September 14, 2026, 02:25:46 pm
Hoffman Amps Forum image Author Topic: Tektronix 515A scope  (Read 20909 times)
« on: November 30, 2009, 10:40:48 pm »
Any thoughts or info on this scope? I have some one that want to give it to me via some shipping. Looks new /
Offline tubesornothing
Re: Tektronix 515A scope
« Reply #1 on: November 30, 2009, 11:21:59 pm »
If is has a sharp trace and displays a sine wave from a generator then why not?  It will do the trick.  A dual trace would be nice, but if shipping is $20, then signle trace will work.
Does it have a probe?
Now, if it doesn't work or is "untested", then you might want to consider something else.
« Reply #2 on: December 04, 2009, 05:25:12 pm »
It was fully serviced and works good from what i have been told. Was shipped to me free of charge along with some other items i have not yet found out what they may be. The UPS shipping weight says 50lbs. Met a real nice person that owns a PCB factory and there tech is no longer present. Cant wait to see what all is there /
« Reply #3 on: December 05, 2009, 01:02:51 am »
You can bank on at least 40 pounds, and then some for all those old Tek scopes. I actualy have a bunch of them just sitting around because they take up too much space. That, and I really need to verify proper operation of them and do a basic calibration (I don't really have all the stuff to do it "right").
If I found some of them didn't work right or were a little too much hassle, I'd probably strip it down, sell useful irreplaceable items on ebay (like a well-functioning CRT, plug-ins, etc), and swipe some of the cool reuseable bits (crazy PT's with many secondaries/taps which could be good for building a bench power supply).
But other than size, their good enough to do everything we'd want to do, and don't have feature overload that can make the learning curve vertical.
« Reply #4 on: December 07, 2009, 04:39:40 pm »
if i had some tektronix iron laying around... i'd love to build this
« Reply #5 on: December 08, 2009, 03:41:57 am »
I've seen that, and pondered it a bunch. Then wondered if I'd really want to cut up and old Tek scope. But reality is I've got a bunch of these around and we're unlikely to be the folks who'd say the tube scopes work better than the SS scopes, so...
I couldn't even tell you the model numbers of the ones I've got right now, just because they've been in storage for a few years.
« Reply #6 on: December 08, 2009, 02:51:30 pm »
your torch or mine?  :laugh:
on a more serous note though, there is still plenty of tek tube stuff still floating around. if your scopes were worth placing back into service, would you have not done so by now? just something to ponder... i'd love to have a copy of the iron, if just for anything would be to have it cloned by edcore or heyboer so we don't have to gut anymore old tek gear than necessary. i'm scouring ebay now for a tek 535 carcass... no luck so pfar, only a functional unit for more that i care to spend...  :undecided:
« Reply #7 on: December 08, 2009, 07:25:06 pm »
Here are some pic's. It arrived today via a very generous benifactor and a great person to converse with
It's a beauty. Now i have to learn how to use it properly /
« Last Edit: December 08, 2009, 07:27:16 pm by plexi50 »
« Reply #8 on: December 08, 2009, 08:25:36 pm »
Very nice!  (very nice artsy phot at the bottom too!)
Just power it up, check for a nice focus, plug into vertical input 1, hook the other end to a guitar.  Turn the volts/cm scale to 0.1 and strum a chord!  You will also have to adjust time/cm...
« Reply #9 on: December 08, 2009, 09:15:59 pm »
Yummy!
« Reply #10 on: December 08, 2009, 11:12:27 pm »
http://www.tek.com/Measurement/App_Notes/XYZs/
"XYZs of Oscilloscopes
Introduction
After reading this primer, you will be able to:
    * Describe how oscilloscopes work
    * Describe the differences between analog, digital storage, digital phosphor, and digital sampling oscilloscopes
    * Describe electrical waveform types
    * Understand basic oscilloscope controls
    * Take simple measurements"
« Last Edit: December 09, 2009, 01:11:48 am by PRR »
« Reply #11 on: December 08, 2009, 11:43:34 pm »
After reading this primer, you will be able to:  ...
and there will be a test!
