearing the rattiness when the reverb is connected but turned to a minimum.
« Last Edit: June 23, 2026, 07:58:24 am by tristanc »
« Reply #59 on: June 23, 2026, 12:43:48 pm »
How hot of a signal? If your RMS AC voltage at the driver tube grid is ≈70% of the cathode voltage you could have grid clamping and that would affect the dry signal.
The part that has me scratching my head is that disconnecting the tank eliminates the problem. This would imply it's a problem that is fed through the tank and mixed back into the signal through the recovery stage OR that the effect of eliminating the load of the tank changes the overall plate load in a favorable way to reduce grid clamping.  I'm leaning towards the latter.
Offline tristanc
« Reply #60 on: June 23, 2026, 01:52:34 pm »
I'll try and take a reading tomorrow.
Agreed - that is odd. Unless it's parasitic coupling to a close-by wire? Or something silly like having the reverb transformer oriented the 'wrong' way round? Or wires reversed?
I'm wondering what order I do the experiments in. I've limited time tomorrow to do some play testing, figuring I can always scope things properly later on when I have more time to investigate and tidy up any bodges.
1) clip in another 1.5k across the 1.5k Rk to get closer to the 680r value I see on other schematics
2) clip in plate to cathode 100p (or higher - 560p)
3) clip in the 1k at the reverb send (protection - likely no difference to this case unless it's impacting plate loading when unplugged. Could be red herring.)
4) clip in more capacitance across the recovery plate resistor
5) Increase the stopper(s) to 10k (and the 'bridge' stopper too, if appropriate. A bigger job - one for later)
I could go one by one until it's, hopefully, resolved, or it could be a sum of a few of them. Who knows...
« Reply #61 on: June 23, 2026, 02:24:41 pm »
I think the most useful test isn't listed. Add a Dwell control temporarily to see if you can induce/cure the effect by attenuating the input to the driver.
Also, I don't understand why you have a "bridge" grid stopper.
Offline tristanc
« Reply #62 on: June 23, 2026, 02:59:51 pm »
Good shout - I’d need my iron out for that. Perhaps I can do the opposite - add capacitance to let more signal in and see if the issue gets worse?
The 2 stoppers thing was from a google - there being 2 potential gain loops that could pick up interference, so belt and braces approach was to add a 2nd resistor. Overkill maybe, but also removed the length of wire from one grid to another. I can remove on the tidy up.
Offline tristanc
« Reply #63 on: June 24, 2026, 08:24:27 am »
I'm about to give up... Just to make sure I'm not chasing a figment, attached is a sound sample. Should I just settle for it?
Amp at 7/10, bit of reverb & trem, high output tele bridge pickup. A low E plucked with guitar volume up full, then down a bit to clean up, then back up again. Then some high notes with IMD. Some power chords. Recorded via Boss Waza TAE. Sound in the room is a bit more muffled and the rattiness more prominent at living room conversational volume.
Today I tried:
- a 12au7 in the reverb driver slot,
- changed the bias of the 12at7 (two 1.5k in //, 5.1V on cathode, 320V on plate),
- grounded out the reverb entirely,
- removed the tube,
- added in a cap to the reverb transformer primary and 1k to the 2ndary.
No difference. Which makes me think the reverb may not be the source.
Oh, I'm hitting the driver with 11.8Vrms.
I also tried various caps in places (plate resistors, e.g.), increasing existing cap values, and basically experimented seeing if I could filter off the tone I'm hearing. No joy.
I took the opportunity to solder in a 10k grid resistor to the reverb driver and the 3rd stage grid. Latest schematic attached.
Should I just call it done and play it?
Offline Adrien
« Reply #64 on: June 24, 2026, 09:54:53 am »
Hi guys, been following this thread with interest, a lot of great info here, thanks to everyone who contributed!  I have recently completed a similar project to update my PR.  I originally built it with the Hoffman board and layout probably 10 years ago. I had some issues with a horrible blocking distortion from the reverb driver at higher volumes along with a fair bit of hum.  I also wanted to tidy up some of my old sloppy wiring and less-than-ideal grounding, so decided to do some updates as well with some of the mods in this thread.
