September 08, 2026, 04:21:20 pm
Hoffman Amps Forum image Author Topic: Mic for vocals with Apple  (Read 11586 times)
Offline Fresh_Start
  • noob de Lux
« on: December 28, 2009, 02:26:32 pm »
My daughter has an Apple laptop with Garageband on it.  She already has recorded a couple of multi-track vocal pieces which sound amazingly good given the internal microphone.
Is there a reasonably priced microphone which she could use for recording?
I don't want to get into a preamp, etc.  She is a bit of a Luddite.
Chip
Quote from: jjasilli
Quote from: PRR
Offline tubesornothing
Re: Mic for vocals with Apple
« Reply #1 on: December 28, 2009, 02:33:27 pm »
Whats she recording?  vocals, acoustic guitar, miked amp cab, drums?  All of the above?
Offline Bassmanster
  • Rarrrawweth!
« Reply #2 on: December 28, 2009, 02:46:36 pm »
There must be a decent USB LD condenser for cheap.
But anything will be better than the internal mic.
I will be swift.  And merciful.
Offline Frankenamp
  • What does this button do?
« Reply #3 on: December 28, 2009, 05:34:23 pm »
I've had good results with Audio Technica mikes, they seem to have a decent rep. And Ditto to the above- anything is better than the built in mike.
This problem calls for a bigger hammer!
Offline terminalgs
« Reply #4 on: December 28, 2009, 07:09:46 pm »
MXL 990 USB.  decent condenser mic. , $80 @ MF,  sounds good with vocals,  or amps.  there is a stereo unit and a mono unit.  I set a friend up with a mono unit and Apple/garageband.  works good.  you'll need to show her how to select the device and then change the gain under the  'System Prefs->Sound->Input'.
Offline Fresh_Start
  • noob de Lux
« Reply #5 on: January 01, 2010, 10:36:47 am »
Well, I'd decided on the Blue Snowball but when we got to Apple Store she declared that it was too big to travel with.  The Blue Snowflake is a USB condenser mic and she loves it!  Only $54 with a friend's Apple employee discount.
FWIW the Snowball is really cool in that it can be cardioid or omnidirectional.  The frequency response is actually a bit less than the Snowflake but I'm betting the sound is better.
Just thought you all might be interested in the outcome of my search.
Chip
Quote from: PRR
