September 08, 2026, 04:41:08 pm
Hoffman Amps Forum image Author Topic: Where to ground the first filter cap?  (Read 8269 times)
Offline wsscott
« on: December 31, 2025, 03:53:43 pm »
I recently read an article on grounding by Aiken Amplification, and am now confused on what I think should be a simple task in building a tube amp.  And that is where to physically ground the first filter cap.
I'm assuming when he says the "first filter cap", he's literally talking about the very first filter cap, ie. the reservoir cap.  The article says when using a ground buss (assume the buss is connected to ground at the input jack), to ground the PT's secondary's CT directly to the ground lead of the first filter cap-not to anywhere else on the ground buss or you will get 120hz hum.  I'm assuming that ground lead is then connected directly to the buss. Or maybe I'm wrong about grounding it using the buss.
So is connecting the CT lead to the filter cap's ground lead vs. connecting the CT lead directly to the ground buss an important distinction, or am I just reading the comment too literally?
And, as a follow up, is there any problem with connecting all of the remaining filter cap ground leads to the buss at different locations along the buss?
Thanks.
Offline dmp
Re: Where to ground the first filter cap?
« Reply #1 on: December 31, 2025, 04:18:32 pm »
This is Merlin's chapter on grounding: https://www.valvewizard.co.uk/Grounding.pdf
Fig 15.10
The transformer CT and the filter cap ground lead connect together to the ground bus (I usually use heavy gauge, ~10awg, copper wire for the bus). Then filter caps for stages connect near the tube cathode connections. Finally the bus connects to the input jack. Grounding is not a simple task - it has caused many headaches. A quiet amp can be hard to achieve.
« Last Edit: January 02, 2026, 09:36:08 am by dmp »
« Reply #2 on: December 31, 2025, 04:59:25 pm »
Did Aiken have a schematic example?
the 1st filter cap is the dirty AC, you want it and the PT/rec grounded "Away from" everyone else.
this is a snippet from a 4MB PDF the title is in the middle, hunt it up, read it, understand it, and you'll be the best ground-gremlin hunter in your state  :icon_biggrin:
Offline wsscott
« Reply #3 on: January 01, 2026, 07:11:42 am »
Thanks guys. This is very helpful.
No, Aiken didn’t show a diagram or other type of schematic in the discussion.
Happy New Year too!
« Reply #4 on: January 01, 2026, 09:19:39 pm »
... I'm assuming when he says the "first filter cap", he's literally talking about the very first filter cap, ie. the reservoir cap.  The article says when using a ground buss (assume the buss is connected to ground at the input jack), to ground the PT's secondary's CT directly to the ground lead of the first filter cap-not to anywhere else on the ground buss ...
Assume the "Ground Buss" is a thick copper bar.
Connect the Power Transformer Secondary Center-tap to the copper bar.
Connect the 1st Filter Cap Negative lead to the same spot on the copper bar (right beside the CT).
Connect the copper bar to Ground (doesn't really matter what part of the bar gets grounded).
Aiken's point was to have the current-path of the power transformer and filter-cap make the smallest possible loop:
  PT Secondary Winding-End -> Filter Cap Positive -> Filter Cap Negative -> PT Secondary Center-Tap -> PT Secondary Winding-End -> Repeat
Do this for your entire power supply (make the current-loop as short and direct as possible), and you will avoid most hum/oscillation/strange-interactions.
Offline wsscott
« Reply #5 on: January 02, 2026, 11:03:31 am »
If you were going to build an amp from scratch, based on an existing schematic like a Fender, Magnatone, etc.,  that you might modify some, would it be a best practice to install the filter caps on the eyelet/turret board as close as possible to the component that it serves first, rather than having all the filter caps in a doghouse, or all at one end of the circuit board, or in a cap can?  This might result in the leads connecting between the filter caps and balancing resistors being longer than if all of the caps were next to each other, or maybe not.  Seems like it might be better for a filter cap to be closer to its associated component connection rather than having a longer flying lead wire.
Would the type of grounding system to be used, ie. buss bar or a single or multiple star system, have any impact on the filter cap location?
Thanks.