The Hoffman layout was a bit easier to modify in terms of power supply and grounding, I added a couple extra power nodes with axial caps along the board, moved the reverb driver power to node C and split the grounding as discussed here among other things.  Was a bit tricky in spots but managed to do it just using existing turrets.
End result is great, MUCH better noise floor overall, the reverb is silent, and the only hum is mechanical from the PT.  As-built schematic is attached, it ended up very similar to what you have Tristan. This also fixed the horrible distortion I originally had which was much worse than what's in your recording, it sounds like what was described in the TDPRI thread you linked (https://www.tdpri.com/threads/silverface-princeton-reverb-reverb-related-distortion.1171963/).
That said, after all these mods I still have a buzzy distortion when cranked, the exact same as your most recent sound sample. The general consensus I've seen is that PRs are not great when cranked, and truly fixing the issue kinda turns it into a different amp...so I think I'll just leave it.  Happy to play it clean and crank my 6v6 Plexi instead  :icon_biggrin:.
Just my 2 cents.  Big thanks to you for documenting your project so thoroughly, it has been a big help to me and I'm sure many others  :thumbsup:
Offline dogburn
  • Meddling Kid (but older)
« Reply #65 on: June 24, 2026, 10:11:34 am »
tristanc - I don't think you need to give up yet. It might help if you did an audio file where you play it loud with the umpleasant distortion and then the same with the reverb tank unplugged, which you said removed it. Then we could really be able to understand what you are talking about. Also, play some chords, and tell us what guitar you are using and what pickup. I recently built a PR with 1-tube reverb and no trem - when I put that back together I will test it some more and compare to your sound files - when first testing that amp, the distortion wasn't very pleasing either, but it may have improved with some of the tweaks I did.
And on another note, I built a Princeton 6G2 a couple of years ago (my first tube amp build), and I didn't like the distortion on that either, but apparently I had biased it too low (calculating based on 12W for a 6v6GT instead of 14W), and when I upped it some, it sounded a lot better. Cold bias can produce unpleasing distortion for sure, so you might want to tweak yours a bit higher to test out.
Offline Adrien
« Reply #66 on: June 24, 2026, 10:20:39 am »
This is a good point, I'll try this too.  One downside I can foresee with a hotter bias is it might weaken the trem somewhat.
« Reply #67 on: June 24, 2026, 10:55:25 am »
This is wild. This number should be safely below the cathode voltage if you want to keep the driver stage happy.
The fact that you are getting an issue without the tube in place though tells me that you're hearing 2 different problems, though. And your most recent observations seem to contradict your prior reports.  I think some is the cathodyne rattyness (a fixed bias arrangement or the "Stokes mod" may be worth a try) and the rest is grid clamping from slamming the driver stage.
Offline tristanc
« Reply #68 on: July 02, 2026, 07:14:08 am »
Thanks for the kind comments and also the comfort that what I have may be 'typical'
This point is key - perhaps this is just 'the sound' of a PR. I'm asking too much to cover both the fender cleans and higher gain power amp distortion. I have a 6V6 plexi (also with 2204 preamp) for higher gain or boosted front end. Stick to the clean + a pedal for OD.
The PR's sweet spot may just be a tad below things start clipping, where the compression kicks in, but not where this annoying buzz / rasp comes in. Other amps the conditions are different. Topologically, jumper out the reverb and turn off the trem, you have a simple amp that should distort nicely / in a way that is pleasing.
I've tried to find examples on youtube where people are playing straight in with the amp on 10. But they tend to have pedals / other things going on.
That is something I could try - I am using JJ 6V6S tubes, so 14W. Worth experimenting with.
I think this is just a fact of the circuit. You turn it up and have a high output guitar you'll hit the reverb hard. But it _should_ take it, to a point. Or at least, this is a factor of the sound.
Yeah - I may have a couple of things going on. To add to things, it had a bit of a drop / rough handling this week and, unless I'm imagining it, the noise floor has increase - hearing a lot more shot noise.
I used the amp on Tuesday night, it sounded great but I didn't play with it much beyond 4/10. So before the onset of the issue.
