September 08, 2026, 04:41:41 pm
Hoffman Amps Forum image Author Topic: Grid Bias Versus Cathode Question  (Read 6342 times)
Offline apeontheweb
« on: April 03, 2026, 08:39:01 am »
I have a 5E3 kit that is cathode biased. I played through it and AB'd it with Fender's Eric Clapton Vibro-lux which is the 5E3 but the power section is grid biased. I couldn't really hear a difference which surprised me. I began to think maybe the type of biasing an amp uses isn't that important to the sound. My question is : what are some of the sonic differences someone might expect to hear when comparing an amplifier that is grid biased versus one that is cathode biased?
Offline acheld
Re: Grid Bias Versus Cathode Question
« Reply #1 on: April 03, 2026, 10:10:18 am »
It's a good question that I've had myself.
For a long time I had a thing for Blues Juniors.  Simple amp, sounds good.  For the first three Fender factory versions they were fixed bias -- but typically voiced hot from the factory.   Sometimes, a set of EL84's would last for (literally) a couple of months.
I built a number of clones, but voiced much cooler with adjustable fixed bias, and the EL84s last forever (well, long enough!).  When the BJ IV came along, Fender changed the biasing scheme to cathode biased.   So I built a couple of these -- and to me, all of them sound the same.  Bear in mind I'm an old guy . . .
I'm sure in some applications it probably does make a difference, and maybe some of our members can make some sense of it.
To me, though, voicing an amp means using the sum of all the parts, not just one of them.
Offline passaloutre
« Reply #2 on: April 03, 2026, 10:16:50 am »
I’ve built a couple amps where I tried both, and couldn’t hear much difference. My uneducated takeaway is that the headroom would be the biggest difference. Cathode bias uses up some of your B+ headroom to bias the tube, so there’s less available for signal swing. This can be a good thing, if you want less power out of the amp. Tone wise, I don’t hear much difference as long as each is done correctly.
I like cathode bias because it’s easy to implement and I don’t need a lot of headroom, but I’ve got some fixed bias amps I really love too, and they don’t put off as much heat out of the chassis.
« Reply #3 on: April 03, 2026, 10:21:21 am »
i'm a tech/engineer with a deaf ear n zero musical talent.. so....
self-biased amps tent to emphasize odd harmonic while PP amps, even (that could be backwards, I'm dyslexic:)
self biased amps lime to operate in Class A, "Clean"  they get sorta cranky when driven into A/B, the distortion can be pretty "non-musical"
one of the better comments from my test-guitarists;
"Your amp is so clean, I have to be a better guitar player, I can't hide my mistakes in the distortion"
SE amps take pedals well, pre-amp distortion well
lunch is calling....
« Reply #4 on: April 07, 2026, 01:24:41 pm »
I have a 5E3 kit that is cathode biased. I played through it and AB'd it with Fender's Eric Clapton Vibro-lux which is the 5E3 but the power section is grid biased. I couldn't really hear a difference which surprised me. I began to think maybe the type of biasing an amp uses isn't that important to the sound. ...
TLDR:  Fixed-bias on a Class A amp will sound basically the same as Cathode-bias on a Class A amp, especially if the power supply and other stuff is the same.  But trying to Cathode-bias an amp that otherwise was optimized to run as a Class AB amp making large output power will result in obvious sag/squish/sonic-difference.  And often amps that allow use of both bias methods aren't trying to intentionally hobble one bias setting for a sonic-effect.
Bias Method alone doesn't dictate sound, though cathode bias cannot be used far into Class AB.
Class A idling at 100% plate dissipation means the tube swings from "Idle Current" to "About Double Idle Current" and down to "Almost Zero Current."
   - Full Power Current from the power supply is nearly the same as Zero (or Idle) Power Current drawn from the power supply.  So power supplies are lightly-built.
   - Find the "Average Current" over the signal cycle, and it is roughly the same as the Idle/Zero-Power Current.  So bias volts across the cathode resistor stays essentially constant.
   - Tube Rectifiers can be used with impunity in Class A amps because the more-constant current-draw means less voltage-change across the rectifier from idle to full-power.
   - Any sense of "sag" mostly comes from pushing beyond max clean output power:
     - The 5E3 strays a little beyond Class A into Class AB, but only at max power and/or when distorting.
     - If one side tries to pull much more than 2x idle current, this creates a bigger bias voltage-drop across the cathode resistor, which reduces plate current.
     - High current-draw drains the charge from the filter caps, maybe faster than they can be recharged, especially when filter caps are small-ish (like 16µF).
Class B amps theoretically idle at zero plate current, and swing to very high peak plate current.  Class AB amps are "something between Class A and Class B" so higher power Class AB amps pull a peak plate current very much higher than 2x idle current.