« Reply #12 on: December 09, 2009, 06:59:48 am »
There's a trick to getting a good stable waveform displayed on that old scope. The trigger level and stability controls work together. After selecting your trigger source, you will turn the trigger level and stability controls max clockwise. The timebase will freerun, ie, the display will be nonsynchronous. Rotate the stability control CCW until the display blanks out, ie, timebase is not triggered or freerunning. Now rotate the trigger level CCW until the display reappears. It should be rock solid at this point.
There is a preset position for the stability, but it doesn't work very well. I don't know if this trick is documented in the manual. I learned by word of mouth and never checked the manual.
« Reply #13 on: December 09, 2009, 08:19:41 am »
I will play with it today and try your tips out Sluckey. Thanks for the info link PRR!
If i turn the wrong dial and dissapear it's your's! (Time Machine)
« Last Edit: December 09, 2009, 08:33:44 am by plexi50 »
« Reply #14 on: December 09, 2009, 08:40:16 am »
You can d/l the 12meg pdf manual from BAMA.
« Reply #15 on: December 09, 2009, 08:47:02 am »
I just noticed the square wave calibrator at the bottom (its just a signal source), so no need to hook to your guitar, just hook to the calibrator.  Set the vertical volts/cm to 1 and set the square wave calibrator to 1 (to start with).  You probably have to adjust the timebase, not sure what frequency it is.  Adjust the vertical volts/cm to adjust the height of the wave.
Dont forget to take pics - we have to see this puppy in action!
« Reply #16 on: December 09, 2009, 07:29:20 pm »
Here a 15 second vdeo i just made using my oldy but goody Mavica FD83 floppy camera
The video asks a question / It skipped using media player but works using GomPlayer
It may be my computer acting up / I think this scope is going to help me a lot in solidstate amp repairs once i get some schooling
http://s356.photobucket.com/albums/oo5/plexijtm45/?action=view&current=MVC-001W.flv
« Reply #17 on: December 10, 2009, 12:20:41 am »
Very cool.  I should video respond, but that would require me thinking - ha!
Just grab any guitar cable, unscrew one of the ends.
(pic A) Take your scope probe and put it on "input 1" BNC of the vertical input
(pic B) Plug a cable into your guitar
(pic C) then take the opposite end of the guitar cable, unscrew it , then take the probe end of the scope probe and connect to the guitar cable.
You'll also have to adjust the time base (time/cm) until you get a nice waveform.  Try 1ms/cm. From your video, I think its set quite slow.
« Last Edit: December 10, 2009, 12:24:32 am by tubesornothing »
« Reply #18 on: December 10, 2009, 12:26:31 am »
Another way you can connect to the guitar cable, is if you have a 1/4" jack kicking around.  Just plug the guitar cable into the jack, and connect the scope probe to the jack.  Ground clip to the shield, probe tip to the tip connector.
Offline TubeGeek
    • Glacier Amps
« Reply #19 on: December 10, 2009, 12:33:38 am »
Nice scope!  Kinda looks like my avatar!
« Reply #20 on: December 10, 2009, 07:15:34 am »
Your max vertical sensitivity is .05v/cm. Your probe is a 10X, so max vertical sensitivity will be .5v/cm when using that probe. Your displayed guitar signal will be pretty small.
If you just want something to look at to get used to using the controls, I suggest using the cal output. You'll be able to properly trigger the scope and view the stable square wave cal signal. You'll be able to change timebase speeds to see how the display is affected and you'll actually be able to measure the time (1/freq) of the waveform. And since the cal output has several voltage level outputs, you'll be able to verify that the vertical attenuators are working properly. And you'll be able to adjust the probe's internal compensation cap.
To connect your probe to the cal output, just straighten a paper clip and insert into the center pin of the BNC jack. Then clip your probe to the paper clip. BTW, there are several different probe tips for that probe, including a BNC tip, male test pin tip, and female test pin tip. There is also a X1 probe in that same style. That's a very popular probe in RADAR work.