I'll report back when I have time to experiment. Thanks again for the comments.
« Reply #69 on: July 02, 2026, 10:09:04 am »
That IS the point.  When the grid voltage exceeds the bias offset is when it can no longer take it.
« Last Edit: July 02, 2026, 10:22:39 am by stratomaster »
Offline ac427v
« Reply #70 on: July 05, 2026, 08:35:52 am »
What stratomaster said.
The Fender reverb circuit was never designed to handle that much input voltage. Some form of "Dwell" control is needed to allow this clean amp handle dirty levels of signal.
Bright Idea!??? What if you replaced the Volume control with a dual pot. Use the second section wired in reverse to replace the 1 meg dwell resistor. That would automatically reduce the reverb driver input signal as the volume was increased. No, I have never tried it. Just trying to avoid adding another hole and knob to twiddle.
« Reply #71 on: July 06, 2026, 07:46:39 am »
Stratomaster is right:  the Driver's limit is 6.2v x √2 / 2 = 6.2v x 0.7071 = 4.38v RMS.  The driver is certain to distort after that.
When you have 11.8v RMS to the Driver, how much voltage do you have at the Input Jack?  Is it similar to the ~100mV a guitar pickup might deliver?
Or are you landing in a range of voltage like a heavily-boosted signal post-pedal-boost?
Normally, the Tone Stack and Volume control impose more than enough signal-loss that "high signal to the Driver" is not a big deal (though Reverb does get more-intense with high Volume settings, because there is more-input to the 12AT7 driver).  If your use-case envisions slamming the snot out of the front-end with boosts (which wouldn't sound too great with a blackface Fender unless you retrace all of Randall Smith's steps, and turn it into a Boogie), then maybe ac427v is right & you need a Dwell control to dial-down the signal to the Reverb Driver tube.
« Last Edit: July 06, 2026, 06:17:40 pm by HotBluePlates »
« Reply #72 on: July 06, 2026, 10:49:04 am »
For reference, a stock 64 Super Reverb I serviced last week had about 8.4V on the driver cathodes and a signal of about 3.6Vrms on the grids at the onset of clipping at the speaker (maximum clean output).  Input signal was about 120mV.
11V is just straight up punishment.
Offline dogburn
« Reply #73 on: July 08, 2026, 05:22:58 pm »
If you haven't resolved the issue yet, it may be worth looking at the voltages on the reverb recovery and subsequent triodes. Going back to your schematic and your posted voltages, it looks like your voltage on the reverb recovery is way over the 160V on the Fender schematic, and the final gain stage and the PI are also at quite high voltages. So you may need to up those voltage dropping resistors.
« Reply #74 on: July 15, 2026, 03:21:41 am »
Does adding a 10k grid stop do anything to the tone or overdrive? could it be smaller then 10k?
« Reply #75 on: July 15, 2026, 09:13:44 pm »
No. The input capacitance of a 12AT7, even in parallel, is such that you'd need 100k+ to begin to hear an effect. Plus this is the reverb circuit which is bandwidth limited, so maybe something like 330k would be ok before you hear it.
« Reply #76 on: July 16, 2026, 08:07:18 am »
why 10k? how do you determine the value. on the power tubes they use like 1.5k
« Reply #77 on: July 16, 2026, 09:12:07 am »
Read this: https://www.valvewizard.co.uk/gridstopper.html
« Reply #78 on: July 16, 2026, 10:43:42 am »
ok will read. will that stop oscillation in the reverb section? I get some when i turn the reverb pot.
« Reply #79 on: July 16, 2026, 11:39:14 am »
Probably not. You likely have another problem.  Could be any of a number of things. Is your amp also a Princeton Reverb style?
« Reply #80 on: July 16, 2026, 12:49:56 pm »
yes. i have a new accutronics tank that i heard are not that good anymore. could that be it?
« Reply #81 on: July 16, 2026, 12:51:17 pm »
also.
before i added grid stop resistors to the power tubes and that seemed to fix the problems. but i didnt like the effect on the overdrive so i removed them. it seemed to make the amp clean and then overdrive at the louder volume instead of having the overdrive mixed from the beginning.
