August 29, 2026, 08:49:17 am
Hoffman Amps Forum image Author Topic: single speaker out of phase??!??  (Read 11486 times)
Offline tubesornothing
« on: April 24, 2010, 03:16:18 pm »
So a buddy says to me that dumble and fuchs single 1x12 speakers are wired out of phase.  That when the guitar signal moves positive, the speaker sucks in, and it should push out.  This is a single, solo speaker - I am not talking about more than one speaker.
To me this sounds like just a bunch more mojo hype stuff.  With the number of times inverting stage flips the signal, combined with the phase shift of RC networks and other circuits I think designers get lucky if the guitar signal matches the speaker signal phase.
So...  is there any fact behind this?
Offline JayB
Re: single speaker out of phase??!??
« Reply #1 on: April 24, 2010, 03:25:29 pm »
Sounds like mojo.
You're going to hell faster than Britney Spears running to a Barber shop
Offline P Batty
  • Flippism Is The Key
« Reply #2 on: April 24, 2010, 03:50:52 pm »
It shouldn't matter unless you use it in a multi-amp setup, where it matters a lot!  That said, many hi-fi guys swear that reversing the speaker polarity while playing some recorded music will "enhance the sound stage."
« Reply #3 on: April 24, 2010, 05:13:28 pm »
I figured as much.  Perhaps I'll take the time to figure it out and add it as a selling feature.
Offline OldHouseScott
    • Old House Recording Studio
« Reply #4 on: April 24, 2010, 05:22:22 pm »
You're too late. Matchless already did it. Check out page 3.
http://www.schematicheaven.com/newamps/matchless_dc30_old.pdf
OldHouseScott
"We put a little quality in everything we build..."
Offline JayB
« Reply #5 on: April 24, 2010, 05:56:32 pm »
 :laugh:
I can actually see that being useful. You want all the guitar players and bass player speakers to be in phase. If not the band can sound like crap.
« Reply #6 on: April 25, 2010, 08:13:12 pm »
Can you explain this?
Offline JayB
« Reply #7 on: April 26, 2010, 10:15:48 am »
It's just the same thing as having a speaker out of phase in a 2x12 cabinet. It's noticeable to me when two guitars playing the same note. It's a weird phasing effect. All I can say is try it sometime.
Offline Structo
  • Tube Burner
« Reply #8 on: April 26, 2010, 07:52:39 pm »
From what I have read even some effects put the signal out of phase.
Is it true that is an amp has an odd number of stages that the signal will be out of phase?
That every stage inverts the signal so if it is out of phase going into the phase inverter that it is out of phase at the speaker?
Don't let out that smoke!
« Reply #9 on: April 27, 2010, 12:18:32 am »
Not every stage inverts the signal - for instance, cathode followers do not.
I just put a scope on the PI and speaker output of an AB763 (ish).  They are out of phase with each other.  I could probably re-jig this by swapping OT leads or grid leads.  So "it all depends".
If phasing is something to worry about, then you would want to get the input signal in phase with the speaker output.
Offline Frankenamp
  • What does this button do?
« Reply #10 on: April 27, 2010, 09:23:58 am »
At the risk of sounding pedantic, there will be more effect on phase between a guitar and bass or two guitar cabinets with the physical distance involved. plus there is a geometrical function: think of the triangle between the two speakers and your ear, as you move around the angles and the distances change. A lot. Much more than flipping the phase one way or another. Also the distances to and from the walls and ceilings have other effects as the distances and frequencies change. There is a lot more room for actual acoustical physics than the (mojo) effect of flipping the phase of the amp. Have someone pick up your speaker box and slowly rotate or tilt it as you play, you'll hear what I mean. A guy named Leslie sold a lot of speakers that did the phase shift thing mechanically for organs- and guitars... till someone invented a little stomp box that sounds kinda like it but weighs less...
Just had a 'Neil Young' moment: considering the logistics of hookin' up some actuators to a footswich to move the cabinet around... kinda like his 'wizzer' setup- (tilt up, down twist left...) that gymbal setup might not be practical for anything larger than a champ or pignose... but it's a fun mental excercise.
Addendum: I seem to remember a section in Weber's "Hip Guitar Amp" book where he waxed eloquent on the subject... Much as I respect most of his knowlege... that section was a bunch of hooey. (my .02c)
« Last Edit: April 27, 2010, 09:28:30 am by Frankenamp »
This problem calls for a bigger hammer!
« Reply #11 on: April 27, 2010, 10:08:51 am »
He did at least mention that it was "absolute phase" and say that it was more important in multi-amp/multi-speaker setups.
By yourself, he claimed that it could have an effect on acoustic feedback. But if that's true, so could moving closer/farther away from your speaker, due to the wavelength of the sound.
I wouldn't worry about all this too much; it's a bigger issue if you send a single signal through 2 amps which result in opposing phases at the speaker, because (presumably) you're dealing with 2 signals that are otherwise identical.
Time-based effects like phasing, chorus and reverb do crazy things to the phase of a signal as well, and most people are typically pleased with the result.
Offline panhead
  • Play it like your hair's on fire
« Reply #12 on: May 03, 2010, 11:54:46 am »
As someone said, the physical distance involved will affect the phasing and probably negate any effect of the different instruments speaker phasing. Same thing with the acoustics of the room.  I've wondered if speaker phasing (or the relationship between the speaker and pickup phasing) affects the feedback you get from holding your guitar in front of your amp.
Panhead
Offline P Batty
« Reply #13 on: May 03, 2010, 10:14:04 pm »
If you do get into a complex, multi-miked, multi-speaker set-up it is something to consider, you (or your sound tech) will have to come to grips with this issue. If it is only two cabinets, not miked (or only one miked), I don't think you will have a problem, there are so many phase cancellations going on at different frequencies that the relative polarity shouldn't matter. When I used to do sound, I would always have a phase reverser for the mics, just in case.
