September 08, 2026, 04:40:51 pm
Hoffman Amps Forum image Author Topic: Seeking Bias Checker Input  (Read 6371 times)
Offline RoadShow
  • Disturbing the Peace Since 1955
« on: April 03, 2026, 10:22:56 am »
Hi folks,
I wanted to get a couple of bias checkers for my factory amps such as my TRRI.  Anything i've built has the 1 ohm set up.
Here are the ones I know of:
https://el34world.com/charts/BiasChecker3.htm Hoffman checker
https://mojotone.com/products/mojotone-bias-checker-kit-by-hoffman-amps?variant=41689714360416 The Hoffman checker
https://rubytubes.com/products/ruby-bias-probe?_pos=1&_sid=1a47b5cf6&_ss=r Ruby Tubes
https://grangeramp.com/product/bias-probe-current-measuring/ Granger
https://www.tubedepot.com/products/tubedepot-bias-scout-kit Tube Depot
and a wide variety on Amazon, of course.
Any others you know of or would recommend?
Anything you like or don't like about any of these or other?
Right now I'm leaning towards the Tube Depot because it also allows you to read the plate voltage.
Here's a Youtube vid where he has added a black switch box to select between the cathode and plate readings:
https://www.youtube.com/watch?v=A-VtdXYgceA
I think this is a nice feature to add in.
Thanks...
Offline Merlin
Re: Seeking Bias Checker Input
« Reply #1 on: April 03, 2026, 11:02:31 am »
Personally I would not condone a bias probe that requires a separate ammeter, it is a recipe for mistakes. Ideally all those bias probes would include a 1 ohm resistor so that a separate voltmeter can be used instead, but nobody seems to make them that way. Apart from that, I guess the Tube Depot one is the more useful option. The TAD and Eurotubes bias probes avoid mistakes by having their own dedicated meters.
Offline RoadShow
« Reply #2 on: April 03, 2026, 11:18:20 am »
Thanks for the reply.
This is the Tube Depot schematic and uses the 1 ohm resistor and HV conversion that has been discussed in the past and relies on reading mV and not as an ammeter.
Offline stratomaster
  • Don't guess, measure.
« Reply #3 on: April 03, 2026, 11:53:55 am »
Why 2W and 5% when checking idle current?
A 1/4W at 1% or better is smaller, more than enough power handling, and much more accurate.
Why spec 1% resistors for plate voltage, but not cathode current?
Odd choice.
Offline RoadShow
« Reply #4 on: April 03, 2026, 01:25:26 pm »
Odd choice.
Yeah,
I don't know.
I can't explain my wife or kids, how am I able to explain that?
Offline BrianS
« Reply #5 on: April 03, 2026, 03:23:25 pm »
As a busy repair tech, I use the TAD Biasmaster.  Works very well; keeps the bench tidy and my Fluke free to measure voltages throughout the amp.  Might be overkill if all you are doing is checking & setting bias on your personal amps, but is a nice tool.
Offline AlNewman
« Reply #6 on: April 03, 2026, 03:26:40 pm »
Odd choice.
Probably to make the meter bulletproof.  They're in the business of protecting their meter, not necessarily the tube or the amp.
Offline RoadShow
« Reply #7 on: April 03, 2026, 04:06:28 pm »
The nice thing about that Bias Master is you can basically do a sweep of all 4 tubes with the rotary switch.  Nice.
I just looked, Amplified Parts carries it in the USA, but they're OOS.
« Reply #8 on: April 07, 2026, 12:53:42 pm »
I use the Eurotubes Pro One.  Yes, they are expensive, but you're basically buying a couple of meters at the same time.
I initially got the standard version, then later bought the watts-version when getting some for EL84s.
I have checked them, and they measure Plate Volts and Plate Current at the plate pin, not cathode current.  I like not having to account for screen current (even if that is typically an error in a safe direction).
« Reply #9 on: April 08, 2026, 03:12:45 am »
It horrifies me how it seems all  vendors selling anode voltage / current probe devices are comfortable providing unshrouded plugs for the meter.
I acknowledge that shrouded plugs add maybe a £/$/€ or 2 to the parts cost, but these things are often marketed to regular valve amp users, not necessarily technically cognisant of how to mitigate the shock hazard (which to me necessitates the use of shrouded plugs anyway).
« Reply #10 on: April 08, 2026, 12:13:47 pm »
I think the rationale, at least with the Tube Depot one, is that there's a 9.999e-5 voltage divider, so there's no high voltage present. I believe I've come across the designer of that probe on another forum explaining this design decision with safety and cost both in mind.  He also conceded that there will likely be user error in the reading and conversion of the mV scale measurement to equivalent full voltage, but was unwilling to put half a volt or so on an exposed plug. So it was a necessary tradeoff.