« Reply #6 on: January 02, 2026, 12:11:27 pm »
I typically put the caps "onboard" vs doghouse.  that's not just to keep the loops small, it's easier to measure/troubleshoot when "B+" is located close to the circuit it feeds, otherwise you're eyes get all cris-crossy following mystery wires back to the source  :icon_biggrin:
Offline wsscott
« Reply #7 on: January 02, 2026, 12:45:47 pm »
Yea, that's nice looking, and easily accessible.  I like that layout.
What amp is it?
« Reply #8 on: January 02, 2026, 03:04:00 pm »
my last amp, a tinker's special  :icon_biggrin:
search me n "Christian Delight" to find the build thread
it's a steal from Steve that drew up a cleaner version of a Silvertone 1482 for Platefire I believe
Offline AlNewman
« Reply #9 on: January 02, 2026, 07:59:22 pm »
The funny thing that Fender did with caps in the doghouse was install the brass plate, which although it allowed crosstalk between the chassis and circuit, it created a 'buswire' between power amp and input.
If you look at Fender's layout, all the solder connections to the brass plate are at convenient points in the circuit.  Basically, you could follow their layout with isolated pots and board mounted filter caps, and stay true to a modern grounding system if you position the ground points where they are on the brass plate.
I see a lot of people not having success with buswires, because they don't follow what Fender laid out 60 years ago.
Maybe with a high gain amp, with several different channels and gain stages the brass plate (chassis) would no longer serve it's purpose, but on the other hand you would have to position everything absolutely perfect if a buswire was your only path to ground.
Of course, reading and learning from people smarter than us, it makes complete sense to separate the different stages of filtering along a linear path.
« Reply #10 on: January 03, 2026, 06:00:04 pm »
See:
1.  Merlin's website on grounding.
2.  psionic audio's youtube series on grounding (who acknowledges Merlin):
&t=29s
« Reply #11 on: January 06, 2026, 07:24:27 am »
Yes.
Read Merlin's grounding, he has drawings in there.
Yes.
Read Merlin's grounding. HBP's small loops.
Multi star system.
Akin is the same, so is Kevin O'Connor London Power TUT books.
« Reply #12 on: January 06, 2026, 07:26:11 am »
The 1st filter cap/PT CT loop has the largest charging pulses in the amp. So it's the dirtiest connection in the amp.
Like already said, connect the PT CT directly to the 1st filter caps ground lead. NOTHING else there. This lets the cap's charging pulses flow in that small loop by themselves. They will not modulate any other circuit in the amp by doing this. The charging pulses are isolated from the other circuitry.
Then you run a single wire from the PT CT and 1st filter caps ground lead connection as a buss over to the next ground star with it's filter cap located at the circuitry it feeds, ie, make a filter cap ground star. You go from 1 ground star to the next ground star to the next, etc.
This way each filter cap has it's own small loop ground star that's charging current's are isolated from the other star's.
« Last Edit: January 06, 2026, 07:39:20 am by Willabe »
« Reply #13 on: January 06, 2026, 09:16:52 am »
... Then you run a single wire from the PT CT and 1st filter caps ground lead connection as a buss over to the next ground star with it's filter cap located at the circuitry it feeds, ie, make a filter cap ground star. You go from 1 ground star to the next ground star to the next, etc.
That's a great description of the multiple star ground system associated with Merlin, but both the accompanying images in the post seem to show chassis connections at the star points, such that the chassis, rather than a wire / bus, links the stars together.
Merlin advises only one connection between the multiple star ground system and the chassis, made very close to the input socket.
« Reply #14 on: January 06, 2026, 01:38:02 pm »
Nope, look again, only 1 chassis ground connection.
PDF, as many times as I've posted about Merlin's multi star grounding and helped people redo their grounding, I'm surprised you would say this. Guess my drawings not as clear as I thought? But it wouldn't make any sense to talk about a multi star ground and then post drawings using random chassis grounding.
In the schematic look at the 1st filter cap's ground lead, it's labeled as chassis ground.
I tried to show the individual stars by group number. Follow the PT power supply filter cap series string buss ground wire. They correspond to the circuit ground star component grouping above the power supply filter cap series string. It's the best I could think off. Maybe I should have turned the arrows the other way?  :dontknow:
In the schematic, the circuit ground star component grouping for 2, 3 and 4 are not going to the chassis. Those are supposed to be arrows pointing to the ground star number, not actually showing a chassis ground. I just labeled them that way to line them up with the numbered power supply filter cap ground leads.