« Reply #82 on: July 16, 2026, 08:46:29 pm »
It's possible the tank has an issue, or the problem is the placement.  Make sure the connections are facing the speaker baffle.  You can also try moving the tank outside of the amp temporarily to see if it's coupling to the speaker or cab.  Sometimes the issue is the transducers being loose.  A dab of E6000 or even neutral cure silicone can take care of that.  Or you may need a padded reverb bag.
also.
It's unlikely that you heard a real effect or you have some other issue.  You can measure the output power at the onset of clipping with and without the grid stoppers and compare them to see if your ears were lying to you or not.
« Last Edit: July 18, 2026, 11:22:24 am by stratomaster »
« Reply #83 on: July 17, 2026, 07:51:01 am »
not sure it seemed to be different. like i said the amp sounded more clean less hairy.
« Reply #84 on: July 18, 2026, 08:57:47 am »
What do you mean not good, how so?
Offline tristanc
« Reply #85 on: July 20, 2026, 10:12:56 am »
An update from me - I've done little-to-no tweaking and just used the amp.
What I did do was listen to this video: https://youtu.be/CMps8xUBC2E?si=lwB2VXWQnwNyEN4e
Specifically these sections where the amp is on 10.
Strat: https://youtu.be/CMps8xUBC2E?t=1811&si=eG0lHkTMcCMhaVDI
LP: https://youtu.be/CMps8xUBC2E?t=1918&si=oZ0681HI2L_hF9NB
Tele: https://youtu.be/CMps8xUBC2E?t=2030&si=Sk4LZ4Rhrec5Qms9
Playing along at home, living room volume, through my attenuator, I think I get a very similar sound / distortion characteristic. I'll try and record some parts to do a comparison. So perhaps this is just The Sound of the Princeton and I'm over thinking it. And maybe the sweet spot of the amp is at 5/10 and drive should come from somewhere else.
To that extent, I bought a BD-2 clone to add a bit of drive at lower volume and the combo sounds great - especially with the Celestion Neo Creamback speaker I swapped in.
One finding was that at 'playing with a drummer' volume (4/10) I had to turn the gain on the pedal way down, compared to playing at home through an attenuator - perhaps the speaker coming in to play.
I'm still loving the amp. Love the form factor, the cleans at the point that things start compressing, and the reverb / trem. I wish I had built some of my other amps in to this form factor - particularly the higher gain ones.
« Reply #86 on: July 20, 2026, 01:34:45 pm »
they say you get a weak reverb from it. they use a press on wire for the transducer i guess. not sure why but thats what i hear.
Offline Carlsoti
« Reply #87 on: July 20, 2026, 09:12:40 pm »
You're unlikely to get the deep drip of an old Gibbs pan with a new one from any manufacturer. That's just the way things are. I don't futz with old broken reverb pans anymore. The juice is not worth the squeeze.
Offline acheld
« Reply #88 on: July 21, 2026, 12:05:01 pm »
I agree with this statement.  At least in my hands, I can't seem to get what I want out of a reverb unit built into my amp builds.  It may well be my own lack of expertise, but I've given up on the idea of true old school reverb in favor of using pedals to enhance my tone.
Offline tristanc
« Reply #89 on: July 27, 2026, 06:56:55 am »
I couldn't leave it alone....
• Reflowed basically all the joints. No difference.
• Tried playing with the bias again, on the assumption that perhaps there is cross-over distortion. Potential improvement. Instead of aiming for 70% I went to 80% That _seems_ to have made the issue less noticeable.
• Modified the reverb mixing components - the 3Meg and 10pF - based on a forum post of someone describing a similar distortion issue. Potential improvement. I clipped in a 68pF across the 3Meg (so 78pF) and to my ear, the extra treble made things sound better at 10/10 and provided just a bit more bite at lower volumes. The extra bite can be taken away with the treble control. It may be masking the harsh distortion, though.
• Clipping in a 1Meg in parallel just made things louder and the reverb not so good.
So I'm going to leave it biased hot for a few days and see how I get on. Next up, replacing the 10pF with a 68pF - may have to simulate that to see the implication...