« Reply #21 on: December 10, 2009, 08:27:20 am »
I did not see it was a 10x probe (Steve - how could you see that!?!).  Yeah grab yourself a 1x probe (even a knock off will work fine here), you will need it for those small signals.  Like on guitar input, or after a reverb drop resistor.
« Reply #22 on: December 10, 2009, 08:51:29 am »
I work with that type probe daily, both 10X and 1X.
See that fluted piece on the rear end of the probe? That's the locking collar ring for the probe compensation adjustment. You view a square wave, loosen the ring by turning CCW, then rotate the body of the probe to minumize overshoot or undershoot on the lead edges of the square wave, ie, adjust for the best looking waveshape. Then turn the collar ring CW to lock the setting.
1X probes of that type don't have a comp adjustment nor that fluted locking ring.
here's a pic...
« Reply #23 on: December 10, 2009, 09:20:08 am »
Cool on the compensation adjustment on the probe!
You were right about the wave form being small
Here is the video of it working /
http://s356.photobucket.com/albums/oo5/plexijtm45/?action=view&current=MVC-001W-1.flv
« Reply #24 on: December 10, 2009, 10:39:13 am »
Very cool.  Give the square wave calibration a shot.  Then time to try it on an amp - got one on the bench?  I dont suppose you have a sine wave oscillator kicking around do you?
« Reply #25 on: December 10, 2009, 02:22:53 pm »
No signal generator these days. Have had some in the past but never used them either
There cheap enough i believe on Egad. Just buttoned up a HotRod DeVille and it left 5 minutes ago
Have a SVT Pro 2 on the bench but it as well has just been buttoned up and is waiting to be picked up
Wait! I have a little Fender 5F1 amp not in a cabinet that i have full board access to /
Whats can i test with it? Signal off the mixer resistors or feedback resistor? Im quessing /
« Reply #26 on: December 10, 2009, 03:06:28 pm »
You can pull the signal from anywhere - except off the plates of the tubes.  In that case, just pick it up after the coupleing cap, or on the output of the OT.  PRR will chime in with how to make a probe to pull it off the plates.
CAUTION: before you hook up yor scope probe, turn your vertical sensitivity to like 5V/CM - the highest.  Then once you have it call connected, slowly turn it down to get a nice shape.
You can use the signal generator in the scope to pump into the amp and a stable waveform, just use a coax cable and a 1/4" jack or a torn up guitar cable.  Square wave is far from ideal, but it will get you going.
« Reply #27 on: December 10, 2009, 04:24:43 pm »
How do i use the scope to see the power tube bias waveform?
I have several waveforms i got off the tone lizzard site for waveform bias reference / Cold / Hot
« Reply #28 on: December 10, 2009, 04:33:20 pm »
I can't find that article, so not sure what it going on. Can you post a link?
Perhaps he is injecting a sine wave signal and checking crossover distortion to set bias.
« Reply #29 on: December 10, 2009, 06:31:58 pm »
ok then, use your PC's/laptop's sound card...   :smiley:
http://www.dxzone.com/cgi-bin/dir/jump2.cgi?ID=17725
« Reply #30 on: December 10, 2009, 07:42:58 pm »
ISOTone you just refreshed some of my brain cell's / I have an old computer program called Cool Edit /
It has a signal generator program complete with all the bell's and whistles. Great idea
Here is the Bassman and Marshall biasing link using an oscillascope/
http://www.tone-lizard.com/Bassman_bias.htm
http://www.tone-lizard.com/Marshall_bias.htm
« Reply #31 on: December 10, 2009, 07:54:11 pm »
OK, that's what I thought.  Put a 500Hz 200mV tone into the input jack of the amp.  Hook the scope to the speaker output (with either a speaker or a dummy load attached).  Slowly crank up the amp and the crossover distortion will start to appear.  Adjust bias for minimal crossover distortion/best tone/70% of plate dissipation.  (i.e. its a compromise).