In the layout, it shows 1st filter cap chassis ground at a PT bolt. I should have labeled the input and output jacks as isolated. But you can see the jack ground lug on both of them has a ground wire that goes back to the circuit ground star related to them. (I need to fix the PT chassis bolt ground in the layout. I never use a PT bolt for chassis ground. I use a dedicated bolt for the chassis ground.)
On any of my builds, I use a single chassis circuit ground connection. But I think in many amps using 1 chassis ground for the power tubes ground star and a 2nd for the preamp ground star is fine too.
« Last Edit: January 06, 2026, 02:27:50 pm by Willabe »
Offline jbrew73
« Reply #15 on: January 11, 2026, 03:55:14 pm »
Willabe
Are you grounding the buss at only one point? Is it at the first filter cap end of the buss?
I’ve been reading a little on grounding lately and maybe I am misunderstanding but I thought you only grounded the buss at the input jack/last filter cap end.
« Reply #16 on: January 12, 2026, 10:07:06 am »
Yes. Only 1 point and it was at the 1st filter cap end of the buss.
You should re-read my post and my response to PDF.
...... In the schematic look at the 1st filter cap's ground lead, it's labeled as chassis ground.
But, I connect the 1st filter caps ground lead directly to the PT's CT. Then I run a single wire from that connection over to the buss. That way the charging currents for the 1st filter cap can go round and round with it's charging source, the PT B+ wind, which gets rectified to DCV, then going back through the PT's B+ CT, in their own little loop. And that way they don't disturb/modulate any other circuits.
The loop is; PT B+ rectified DCV charging pulse charges filter cap, then through the filter caps ground lead back into the PT's CT back through the PT's B+ wind. Round and round it goes.
Said another way, because this keeps that large dirty charging current/pulses off of and there by from being injected onto/into the chassis. In turn this keeps other weaker circuits ground lead from being modulated by this large/strong charging current. Because that large/dirty charging current can/will get injected into a weaker circuits ground chassis connection. It gets superimposed onto the other weaker circuits ac (audio) signal. S/N ratio comes into play. Large noise signal being injected/superimposed over a smaller signal.
Many say the best place to ground the amps ground buss is at the input jack, when only using 1 chassis ground. Kevin O'Connor has said he likes to ground the ground buss somewhere in the middle of the buss, by/just before the PI. Because the input signal is so small.
Many guys ground split the ground buss into 2 sections.
1. The power amp
2. The preamp.
So they have 2 separate chassis grounds. This also works great.
The most important thing to get grounded correctly is;
The noisiest/dirtiest connection in the amp is the ground lead from the 1st filter cap because it has the largest charging current.
So if you give that ground lead and it's charging source their own little loop your killing off the largest ground noise source in the amp.
Merlin, Kevin O'Connor, R. Aiken, R. Robinette and other all agree on this.
Look at Merlin's fig. 14.14, 14.16, 14.17;
https://www.aikenamps.com/index.php/grounding
« Last Edit: January 12, 2026, 10:19:45 am by Willabe »
Offline wsscott
« Reply #17 on: January 12, 2026, 11:07:25 am »
Willabe, if the connection where the PT’s CT and the Ground/Negative lead of the First filter cap meet is then wired to the main Ground Buss wire that is ultimately connected only at 1 place to chassis ground, why doesn’t that dirty first filter cap connection then make everything else connected to that ground buss wire dirty too?
« Reply #18 on: January 12, 2026, 06:23:20 pm »
wsscott:  there's no one answer.  Willabe is a successful & experienced builder.  Others would ground the 1st filter stage to the Center Tap and Nothing Else there - no connection to a grounding bus or anything else.  Doug Hoffman uses a ground bus soldered to the rear of the pot bodies. Psionic Audio would not do that. Cap cans often get grounded where the can body is.  Etc., etc.
For Hi Gain Amps, the grounding scheme is significant to a quiet amp.  For low gain amps, Fender, e.g., got away with murder - and had quiet amps.
You've been pointed is several "right" directions and need to make your own choice.