   - Because the peak plate current might jump up to 3-4 times idle current in a Class AB amp, cathode bias is infeasible because the bias voltage developed would counteract the plate current.  So fixed bias (higher parts count, more expensive, less safety) only really gets used on higher-power Class AB amps.
   - Big swings in current-draw from idle to full-power means the bigger Class AB amps will tend to solid-state rectifiers to limit power supply voltage sag (as that tends to counteract power output).
   - Big swings in current-draw from idle to full-power means the bigger Class AB amps will generally get stiffer power supplies with more, and larger, filter caps to deliver those big current peaks.  Which also means less voltage-sag (except for the earlier 1960s-style amps that might still have smaller filter caps, even with Class AB).
I know we "all" ignore bias voltage from grid-to-cathode these days, but we shouldn't.
   - The early 1950s 5B6 Bassman biased its barely-into-Class-AB 5881s with -27v grid-to-cathode.
   - The mid 1960s AB763 Super Reverb biased its 6L6GCs with -52v grid-to-cathode.
   - If you tried to develop a large bias voltage of 52v for the Super Reverb with a cathode resistor to tame its idle current, it would squish and compress like hell when driven hard enough to shut one side off (after which the average plate current rises above total idle current), and the cathode resistor began developing a large counteracting-voltage that would constrain plate current.
Some amps offer both bias options but try to keep "all else the same," and if all else really is the same then there's no real sonic difference.  Sonic differences arise when "all else is not the same."
« Last Edit: April 20, 2026, 05:33:25 am by HotBluePlates »
« Reply #5 on: April 08, 2026, 09:42:10 am »
So what amps do compress the signal more than others?
How do we design an amp that will respond with more tube and power supply compression for sustain?
Can we use K bias as part of that tube compression?
Offline passaloutre
« Reply #6 on: April 08, 2026, 02:49:13 pm »
Well there are other ways to compress besides the power supply, but looking at HBP’s post it sounds like you get max compression out of a deep-Class AB amp (so preferably fixed bias) with tube rectifier (or some series “sag” resistance) and smaller filter caps. Class AB means it will demand more current under high drive, and the tube rectifier will drop supply voltage when the current goes up.
« Reply #7 on: April 09, 2026, 04:10:46 am »
Aiken uses the terms sag and squish to describe the mechanisms behind this https://www.aikenamps.com/index.php/what-is-sag
It's not feasible from a schematic etc to assess how much the voltage output of the mains transformer HT winding will reduce at high / extreme loads. Transformers designs from the valve rectifier era (and modern designs intended to recreate that) typically use thinner wire for the HT winding, as valve rectifiers require the 'protecting resistance' this provides.
The Vox AC30 is an example of a design that uses a contribution from all 3 mechanisms to generate what to me is a significant degree of compression at high power outputs.
For both fixed and cathode bias, I suspect bias shift / excursion at output valve grids also contributes to the compression effect.
https://www.ampbooks.com/mobile/amplifier-calculators/bias-excursion/
« Last Edit: April 09, 2026, 05:59:56 am by pdf64 »
« Reply #8 on: April 09, 2026, 08:52:59 am »
Thank you PDF.
From the Aiken link you posted;
Another term: "squish">An effect similar to sag is produced by cathode-biased amplifiers because the increased current through the power tubes increases the voltage drop across the bias resistor, which in turn decreases the current through the tube, with a time constant dependent upon the size of the bypass capacitor in relation to the cathode resistance.  This compression effect is commonly referred to as "squish" to differentiate it from "sag", which applies only to compression induced by power supply droop.  "Squish" also is used when referring to the effect produced by the transient recovery time of AC-coupled amplifier stages.  A sharp transient temporarily increases the effective negative bias, and the time constant of the RC coupling determines the recovery time following the transient.  Long time constants caused by large coupling capacitors in conjunction with large grid resistor values will increase the amount of squish in an amplifier.  Too long a recovery time leads to "blocking" distortion.  This is why it is not a good idea to use overly large coupling capacitors in the output stage of a guitar amplifier.
« Reply #9 on: April 20, 2026, 05:42:51 am »
I have an Ampeg Reverberocket from the early 60s that compresses more than any amp I've ever heard.
Yes, it is cathode-biased, but it seems more than a 5E3 Deluxe copy, despite having substantially the same power section and slightly beefier filter caps.
I haven't analyzed the circuit to figure out why it compresses so much, but I suspect it is a result of how the reverb circuit passes the Dry signal from the cathode of one section of V2 to the cathode of the second section of V2.  That's because the apparent compression happens even at low volume, and without the power section being driven hard.  However, I would need some kind of pulse generator to spot peak signals being compressed.
