September 08, 2026, 04:41:14 pm
Hoffman Amps Forum image Author Topic: 5f2a reverb design  (Read 3988 times)
Offline tomojt
5f2a reverb design
« on: May 21, 2026, 06:40:24 am »
hi, im planning on building a pretty heavily modified 5f2a/5f1/ga5.a and im wondering if i should ad a spring reverb to it cuz i like my reverb in the amp and i actually wanna use this amp daily.
the thing is i dont want to add any tubes to it. i figured a jfet buffer going from the 22nf coupling cap after the second 12ax7 triode going into a tda2030 spring tank driver. the recovery circuit would be a tl072 simple op amp and then a mix pot with a mixing resistor. The whole thing would basically be in a parallel fx loop if i understand it correctly.
thats is my current plan on doing it but i wanted any suggestions or comments on this and if this would even work.
ive attached a screenshot from my schematic and have drawn onto it the concept how id insert it in.
im happy to hear any comment or critique.
thanks
Re: 5f2a reverb design
« Reply #1 on: May 21, 2026, 09:45:00 am »
Look in here for 1 tube reverb ideas;
https://el34world.com/Forum/index.php?topic=7957.0
Offline tomojt
« Reply #2 on: May 22, 2026, 05:54:42 am »
update: ive found out about the tube town LNDverb kit. any help woth inserting it and how to not eliminato tone suck if there is any?
« Reply #3 on: May 22, 2026, 11:35:54 am »
Seems that here you can find interesting info
https://el34world.com/Forum/index.php?topic=9819.0