« Reply #32 on: December 10, 2009, 10:43:13 pm »
Add this link to your lists; much more useful than that Tek XYZ booklet.
http://www.doctronics.co.uk/scope.htm
Also:
http://www.doctronics.co.uk/design.htm
« Reply #33 on: December 11, 2009, 10:28:27 am »
Ok i am going to try the biasing out later today with the scope
I will take a video of it as well /  Good link PRR
Offline supro66
« Reply #34 on: January 13, 2010, 08:25:35 am »
« Reply #35 on: January 13, 2010, 09:29:05 am »
I cant see if the timebase plug in has triggering options.  Probably.  The bandwidth is big enough.  4 channels is way more than enough (I think I only use 4 channels about once a year, but can be interesting).
« Reply #36 on: January 13, 2010, 10:12:08 am »
Yes, it has triggering options. I was working in PMEL when those modular scopes first started showing up in the USAF. What a neat idea! As it turns out, they were a bear to calibrate, not to mention repair. They didn't stay in inventory very long.
The price is right. And you still have an empty bay for a Function Generator plugin. Plugins are available, usually for around $cheap.
Offline supro66
« Reply #37 on: January 13, 2010, 10:24:01 am »
Darn
Everybody knows about it now  :grin:
I may get one don't know yet
I would like to call around to some TV repair shops and see if they have any to sell
I like to see it work before I buy
« Reply #38 on: January 13, 2010, 05:32:15 pm »
I jumepd in too; and recently bought a Protek 20MHz analog scope on eBay. Good price; hope it works.  Between PRR, Sluckey & Tubesornothing, and earlier threads, we should do OK.
Congratulations on that Tetronix 515A.  It's one beautiful piece of vintage equipemnt!
« Reply #39 on: January 19, 2010, 08:03:35 pm »
I am in the process of moving so i did not get around to making a cable for my PC soundcard yet to inject the 500 Hz signal
Soon /
« Reply #40 on: January 19, 2010, 08:49:01 pm »
Moving... scope.... moving... scope...
Hmmm, the decision is obvious.  Now throw in guitar playing and things get messed up.
Perhaps you have a tuner with a nice 440Hz output?
Pictures when you get a chance...
« Reply #41 on: February 26, 2010, 08:14:53 am »
Well, after some checking, it seems I have a pair of Tek 533's, a 532, a rackmount 506, and a couple of others. The rackmount unit is probably the most likely candidate for the torch, as it is huge and the rackmount format means it takes up way too much space on a bench top. Somewhere, I have manuals for a few of these, which will also spell out the voltage and current ratings for each tap on the power transformer. They are also available free posted on the net in various places.
So maybe we can come up with something after all.
The big question in my mind is whether it is smarter to use tubes for pass elements in a regulated power supply, or whether the switch should be made to MOSFETs. To use tubes, you generally want pentodes or beam power tubes, because using triode pass tubes would require more voltage dropped across the tubes, which leaves less for the output voltage. And the typical pentode/beam pass tubes (EL34, 6L6, EL37, 6550, etc) are ones we'd want to save for actual amp projects...
« Reply #42 on: February 26, 2010, 11:50:41 pm »
ok then, if you have just the one copy of the 506 PT, looks like a custom wind might be track to follow - from past experience, i do believe that edcore would provide a quicker turn-around than heyboer - i'd like to submit a design request/quote if we can come to a consensus on what to use - more on that below.
some in-line research - i found the 533 manual at bama.com - the 506 isn't listed... is the 506 the rack-mount version of a bench-top such as the 504 perhaps?
http://bama.edebris.com/manuals/tek/533/
looking at his schematic again and the tek transformer data on his URL (link below) it seems as though the 533 PT won't provide the 500mA desired - don't know about the 506 PT. if i were to request a custom build, is it safe to assume the winding table below for the secondaries is reasonably correct?
http://www.pmillett.com/Tek_xfmrs.htm
360V RMS @ 600mA for the plates (i bumped it +100mA)
195V RMS @ 150mA for the bias and V reference supplies.