« Reply #19 on: January 12, 2026, 06:56:13 pm »
You need to re-read what I wrote.
Because of the buss wire.
1st filter cap/PT CT ground star/small loop - buss wire to next ground star - ground star/small loop - buss wire to next ground star - ground star/small loop - buss wire end connected to chassis.
You form a small loop with with the 1st filter caps ground lead and the PT CT. That lets the current go round and round all it wants by itself in that loop.
Then you run a single separate wire from that loop cap ground lead/PT CT, so the loop is isolated from from anything else by that single wire.
The buss does the same thing. You make a ground star with all the ground connections from a circuit and the filter cap's ground lead that feeds that circuit.
And you run a buss wire to/from each individual ground star.
The ground star is a small loop, that is isolated from the other ground stars by the ground buss wire.
It's that simple.
Read Merlin's grounding, it's all in there.
« Reply #20 on: January 12, 2026, 07:02:22 pm »
.... Others would ground the 1st filter stage to the Center Tap and Nothing Else there - no connection to a grounding bus or anything else.
I told him about that grounding scheme in my reply #16;
1. The power amp
2. The preamp.
« Reply #21 on: January 12, 2026, 07:26:55 pm »
Look at Merlin's Fig. 14.11 a/b. It shows the 'improved' small loop in b. And it knows how to win. Look at the short green wire in 14.11b, how it isolates the loop from the other ground stars on the ground buss.
Fig. 14.12 shows power supply current loop.
Fig. 14.13 shows 2 separate ground stars being brought together at the common B+ supply filter feeding them.
Also look at/study;
Fig. 14.14b, Fig. 14.16, Fig. 14.17, Fig. 14.18
The information is all there;
« Last Edit: January 13, 2026, 12:03:04 pm by Willabe »
Offline wsscott
« Reply #22 on: January 19, 2026, 11:06:51 am »
Willabe-I'm using a ground buss wire that only connects to ground on the Input jack end.  I've got 4 filter caps at the far left end of the chassis, and wires run from their Nodes to various points in the circuit which are at various points on the circuit board.  I understand that its best to have a star ground for each Node in the circuit that connects to only one point on the ground buss, but because the components for some of the nodes are at the Input Jack end of the chassis, it results in several long wires, maybe 5" or a little less in length, being run to get to that Node's star grounding point on the buss.
So I wanted to know if it would be better for me in an effort to reduce hum, to keep those ground wires as short as possible and just ground them directly to the buss near the component, rather than running them back to that star ground where there might be, in some instances, 4-5 wires coming into the star.
Thanks for your help.
« Reply #23 on: January 20, 2026, 12:51:32 am »
Your wording is throwing me off. But if I'm understanding this right;
What does it show/say in Merlin's grounding page? Look at the drawings.
Fig. 14:14 a and 14:14b answers your question.
14:14b shows the improved ground star/ground buss wiring. That's how you want to wire it up. Including with the filter cap right there at the circuit it feeds. Not back on the far end of the chassis by the PT like Fender did.
If you ground a component as soon as you can to the buss instead of running a wire from the component over to the buss. Then even though you shortened the ground wire from the component, now the buss wire is doing the same as the wire. So it's still just as long as it was.
I'd rather get the component grounds gathered together closely at 1 point and have the filter cap that feeds it right there at that ground star. So all those component ground leads and the filter cap ground lead come together at 1 point on the ground buss.
And the way the 1st filter cap ground lead is wired up is the most important ground to get right.
... but because the components for some of the nodes are at the Input Jack end of the chassis, it results in several long wires, maybe 5" or a little less in length, being run to get to that Node's star grounding point on the buss.
Because their long, you have to watch out for what other wires are they running close too or along side of?
All ways better to keep wires short if possible so there's no cross talk/interference with other wires. So short ground loops are best practice when possible.
It's part of doing your layout.
Offline wsscott
« Reply #24 on: January 20, 2026, 11:35:27 am »
Thanks.  I wired them like 14.14b.  It's just that a couple of the leads from the components to where I could put one of the star grounds are pretty long, and I didn't know if that was factor to consider.
I understand the concept that a short lead isn't really short if it still has to go a long way on the buss to get to the filter cap lead.
