August 29, 2026, 09:40:07 am
Hoffman Amps Forum image Author Topic: Reverb transformer for Gibson GA19-RVT Falcon  (Read 9634 times)
Offline chocopower
« on: October 30, 2009, 06:36:03 am »
Hello from Spain!
Could i use an standard Fender reverb transformer in a Gibson Falcon like this:
http://www.schematicheaven.com/gibsonamps/ga19rvt.pdf
The original trafo is marked in another schematic as "TF-E-6400"
Regards from Spain!
David
Re: Reverb transformer for Gibson GA19-RVT Falcon
« Reply #1 on: October 30, 2009, 06:44:56 am »
I think so.
Offline chocopower
« Reply #2 on: October 30, 2009, 06:59:44 am »
Mercury Magnetics have an original replacement, but i think 40$ is pay too much for a reverb driver....
David
« Reply #3 on: October 31, 2009, 06:22:41 am »
Sure you can.
Offline LooseChange
    • Fix Your Darn Amps
« Reply #4 on: October 31, 2009, 06:37:48 am »
Yes, you can use the Fender type.
I've got the same amp. It was a mess and I completely refinished it.
Can you post a picture?
Call me Dan
www.fydamps.com
Offline chocopower
« Reply #5 on: April 13, 2010, 10:41:03 am »
Sorry.. i just have seen you reply right now..... :embarrassed:
here are the pics:
The only mod i have done to this baby are the usual safety ones and rise the P.I. coupling cap from 500pf to 1000pf. The original one is perfect for humbuckers, but  i use it with a Jazzmaster and need the extra punch.
Next time i opened it (what a nightmare!!) i have the idea to install a "fat" swicht to change betwen the two values (two 1000pf caps in series, shorting one of them with a swicht).
Amp was found in rubish for a friend of mine. No speaker. RCA 6V6 inside. After the cap job and others minor works is working like a charm with a Weber 12F150. Original 6V6 are ok too. 270 ohm bias resistor rise his value to 800 ohm, so bias was so cold that keep the tubes in a good condition.
« Last Edit: April 13, 2010, 10:46:45 am by chocopower »
David
Offline duke of earl
  • Bird is the Word
« Reply #6 on: April 19, 2010, 10:29:41 pm »
I have one of these in great condition with the original speaker. It sounds beautiful!