180V RMS @ 230mA for the screens (deleted if MOSFETs used)
6.3V RMS @ 6A for the 807 bank filaments. (deleted if MOSFET's are used)
6.3V RMS @ .5A for the error amp filament.
6.3V RMS @ 6A for user filaments.
we could toss in a 5V 3A for tube recto.
the above could also be split up into 2 or more transformers if it will save $.
...switch should be made to MOSFETs.
agreed, as it would reduce the complexity considerably, e.g. screen PS & 807 heater secondaries not needed. on the other hand, would we not need to redesign the error amp?
i do have some 807's and sockets i've been stashing for this very project with access to more if you're interested. if we do go with MOSFETs, we'll need a fairly hefty heatsink and make adjustments to the original layout. should we decide to stick with the plan unmodified, in regards to the 807's, what are your feelings about adding cathode fuse to each 807. and finally on the 807 subject, it seems as though there are russian 807 tubes available and there seem to be plentiful supply of them.
as far as the front panel and chassis lower go, if we follow pete millett's design, and you don't mind copying (he doesn't mind if we do so), then i'd be willing to machine a pair of each of the front panels, chassis lowers, and turret boards on my CNC machine. buttery may chime in and join the party, so three copies would be about all i could stand to mill in one run since my machine is pretty slow.
thoughts?  :smiley:
« Reply #43 on: February 27, 2010, 05:21:27 pm »
The screen/beam tubes are often operated in triode mode.
To work as screen/beam tubes you need a screen supply, floating, referenced to the cathode (or regulated voltage). That's another winding, rectifier, cap.
The fatter pentodes make good-enough triodes for many purposes. 6L6 triode will pull down below 800 ohms. At 100mA that's just 80V drop. Yeah, it's an extra 33% on top of the typical 250V regulated output, but that 33% more on an existing supply is "usually" cheaper than building an additionaly supply just for screens.
They use power pentodes mostly because large cheap power triodes stopped at 2A3 and 6080, around 12W dissipation. The highly developed mass-produced pentodes were a better deal even when you didn't use all the grids you paid for.
Pete Millett, of course, did it the hard way (with screen supply).
The rackmount 'scope would be a cool filler in a large studio rack. It's an adequate audio 'scope, and if you put it where the client sees it, some clients will be entranced for hours.
IMHO: for most work you will do, you want a steady 6V at big A, plus a 420VAC-600VDC supply on a Variac. Precise regulation is NOT generally needed, and is complex, expensive, untrustworthy....
The very high Gm of the MOSFET means you hardly need an error-amp. Use R and Zener to get steady 400V. Pot across that (GOOD pot) to drive FET gate. FET gate-source voltage will be 2V for bleeder current and 5V for more current than any tube can absorb, 3V sag, ~~1% error of output.
« Reply #44 on: February 28, 2010, 12:57:48 pm »
ok then, if you have just the one copy of the 506 PT, looks like a custom wind might be track to follow ...
Well, let's not be in a hurry to pull money out of pocket. My "rackmount 506" terminology is used to describe the Tek RM506, which is the actual model # on the scope. My ASSumption is there is a non-rackmount 506 floating out there as well. BAMA does show have a RM503 schematic, and it might be close enough.
But my real point is that only a couple scopes out of maybe 6 or more are in the kind of cosmetic shape that Plexi50's 515A is in, so they are all potential candidates for surgery. That is said because I also have a Tek 475 in good working order, and that is the most likely daily-use scope I'd turn to. Since I'm not likely to become a scope collector (I already need to whittle down my assortment of HP test gear, which has turned into a collection), I'd probably feel satisfied with wrestling with just 1 tube Tek scope and nursing it back to good working order.
Who knows? They might need limited work. But there's a lot of caps to be changed, etc, and I'd rather focus on guitar/audio electronics rather than restoring scopes when I don't really have all the needed test gear to calibrate them (mainly thinking of time marker generators and the sort).
So we potentially have a lot of "free" transformers.
