September 08, 2026, 12:17:39 pm
Hoffman Amps Forum image Author Topic: stout relay circuit  (Read 13541 times)
Offline scole
stout relay circuit
« on: November 27, 2009, 03:22:36 pm »
what does the relay circuit do? can it be left out?
Offline topbrent
  • In pursuit of more cowbell...
Re: stout relay circuit
« Reply #1 on: November 27, 2009, 04:38:25 pm »
The relay switches the extra gain stage in and out.
Here is the hardwired, gainstage always on version:
http://www.el34world.com/projects/images/Stout.gif
Here is the switchable gainstage version:
http://www.el34world.com/projects/images/18WATT_VOLTAGES.gif
« Last Edit: November 27, 2009, 04:42:14 pm by topbrent »
Offline topbrent
« Reply #2 on: November 28, 2009, 04:26:07 am »
Here are the schematics to compare if you prefer.
There wasn't a schematic for the no-switch version, so I edited out the relay circuitry.
Offline scole
« Reply #3 on: November 28, 2009, 12:48:43 pm »
can you make a master vol version of the stout?
Offline scole
« Reply #4 on: November 28, 2009, 11:20:04 pm »
why do we need the relay? cant we just put a direct switch? is it for safety? to keep high voltage away from the control panel?
« Reply #5 on: November 29, 2009, 02:09:54 am »
more short are the wires less is the way to get noise
that can be a good reason
Kagliostro
« Reply #6 on: November 29, 2009, 07:27:10 am »
The relay makes it very easy to switch remotely via a footswitch.
Offline scole
« Reply #7 on: November 29, 2009, 11:45:38 am »
ok so you dont really need the relay, you can just put a regular switch in?
« Reply #8 on: November 29, 2009, 12:36:02 pm »
yes
Offline scole
« Reply #9 on: November 29, 2009, 06:54:41 pm »
does the stout with no switch have any clean or is it all gain?
