September 08, 2026, 04:21:47 pm
Hoffman Amps Forum image Author Topic: Heathkit T3 signal tracer  (Read 10827 times)
Offline goldstache
« on: May 29, 2026, 07:32:13 am »
I got one of these going. Been great.
But I have a question.
The unit is a kit build, no mains fuse, 2 prong similar blade power cable.
When I plug the unit into mains, the optical magic eye indicator only responds with the heathkit T3 is antiphase plugged in.
(Dmm in AC, across the T3 and a grounded device, shows mains potential across units)
So with mains polarity aligned, T3 doesn’t illustrate readings optically, and even sig trace responds differently.
What’s up here. I mean the magic eye is an AC driven stage, so I wouldn’t think mains ac polarity would matter.
Should I just swap PT primary for the DC supply transformer? And how do I observe the wattage series setup when trying to iron out.
Schemo attached
Offline goldstache
Re: Heathkit T3 signal tracer
« Reply #1 on: May 29, 2026, 07:52:44 am »
« Reply #2 on: June 07, 2026, 12:22:15 pm »
... What’s up here. I mean the magic eye is an AC driven stage, so I wouldn’t think ... polarity would matter. ...
Electrons cannot flow from Plate to Cathode.
Tube (magic-eye or otherwise) passes no current unless electrons "boil out" of a hot cathode and get pulled to a Positive-Plate (with a few non-relevant exceptions).
We cannot reverse current-direction through a vacuum tube, so think of them first as "diodes" with one-way current.
We only get "AC" when our one-way current gets bigger/smaller, and we strip off the large DC part of that changing-current with a blocking capacitor.
So from an initial thought, polarity always matters.
I wonder if you removed the "death cap" (0.05µF to ground at the PowerSwitch on the schematic).
That cap strips off RF noise riding on the line, and puts XC = 1 / (2 x π x 0.05µ x 120Hz) = ~26.5kΩ between one side of the line and Chassis.
If you added a 3-prong cord and removed that cap the "other side" of the line should theoretically be bonded to chassis/Ground at the service panel (is it?  :dontknow:).
I am coming around to the nothing that "Death Cap" is a bogus-warning in the era of plastic caps (of the mid-60s blue "Ajax" caps in Fender or later), but that paper-dielectric caps and a few very early plastic caps cannot be trusted.  Modern Class Y caps may be "metallized paper" but they are rated for safe-failure when connected from Line-to-Ground (they are guaranteed to fail-open, and never fail-short).
So that's one aspect that might be relevant to your observation.  The other is:
The unit is a kit build ... 2 prong similar blade power cable.
So with mains polarity aligned, T3 doesn’t illustrate readings optically ...
... I wouldn’t think mains ac polarity would matter.
Should I just swap PT primary for the ... transformer? ...
I hadn't read the manual, but I see there is a "3rd Setting" that disconnects the Audio Input from the 1629, and instead connects one side of a PT winding (whose other-side is connected to Diodes on the 12C8.  At a glance, this appears to be a "diode detector" for Line Voltage, where the resistors and 0.05µF cap give a slowly-changing DC Voltage that is proportional to the Line Voltage (governed by the Pot; maybe a "Wattage" Pot?).  This DC Voltage is applied to the 1629's triode-grid, so once again, polarity matters.
But I see a bunch of primary wires on the power transformer, and they're all "Black"... If you still have the 2-prong cord, you would just flip the cord over to make the magic eye work.  If it worked for audio, but not for what I assume is "Watts" then you would swap Black wires on the second-primary to get that feature working.
__________________________________________
Now that I think for a second... vintage test gear never assumed the chassis was "0v relative to earth" and usually did not want the "test gear chassis" to be connected to the "device under test chassis."  Inputs were typically floated off the chassis, and yes, there could be significant (even dangerous) voltages between one item connected to Line Voltage and another item connected to Line Voltage.  (Reminds me also of the use of "Line Isolation Transformers" that intentionally divorce a tested piece of gear from other line-connected devices, so voltage-differentials like this can be squashed while keeping a 3rd-prong connection to Ground at the service panel).
You can try swapping PT primary-wires, but there's a chance this is "just the way it is" (I haven't really thought enough about it to know whether the chassis voltage-differential would go away).
Offline acheld
« Reply #3 on: June 07, 2026, 02:44:18 pm »
I have no experience with this unit (which sounds like a very cool piece!), but I have purchased several amateur built Heathkit units over the years.  What I've found is that the folks who put these together modded them or made errors of various proportion.
So, my approach now is to carefully strip these apart, and then follow the manual to put them back together.  Very relaxing!  Not only are the assembly instructions good, but the test and calibration methods are very well described and easy to do.  And you normally end up with a good piece of equipment.   What could go wrong!
Offline goldstache
« Reply #4 on: June 08, 2026, 07:32:31 pm »
Thank you so very much for the thoughtful posts!
Here’s where I landed.
So turns out that my shielded cable type mattered.
Went to an RG 70R type, and optical deflection of magic eye was same regardless of AC mains phase input.
Why? Could not say……..
Once the irregularity seemed handled. Wired modern convention
Live/fuse 750ma slow (as I have mains current shunt rig, and won’t be using the heathkit for mains draw)/switch/transformer.
Neut to transformer.
Cap removed, though was good on Sencore.
I did try the no cap first. To see if there was a leakage current. Just to parse what the heck.
Then continued on to the probe discovery.
I’m just using it AF mode. Noise test.
I do have an RF probe, and verified.
I did cap isolate the AF tube from gain pot wiper, had a 10M handy for bias.
And the other oddity has I worked it, was that the unit had a 6x5 present for recto.
In my clamoring for info, noticed heathkit had 2 schemos. Prolly more.
But the other schematic had a 6y5.
And the primarily 12v heated tubes needing the full filament winding, end to end.
The CT was left floating for the 6x5 to one end, to warm.
The 6y5 scheme has that CT at chassis.
Despite having the 6x5 version wired and in place, I decided to 0v that filament CT.
So recto is running
6.3vac - 0v
Instead of the 6.3 -0- ………(6.3v)
Gotta help with some idle noise in unit???
And, all that….
I like it.
It’s really good at finding trash passives (new band name maybe)
Thanks to the both of you. I will carefully read what ya sent a couple times, was just exuberant to share that I got to put to bed…for now.
